ZDX 2010-13 High Oil Consumption
FYI...
NHTSA Reference #10086261 - TSB Reference #BPAS09152016902 Sent on 09 15 2016 From Parts and Service Division Subject Request for Parts: 2009-2014 MDX, RL, TL & ZDX Engine Oil PRIORITY/ACTION REQUIRED To: All Acura Service Managers/Consultants From: Technical Research & Support Group RE: Request for Parts: 2009-2014 MDX, RL, TL & ZDX Engine Oil This message is solely directed to Acura dealership personnel; please handle accordingly. Print this iN message and provide a copy to the Shop Foreman and all Service Consultants. Background American Honda (AHM) is investigating certain 2010-2013 MDXs, 2011-2012 RLs, 2009-2014 SHAWD TLs & 2010-2013 ZDXs with a client complaint of higher than expected engine oil consumption. To fully understand the cause of this condition, AHM would like to collect specific parts from the vehicle prior to you attempting a repair of any kind. Qualifiers AHM is interested ONLY if the vehicle meets the following requirements: 1. 3.7L engine only. 2. Mileage must be between 50,000 & 150,000 miles. 3. Must have an oil consumption complaint. 4. Previous oil change must have been done at the same dealership. 5. No sign of oil leaks. 6. No history of major engine repair. 7. No need to conduct oil consumption test prior to calling TRS. Action Required If you have or know of such a vehicle, please call Technical Research & Support (TRS) Group at 800-880-1072. TRS will need to record certain vehicle information and provide you with further instructions. |
I didn't know the ZDX had consumption issues also.
I mean, it makes sense if they used the same engine out of the 4G TL... I just haven't heard about it. |
The engine codes are different for the 4G TL and the ZDX. But at the heart of the matter is the 3.7L J37 engine. I need to delve into this further. Acura replaced the short block in my 2010 6MT TL. I was not aware of engine oil consumption issues with the J37A5, but does not surprise me either.
My 2010 goes through about 2 qts every 1k-1.5k miles. I use the OEM filter, but don't have the dealership do the oil changes as I am roughly at 79k and capable of doing them myself.
Any idea what exactly they are going to do at this point? I see they collect parts, but what? Wonder if this could have a long term recall performed if they discover an issue, just like the struts. |
Originally Posted by crashp3
(Post 15929503)
Any idea what exactly they are going to do at this point? I see they collect parts, but what? Wonder if this could have a long term recall performed if they discover an issue, just like the struts. Remember, the squeaky wheel gets the grease. |
(Post 15929503)
Any idea what exactly they are going to do at this point? I see they collect parts, but what? Wonder if this could have a long term recall performed if they discover an issue, just like the struts. And I am now back to checking oil every other Sunday on the ZDX. Have not done that yet for the ZDX and am approaching 3K miles since the last oil change. My service manager at Acura of Omaha is probably not going to be thrilled with me IF the J37A5 in my ZDX is burning oil. I will post my oil monitoring results here. |
[QUOTE=crashp3;15929503]My 2010 goes through about 2 qts every 1k-1.5k miles.
Wow. I've owned Hondas/Acuras for so long now, I have gotten completely out of the habit of checking oil regularly. My ZDX is about due for an oil change (every 7500/highway miles) so I should likely make a note to check the dipstick this time before I drain it! |
I had an appointment set up with my independent Honda/Acura mechanic for a 3K oil change and tranny/rear diff fluid check. This will be my first service since buying it at 59,638 miles on 11/26. I'm going to cancel that and call my service manager. My 2010 6MT TL had this issue and Acura replaced the short block. Treating the symptom and not the cause unfortunately. Maybe I can help the research effort. I love the J37. So I'm in. For the record, the oil was changed at 59,603 miles and I have NOT checked the dip stick to this point. I am at 62,100 miles as of today.
