Alpine Type S Speaker Upgrade
#41
Originally posted by 97AcuraCL
I was gonna just disconnect and do away with the 6x9s because they only receive lows dont they? And I've got an Alpine Type-R 12" Sub that I'm gonna power with a mono MTX Amp to drop in the trunk for my lows.
Now if I'm wrong about the rear deck speakers being used just for lows... Would it be possible to get like a set of Alpine- Type S 6x9s' and a 4 channel amp to power all the door speakers and the 6x9s? What about from the stock amp.... can I use the stock Amp to power all my Type-S door speakers and the Type-S 6x9s or will that be asking too much of just the stock amp? So if I did decide to add some Type-S 6x9s to the Type S door speaker set up I've got... can I use a decent 4 channel amp to power just the interior speakers? (keep in mind that I'll have that 12" Type-R Sub in the trunk off its own mono amp for PLENTY of bass)
#42
My bolonga has a 1st name
1 Post
Originally posted by SilverTSXinPA
See my post above.
See my post above.
IF I MUST go with an amp... how would something like this work....? Would it be ample to run JUST THE INTERIOR speakers?
http://www2.shopping.com/xPF-Mtx_Thunder_4244
#43
Well I did; but you're talking about running the 6x9s AND a sub with an amp. I just want to run all the interior speakers... My problem is runnning 6 speakers on a four channel amp.... is that even possible? Is it necessary witht he Type-S speakers? The car will be running all Type-Ss in the doors and Type-Ss on the rear deck. Can I run it all off of the stock amp? I mean I'd REALLY perfer running all 6 speakers (plus stock tweeders) off the stock amp... but I guess the real question is will running all of them really be asking TOO much from the stock amp? (PS I just ordered the TypeS 6x9s for 89$ for the pair) So now I need to know if its NECESSARY for me to go looking for a decent costing amp to power them. (PLEASE TELL ME ITS ALL FINE TO RUN OFF STOCK POWER)
#44
#45
1 Post
Yes it is fine to run off the stock amp. I have all Type S speakers installed (doors and rear deck). Made such an amazing improvement that i now want to give them a bit of breathing room. You will not believe the improvement. You will need to turn the volume control up a bit higher to reach comparable volume, but, the clarity and definition is pretty amazing from the stock amp.
to run the front and rear deck speakers... and then run the rear door speakers off the stock amp... how about that... will that work? My biggest problem is speding more than 125 on an amp here.. beacuse I've got to buy a Capacitor if I'm gonna use 2 amps; that in and of itself is another $200. Help here guys?
#46
1 Post
Okay; that auction ended without me making up my mind... So this is what I think I've settled on... Tell me if this seems plausable....
i'm gonna run this amp
MTX Thunder 4244
(All Alpine Type-S) to power my front 6.5" Speakers and the Rear Deck's 6x9s... And Im going to run the rear door 6.5"s speakers off of the stock amp.
Of course the Sub will have its own mono amp.
Plus now I'm gonna need a Capacitor since i'm getting to subs...
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEBWA:IT
that Audiobahn In particular...
can someone please tell me if this is going to work? I really belive it will based on the limited audio knowledge I have... but can anyone just confirm it for me? Please? kthx.
I wont do this for sure for another couple of days; I've gotta make sure I really have this in the budget right now... So i've got soem time... please help any and all recommendations or oppinions GREATLY apprecaited.
MTX Thunder 4244
#47
what about using an amp like
Another idea would be to power the front speakers off of the front two channels of the amp and then power the rear doors AND rear 6x9 full range at 2 ohms by wiring the doors and 6x9's in parallel. This would be a better solution. Then the stock amp would only drive the dash tweeters. Just a thought, and, it happens to be almost exactly what I am going to do.
#48
1 Post
This Amp will do what you are wanting. You will need to run line level converters from the speaker outs from your stock amp. Then, leave the stock amp connected to the tweeters and rear door speakers. You should not need a cap with this setup. The amp does not draw that much. You will most likely need to adjust the amp's gain to match the stock output levels.
