Support Question: Signature only showing on latest post
Old 06-30-2017, 09:44 AM
Received 8,584 Likes on 6,630 Posts
@IB Jason,
I'm not crazy and this used to be a setting you can toggle from vB options right? A few people have asked about them not seeing their signatures anymore. I recall that there used to be a "show only on latest post" option but couldn't find it anymore.
Backend change?
@Majofo first brought it up
Old 06-30-2017, 10:11 AM
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
I noticed this recently as well. Haven't figured out the pattern, but sometimes the signature block is there and sometimes it isn't.
Old 06-30-2017, 10:59 AM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Jason replied to my PM about this on 06-03-2016. Yes, it has been that long.
Originally Posted by IB Jason
The "Signatures Only Shown Once" option was actually powered by an entirely separate plugin, one that hasn't been updated in years and unfortunately wasn't compatible with the latest vB upgrade we performed. As such, we had to remove the plugin in order to proceed with the update a few weeks back.
You still have control over whether you choose to see signatures or not, but we no longer have a way to display a signature once. Sorry!
Old 06-30-2017, 11:03 AM
NBP04TL4ME's Avatar
Ron -
That may be the case but something has changed more recently and as I mentioned above the signature block showing isn't consistent.
PS - It's by no means the end of the world, but it is a change.
Old 06-30-2017, 12:27 PM
Administrator
Ron A's Avatar
Ron -
I can't explain that, and you might need to furnish specific examples for Jason.
He should be replying soon and maybe he can shed more light on your problem.
My reply was more for thoiboi's question.
Old 06-30-2017, 12:35 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
It's hard to furnish an example as the signature shows up seemingly at random; one moment a post will have it, come back to the thread, the post doesn't have it; come back to the thread again and the signature has returned.
Edit: looking at this new post I see my signature, for the moment.
Old 06-30-2017, 12:42 PM
I only see it once... but i remember setting that option a while back.. sounds like I was grandfathered in somehow?
Old 06-30-2017, 01:22 PM
NBP04TL4ME's Avatar
I see my signature in post #2, but not in #4. And have have done nothing with any of my profile settings in quite some time.
***Edit - as an aside, if I use the "Go Advanced" function to preview my post my signature block is there, but when I actually submit - it's not there.
Old 06-30-2017, 01:24 PM
Latent car nut
horseshoez's Avatar
I see it in #2, but not in #4 or #6.
Old 06-30-2017, 01:25 PM
NBP04TL4ME's Avatar
So I just did the edit above and my signature block was not there - and after submitting the edit it's there
Old 06-30-2017, 01:44 PM
Administrator
Ron A's Avatar
I should have let Jason answer this and saved myself a goof.
It must have gotten fixed somewhere along the line and I didn't notice it so I checked and it's working for me in other threads since I never changed my option to see signatures only once.
That's the way it's working for me in this thread also.
I only see your signature once also so don't know what you meant by after the edit it's there.
Old 06-30-2017, 03:24 PM
NBP04TL4ME's Avatar
Ron -
Not sure what to tell you. Now I only see it once as well. After I edited my post above(8), my signature block was there - now that I come back to this thread it's not there. I guess I would need to start taking screen shots to prove I'm not loosing my marbles. I'm not going to loose any sleep over this but something has changed is the past week or so and it appears that the view changes depending on when you look at it.
Old 06-30-2017, 03:47 PM
IB Staff
IB Jason's Avatar
Sorry for the confusion this is causing, guys. The PM I sent to Ron was correct at the time: we needed to remove the plugin that powered the option of only seeing a signature once per thread page. In the time since, however, we decided to build that same functionality into the core forum software and that's ongoing. So as a stop gap, signatures are set to one per user per thread page as that was the norm before we killed the plugin.
Old 06-30-2017, 04:31 PM
Administrator
Ron A's Avatar
Ron -
It probable takes the server a little time to set the cookie (or however they do it) so if you do it fast enough you might see your signature in more than one post but by the next time you see it it would have been updated and the signature would only be seen once.
Old 06-30-2017, 04:40 PM
Okay so I'm not crazy . Thanks for the update Jason!
