6 1/2 inch spkr ??? for 99 TL
ok..im upgrading my speakers in my 99 TL i know its 5 1/4 all the way around but i want to go with a 6 1/2 comp front and 6 1/2 in the rear..im thinking it should work ..but just wondering if anyone has upgraded to that size in there ride..im goin for the new db series polk there not that deep so im thinking im cool..just need reassurance before i purchase..thanks for any feedback...
Alot of 6 1/2's will fit with modification and/or a spacer. If you are going with a coaxial similar to the DX, you could get away with a direct replacement with no mods. Most speakers are different so, you would just have to try it and see. Or let us know exactly what you are putting in and see if anyone has done that. I personally have Diamond Audio S600 in the front doors. Made a aluminum spacer and did slight(very slight) trimming of the metal door panel.
if you install new speakers and keep the bose headunit..yes my friend you will have to do some rewiring to bypass factory amp..personally i wouldnt change mine till you have a new headunit..thats what im waiting to do so i can switch it all over at once..cause im also putting a new sub in the car cause the lil bose sub just aint doin it for me...oh and AcuraX2 im goin to go with the db6500 61/2 comp. set..and db650 for rear doors..solobaric L712..and a KVT-911 excelon screen..but anyways peace out for now...
Also back to the original question: yesterday i took the door out and measured everything. using a spacer the same as what is on the factory speakers there is a mounting depth of approximately 3" and the width of the hole is 4" so you will want to keep the mounting depth and the basket diameter within those measurements if you want to keep from cutting anything (keep in mind that won't be very easy)
acuratl26
04-23-2020 07:30 PM
emailnatec
29
09-28-2018 04:27 PM
InFaMouSLink
10-30-2015 09:43 AM
johnpancakes014
09-27-2015 12:58 PM
