2019 RDX Audio Cutting out on Bluetooth Media
Hello!
I was wondering if anyone else has been having this problem. I have a Pixel 3 XL and just got a brand new RDX (yay!) 3 days ago. The only issue I'm running into is even connected to Media on Bluetooth (this doesn't happen on phone calls) the audio will intermittently cut out. It doesn't playe the media, so I don't think it's Bluetooth disconnecting particularly just the audio itself stopping for a second then coming back having missed that second of audio. Things I've tried:
Thank you! |
I'm having the exact same problem with my Pixel 3 XL and my 2019 RDX. My previous phone, Google Nexus 6P never had this problem. I did unpair my Pixel and paired again with the same results. I talked to Google support today and they were basically no help. They checked car compatibility at android.com/auto and the RDX was not there. That site only checks compatibility with Android Auto though, which of course we don't have (yet). My wife also has the Pixel 3 XL so I might see if she has the same problem.
Originally Posted by pqlyer
(Post 16324010)
Turn on Developer Mode
Good Luck! Hope this helps! |
Wow - awesome Alain! That fixed it. I don't know how you tracked down the solution, but thanks very much!
There is a 12/12 system software update (get it via wifi) that purports to fix this, and many other audio system issues. Please report back if if happens again after the update is installed.
Originally Posted by 2DriveHappy
(Post 16350607)
Don't know what could be the issue. You've confirmed you're connected to your home's wifi network with the password and the car shows you're connected to the right network? If so, maybe your signal is too weak outside the house.
