20 pin connector question
Professional SLACKER
I noticed that there is one 20 pin connector on the HU and one on the amp.
Are the pin config the same on it? Sorry for the confusion.
Rep'n Taxbrain.com
I don't think they are the same. I think he's trying to install the Parrot Bluetooth kit.
I'm thinking he is trying to splice into the speakers inputs going into the amp so that the kit can mute the car stereo.
The pin diagram that I got from this forum is for the radio unit.
I tried to look all over the forum and online to get confirmation but no luck.
I don't wanna get electricuted while splicing and dicing this sucker.
VP Electricity
1 Post
With 12V?
There are amp wiring pinouts all over the place... check post #3 here:
https://acurazine.com/forums/showthr...ht=TSX+diagram
Originally Posted by elduderino
With 12V?
from that diagram .. whats the shielding wire for??? and the Driver's (-) and (+) makes up the front left channel RCA if an RCA is connected to it?
VP Electricity
1 Post
They wrapped an extra noise shield around all four of the signal pairs. According to the manual this shield is only grounded at the amp end (standard noise shield practice - make the ground the drain at the downstream).
In the installs I've done it doesn't matter if the extra shield is grounded or not. Theoretically it should be taken to chassis ground, but it doesn't hurt anything if it isn't, as far as I can tell. The times there have been noise grounding those wires did not help at all, and lifting the ground did not ADD noise.
so let me get this straight ..
The two shielding wires aren't really useful
Driver's (-) and (+) makes up Front Left RCA
Passenger's (-) and (+) makes up Front Right RCA
Right Rear's (-) and (+) makes up Right Rear RCA
Left Rear's (-) and (+) makes up Left Rear RCA
B7-YEL/GRN-Audio Unit makes up the Remote Turn on wire
Is that right?
Is that right?
VP Electricity
1 Post
1) As the diagram clearly shows, there are four shielding wires, not two.
2) I was going to say that you don't need me to tell you what the diagram says...
honestly, if you use signal (+) for the center, use signal (-) for the RCA shield, and either ground or float the factory shield wires, you're fine. You can read the diagram as well as I can, you can figure out L and R and F and R as well as I can, read it, learn it, love it.
Let us know how it goes.
oh ok .. haha for a moment there .. the way i read it .. i was like + for center .. where the center at on the diagram .. i swear .. communication can be such a pain sometimes ..
but hey .. thanks for the clarification eld
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 09:00 PM