#49
You want me to break it?
I haven't yet put together a how to of what I did, but heres the summary - took the signal from the headunit b4 it got to the amp, ran it to the trunk where my 2 amps power Polk db speakers in doors/dash with a sub in the trunk. To answer some of your questions, as long as the amp says 2 ohm (or whatever) stable then go ahead. If your speakers are rated as 4 ohms each and you run 2 in parallel off of the same amp channel, then your amp is seeing a 2 ohm load, so check the amp rating (someone correct me if I'm wrong). The 6X9 are low pass crossed by the stock amp - tap into the signal from a door speaker or something to get all frequencies. If you are going to say replace the rear door speaker, use a line out converter tapped into that speakers stock signal run to your amp - then the front speakers are run off of the stock amp signal, and (once you either tap into the stock speaker wires behind the cd storage bin or replace the speaker wire all together like I did) you can run the tweets (fronts too?) off the stock amp while your rear speakers run off your new amp. Either way, you either have to run speaker wire from your new amp up the center console to where the stock amp output wires are or run all new wire to each door/speaker which takes considerably more time.
#50
I have the same setup, with the same excellent result.
#51
1 Post
So I'm selling the 2 Brand new pairs of the Type S 6.5" Coaxs for sale. Acutally I think I've already got one pair of em' taken care of; but I still have another pair waiting to be sold $65 including shipping for the pair NEW IN BOX.
Please let me know if anyone is interested. I can't move forward because I can't afford to buy thew new Type-R Components for the front until I sell the set of coaxes. :-)
http://www.acura-tsx.com/forums/show...&threadid=6226
#52
ATCer
You guys should be salesmen! Excellent info on these speakers--you have me sold anyways. Here's my question--While I am upgrading speakers in doors and the rear deck, what would be a good tweeter to upgrade to? Cash is not the problem, it's going back and forth to the stores and paying extra install charges!
#53
#54
Can't wait to drive
I'm done installing the Alpine amp into the rear Type S 6 x 9 speakers...but it was so late into the night (past midnight) and I got so tired and clueless that I removed both the rear deck speakers wires at ONCE. Now i'm not sure which one is positive or ground Can someone please post what colors the rear deck speaker wire configuration from looking at it?. I will post my pics of my install after dressing up the wires a bit and my conclusions of the install
#55
Color codes at the speaker:
Left Rear: PNK +, BLU/YEL -
Right Rear: RED +, BRN -
In the harness connecting to the amp the colors are:
Left Rear: WHT +, GRN -
Right Rear: PNK +, BLU/YEL -
#57
Can't wait to drive
Okay, I've finally installed the Alpine amp. The power of the amp is very high. I had to turn everything down--EQ and Gain--of the amplifier so the Type-S speakers won't rattle off the rear deck! The bass is much improve..and almost approaches the effect of a subwoofer. I will put off the install of a subwoofer for now since it sounds pretty good. Bass is tight, and deep. I'm getting some dynamat extreme for the 6 x 9's so the bass should be even cleaner afterwards
Check out the pictures here: My Amplifer Install
#58
Oh..and one other thing....since installing the Type S's...I have not hear the infamous door rattles anymore. I honestly believe that the OEM speakers were so cheaply made that they vibrated the door needlessly...just a guess, but, I would love to know if anyone else who has done the speaker upgrade has noticed the elimination of the door rattles.
#59
Can't wait to drive
I will add foam to the rear deck along with the door speakers also. That should reduce the rattles..and keep the road noise out. Too bad it's so difficult to pull the door panels off...not "hard" but inconvenient. I'll let you know if it improves. But, I am very satisfied with the current results now
#60
Circuit city had buy one pair get 2nd pair 1/2 off on Polk.
This isn't why I bought polk, didn't know about that
deal until after I picked polk. I got four 61/2 polk momo for
$150.
