Amp bypass
Jared
Amp bypass
Okay, I have my wiring harness from crutchfield and have a question. I am a novice installer but am a bit baffled. The harness has the amp turn on, dimmer, power, and constant and ground. THat part I understand. THe part that is throwing me off is the that the speaker leads are RCA connectors. Do i need an another amp and wire them in, or can I run them off of my headunit. ?Thanks
Rollin'... White 2 seater
amp
I am also not the best audio guy, but form what I understand you can take the RCA leads adn run them to another anmp and then run the amp into the speakers. Or can get a signal convetor and you can run the RCA into it and then use the wires that come out and finagle it into the bose amp inputs. For what i have been told it is best to get a 4ch amp run the rca into it and then connect the speakers into the amp. I am not an expert and you might find better info in the FAQ or link in the a/v section that is for reference then you can get the color key and such.
InFaMouSLink
10-30-2015 09:43 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
