Zdx reverse wire for reverse sensors
Hi, I'm trying to install a generic reverse sensors but the reverse bulb is on top the tail, you know the cap... So I prefer find the wire near to the cargo o side panels , help!!!!
Your preference doesn't dictate where the wire is located...
The wire need to pass down
The wire need to pass down until de fuse box, so the thing is where is that cable
I believe the wiring harness for the rear end is located behind the passengers side storage compartment at the rear of your ZDX. You'll need to remove that entire storage compartment, just Google trailer hitch wiring to see what I mean.
Better yet, look here: https://acurazine.com/forums/acura-z...ensors-918542/ |
and i found the original box near to side panels, i plugged in there the generic box