I know it's a matter of taste, they had polk, alpine, infinity
to choose.
A local shop will cut four spacers out of fiber/wood
material for $30. I'll install them with dynamat extreme.
If I like them I'll go back for the two 6x9's.
Everything I hear, it's a big improvement of stock speakers.
$150.
to choose.
#61
Th volume you are getting surprises me...the type ares are rated at 89db SPL and the S's are 92db SPL (more efficient at the same power). With mine, to achieve the volume level of 15 with the stock speakers now requires 20 -22....but presence is much better and bass much deeper. I wonder if there is a gain setting on the factory amp that is out of whack on mine? I can turn mine up to 40 (flat out) loud and clean and clear...no distortion regardless of program (rap, jazz, rock, etc).
I wanted to get an amp, but it seems to be more of a hassle than I expected initially.
#62
2004 TSX NAV 5AT MSM
Forgot to metion this. No cutting was required and the Alpine Magnets for the 6x9's clear the transverse springs in the trunk. Also, there is another post here (dave I think) who swapped out for JBL's. I listened to both and speakers are a matter of taste. The JBL's were really good too!!! The bottom line here is that truly significant performance and quality improvements can be attained with a simple speaker upgrade. Oh, I agree with Dave in that subs may not be needed depending on your tastes in music, and you neighbor's tastes as well. Enjoy!!!
I have the TSX Service Manual and I will follow the photos on Chris Horn's site here...
http://www.chrishorne.com/gallery/TSXspeakers
Am I to understand that this is pretty much a simple speaker swap?
Do you recommend that I use Dynamat when I put these new speakers in?
Anything else I should look out for when I do this?
#63
1. If the type S tweeters don't fit in, use a razor to cut excess material on the INNER edges (of the opening) so the tweeter will drop right in.
2. The left crossover, secure it away from the fuse box. I had some interference problems with mine.
3. Be careful as you pull the door out, as the plastic snaps on the side and bottom break easily.
4. As you pull the door off, take caution to unplug everything before walking away. Especially the plug for the window buttons. One of those fell apart when pulled too hard and took some minutes to figure out what was what.
Have fun!
Have fun!
#64
Re: Alpine Type S Speaker Upgrade
...I replaced the four door speakers with Alpine SPS-170A (35Hz-30KHz, 92db sensitivity) and the rears with Alpine SPS-690A (30Hz-30KHz, 92db sensitivity). To say that the sound is vastly improved is an understatement to say the least.
Couple questions: How do the Alpine SPS-170A speakers mount in the doors? Are any spacers or adaptors needed? And what about mounting the Alpine SPS-690A speakers in the rear deck? Are any spacers needed there?
#65
Davinci> On page 1 of this thread, 11th post down, SilverTSXinPA said "Used the adapter that came with the alpines no problems with spacing."
So I assume this should be a simple swap. the only pain and the thing that has me nervous is removing the panels off the doors.
#66
For anyone who is doing a speaker upgrade for the first time (like me) you can get the Honda/Acura wiring harnesses at Circuit City. They have them on their webpage here...
http://www.circuitcity.com/detail.js...&catoid=-11701
They are $6.99 a pair.
#67
http://www.circuitcity.com/detail.js...&b=g&WT.mc_t=U
#68
I should mention that there are 2 kinds of Metra Speaker Wire Harness Adapters for Honda's that they sell.
The ones we need are the Metra Honda/Acura Speaker Harness part number DW7800SH as seen here...
(the ones I had linked to in my previous post were the wrong kind.
I confirmed this today.
#69
Well I finally did it!!! I replaced the four door speakers and rear deck speakers leaving the factory head and amp. I replaced the four door speakers with Alpine SPS-170A (35Hz-30KHz, 92db sensitivity) and the rears with Alpine SPS-690A (30Hz-30KHz, 92db sensitivity). To say that the sound is vastly improved is an understatement to say the least.
http://iweb.alpine-usa.com:7777/pls/...in=10&p_more=y
What angle did people set the tweeters at? I was thinking straight out, but I guess since they are on the bottom of the door towards the front then maybe aiming the tweeter to the North East on the passenger side and North West on the driver side so they aim more or less towards the listener?
