04 TSX Radio Harness (non-navi)
Is there a way to access the wire harness for the radio without having to remove the whole radio unit? Motorola came out with a T-connection for their wireless bluetooth system and you need to connect it to your radio harness in order to use the auto mute feature.
You can access the harness that connects to the stock amplifier, should have the wires you need.
All you gotta do for that is remove the upper storage bin (right under the radio) by pulling out on it. You should be able to see the amp (small black box) with 2 harnesses going into it (one for signals from radio, other going to speakers).
I would recommend taking out the rest of the center console though (storage bin/shifter/Not An Ashtray)_ to give you more room to work comfortably.
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
jdmaszfcuk
10-19-2015 12:31 AM
xsilverhawkx
09-28-2015 06:51 PM
