RDX: 2019 RDX Audio Cutting out on Bluetooth Media
Hello!
I was wondering if anyone else has been having this problem. I have a Pixel 3 XL and just got a brand new RDX (yay!) 3 days ago. The only issue I'm running into is even connected to Media on Bluetooth (this doesn't happen on phone calls) the audio will intermittently cut out. It doesn't playe the media, so I don't think it's Bluetooth disconnecting particularly just the audio itself stopping for a second then coming back having missed that second of audio.
Things I've tried:
Thank you!
Things I've tried:
- Unpairing and pairing again
- Uninstalling AcuraLink on my phone
- Factory resetting the car
- Turning the phone on in safe mode to see if apps were interrupting the connection.
- Changing notification settings in the car.
Thank you!
I'm having the exact same problem with my Pixel 3 XL and my 2019 RDX. My previous phone, Google Nexus 6P never had this problem. I did unpair my Pixel and paired again with the same results. I talked to Google support today and they were basically no help. They checked car compatibility at android.com/auto and the RDX was not there. That site only checks compatibility with Android Auto though, which of course we don't have (yet). My wife also has the Pixel 3 XL so I might see if she has the same problem.
Alain Arduain (11-01-2018)
Turn on Developer Mode
- Go to Settings > System > About Phone
- Scroll Down and Tap "Build Number" seven times
- Developer mode is now on
- Go to Settings > System > Advanced > Developer Options
- Scroll down to the Networking section
- Toggle ON "Disable Bluetooth A2DP hardware"
- Restart your phone
Good Luck! Hope this helps!
pqlyer (11-01-2018)
There is a 12/12 system software update (get it via wifi) that purports to fix this, and many other audio system issues. Please report back if if happens again after the update is installed.
I can't seem to get it to update even though my version is apparently from August 2018
Don't know what could be the issue. You've confirmed you're connected to your home's wifi network with the password and the car shows you're connected to the right network? If so, maybe your signal is too weak outside the house.
CJ455
3G RDX (2019+)
93
07-23-2021 11:37 PM
Shane One
15
07-23-2019 08:59 PM
sxk101
3G RDX (2019+)
68
10-30-2018 11:56 PM
phineasboggs
10-18-2010 05:51 AM