#70
I see that I am confused - I couldn't tell when people were talking about the Alpine Type-S SPS171A vs Alpine SPS-170A.
The Alpine SPS-170A does not have tweeters. Are both the same in terms of ease of install in the door? Above it mentions the Alpine SPS-170A as fitting right in but not sepcifically the Alpine Type-S SPS171A. Crutchfield says neither fit, nor the rear 6x9's.
I am wary of having to install crossovers as I've never done it before. I have done basic speaker installs though.
Thanks! I love this car except for the speakers.
#71
Can't wait to drive
I have the Type-Rs, but I first shorten and soldered the wires, then mounted inside the door using some dynamat as adhesive, next to the speakers there should be enough space. Make sure it's secure so it's not touching the speakers (vibration) and use enough adhesive to mount (it might fall down, and vibrate like crazy there)
#72
I found decent prices for the Type-S's on eBay. I paid $62 (including shipping) for each pair of SPS-170A's and $72 shipped for a pair of SPS-690A's.
The dealer has more up now on ebay here...
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3087090814
and
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3087091701
I got all the speakers this past week. They were well packaged.
He seems to have raised the price on shipping the 690A's but lowered the shipping on the 170A's. In either case it is cheaper than paying $99 plus tax per pair to Circuit City.
As for the small square parts you mentioned, those are for the SPS-171A's not the 170A's that are mentioned in this thread.
There are pics of both in the above ebay links.
and
#74
George - Thanks for the quick reply (and I apologize for my ignorance on these topics, but I am trying to learn more)
If I go with the Alpine SPS-170A I would have to then buy separate tweeter replacements. My thought was to go with the
Alpine SPS components b/c they come w/ tweeters as someone on this thread mentioned going that route.
Those who went with the Alpine SPS-170A, did you then replace the tweeters? If so, with what?
Also, do both speakers mentioned above (for those who have them) fit in the opening w/ no modding?
#75
Originally posted by JiggaMan
aren't these the same speakers.
http://www.discountsjungle.com/alsp2way15co.html
ALPINE SPS-1629S 2Way
6 1/2" Coaxial Car Speakers
SPS1629 SPS1629S "BRAND NEW, FACTORY SEALED, IN STOCK" REPLACED BY SPS1729S SPS-1729S SPS1729 AND SPS170A
#76
The SPS-170A has been replaced by the SPS-171A which now includes a separate tweeter.
#77
I am not sure it is a replacement, I think they are two different offerings....one for those who need / want an all in one design (170A) and another for those looking for a component (171A).
#78
Well, I apologize from cross posting as I did create a new thread with this question but this may be a better thread for my question:
I am buying a set of 171As for my front doors and I am keeping my stock amp and head unit. Should I install the Alpine crossovers or use the stock set up? I have read that the signal is split at the amp so the crossovers will not do anything. Is that true?
What's your advice?
Thanks in advance.
What's your advice?
Thanks in advance.
#79
I recall reading that the front speakers signal is crossed over in the amp so the front high freq. is sent to the tweeters in the dash and the rest is sent to the front door speakers. If you install a crossover after the amp for the front doors it will not do anything to the signal for the front doors and, worse, you won't get the high freq. out of your crossover because they are not there to begin with. IMHO if you want to keep the stock head unit and the stock amp then you should just do a straight speaker and tweeter swap and not add any crossovers.
#80
The tweeteres are driven from a a different channel in the stock amp, and, again the amp handles the crossover. You do not want to add the alpine crossover to the factory amp.
Enjoy though...let me know how the tweeters sound. I started this thread way back and am still looking to upgrade the dash tweeters.
