add a sub to factory bose system
Old Aug 27, 2003 | 07:00 PM
adoshi19's Avatar
hey guys, is it possible to add a sub to the factory system and if so which would you suggest, and how do you install it? need to get some bass in that car!
Old Aug 27, 2003 | 07:15 PM
paper1122's Avatar
A-CL Fanatic
You just need to get a line out converter, and tap into the wires going into the bose amp in the trunk, then run ur power, ground, and remote(also taps into bose amp) It all depends on how much you want to spend, I shopped around and got a used amp off someone here, and managed to do whole thing for $200 not including wires, it does the job for me.
Old Aug 28, 2003 | 03:47 PM
cartan's Avatar
Swim Bike Run...
I bought the CableLink from www.linkmeup.com to provide the line output from the head unit. Then I ran the wires to an Infinity Basslink in the trunk. It does the job of adding bass to the stock system and doesn't take up too much room.
I bought the basslink off ebay (new) for about $200. The CableLink was around $45, and the rest of the wires were around another $40 from Best Buy. This total solution cost me right around $300. I think it does a nice job of rounding out the stock system, if that is all you are looking to do.
Old Aug 29, 2003 | 10:08 PM
uncald4's Avatar
Former Sponsor
DIY?
Are you gonna put this in yourself? This is not an easy task in this car. The CableLink and Infinity sub are your best option. Quite a bit easier to install. Using a line-out converter is good. But I have a better way to boost your amp output.
Old Aug 30, 2003 | 04:58 PM
fizzle's Avatar
Well, I dunno...
Re: DIY?
And that would be... ???
Old Aug 30, 2003 | 09:03 PM
bryand178's Avatar
does any body who used line out converters get engine noise?
I get really bad engine noise/whine after I got the signal from the low level outputs from the head unit ... especially when I turn on the A/C.
oyayjoe
Jan 1, 2019 10:17 PM
TLDude876
Dec 28, 2016 03:18 PM
scionxb3003
Oct 2, 2015 05:50 PM
Sep 17, 2015 09:01 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
