amp n sub install off stock HU 2003 TL-S
i kno there was a forum running on this already. but no1 responded to it so i figured i would start another 1. has ne1 installed subs n amp off of ur stock HU. if so did u use a Hi Low COnverter or did u just tap into it somehow like in teh other description.? n also where is the factory amp located? a descrpition would b very helpful..ne help would b good. thanks in advance.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
The easiest way to do it is with a LOC. You can just splice the trigger off of the amp's remote or run one with a switch. The amp would need it's own power from the battery though obviously
Pleasure Unit
What I did was very simple and owrked out well (when i bought my car new):
I bought an amp that accepeted line level inputs (no need for a remote wire) and only had to run 3 wires - one from the battery to the amp for power, another from the amp to ground, and a third from the stock sub speaker wire to the line level input on the amp - very easy. Of course you will need an additional sub too, but that is self explanitory. I even left the stock sub going - it sounded more balanced than just the aftermarket sub, plus the stock amp didn't need to be bypassed (load from the stock sub) - very easy. About 2 hours of work for the whole thing - at least 90 minutes of that was running the power wire from the battery to the back.
So true..
handsom-hustla
11-13-2015 05:04 PM