I too have owned many Hondas and some Acuras and never worried about checking the oil. Didn't have to, really. Until the 2010 6MT. Time to check the ZDX. |
[QUOTE=dynodan;15930534]
(Post 15929503)
Wow. I've owned Hondas/Acuras for so long now, I have gotten completely out of the habit of checking oil regularly. My ZDX is about due for an oil change (every 7500/highway miles) so I should likely make a note to check the dipstick this time before I drain it! Anyone know the details re: any other 3.7L recall issues (specific mechanical faults)? |
(Post 15929503)
Any idea what exactly they are going to do at this point? I see they collect parts, but what? Wonder if this could have a long term recall performed if they discover an issue, just like the struts. I see that your TL is a bit older, but, that's crazy high oil consumption nonetheless. How long ago did your TL start consuming oil like that? Honda/Acura stipulates something like 1qrt per 1000 miles warrants an engine replacement. I'd call Acura Customer Relations nonetheless. Your car isnt that far out of warranty to be having issues THAT severe. Oil consumption is generally not a progressive problem. It's either there, or it's not. If you're burning 2 quarts in a 1000 mile period, I'd be super pissed off. |
Originally Posted by HondaOwnerForLife
(Post 15930550)
What about the struts? Did I miss a thread somewhere?
(Post 15929503)
Originally Posted by con5tant
(Post 15931040)
Very offtopic, but I found it interesting that I bought my ZDX on the same day as you lol
https://cimg9.ibsrv.net/gimg/acurazi...8cfd8a04ca.jpgAfter adding approx. 3/4 QT of Mobile One
https://cimg0.ibsrv.net/gimg/acurazi...908faa37d1.jpgI was expecting worse based on the consumption in the 2010 6MT TLDateMilesMiles Since Last Oil ChangeActionNotes1/9/201662,0962,493Checked engine oil volume.See pics. Added approx .75 quart of Mobile One (3/4 qt) |
Sorry my formatting skills need work. The above looks better below:
Date: 1/9/2016 Miles: 62,096 Miles since last oil change: 2,493 Action; Checked engine oil volume. Result: See pics. Added approx .75 quart of Mobile One (3/4 qt) |
(Post 15932213)
I spoke with my service manager today. He's the Service Manager at the lone Acura dealer in Nebraska. I simply called him to give him a heads up so that when he receives my documentation, he's not surprised/confused. He's a true customer advocate based on my experience with him over the years. He managed the oil consumption issue in the 2010 6MT TL such that I never had to deal with Acura corporate at all. He indicated that he's aware of the memo from AHM. He conveyed that in his experience, they seek J37 vehicles close to the plant in Ohio or close to Corporate HQ in California. Be that as it may, he advised to send him my documentation. I will have the oil changed on Monday the 16th. He asked whether or not I suspected a consumption issue with the J37A5. I provided the detail above. Of course we are both aware of the corporate stance here:
1 QT consumed over 1,000 miles is considered normal. The 6MT TL consumption was worse than what I have observed so far with the ZDX's J37A5. I am not seeking another short block replacement. That's a "symptom" fix and not a "root cause" fix. I simply have another J37 and want to participate in the investigation, if American Honda Motor Corp desires participation from a willing J37 owner. I am a fan of the J37. I like having it under the hood and love the "rumble" when it ignites. |
1 QT consumed over 1,000 miles is considered normal [/QUOTE]
My Integra never burned any oil (even at 250K), nor either CRX. This is my first large Honda motor, so maybe there is something about size/more cylinders that comes with oil consumption (?). My '55 Ford 292 c.i. V-8 uses a quart every 1000 also. If checking/adding oil occasionally is the price you must pay for more power, then I'm fine with it! |
Any pics of that old Ford? I am of the opinion that the problem is with the piston rings or the cylinder wall lining, or the combination of both in the J37. Agreed. Regardless of any fix, or lack there of, I am keeping this J37 and the platform it powers!!!!
(Post 15933239)
BTW: I once paid a dealer mechanic to fix a leaky cam plug on my Integra at 150K mi. when I could have just added a few quarts of oil over time instead. Lesson learned. Acura dealers are quite distant, so I wouldn't even waste the trips (doubled with a loaner) to have the engine disassembled/repaired to keep me from having to top of the crankcase occasionally. |
Provided ALL documentation to my local Acura service manager. Had the oil changed on the 16th of January for the first time since owning the "White Whale". Will check oil volume every Sunday. Simply in monitor mode until the next oil change.
I changed my oil around Jan of this year, checked dipstick yesterday and it was completely dry, there wasn't even oil at the very bottom of the stick (I forget the number of miles driven but less than 6k)....No wonder the low oil warning popped up every once in a while when I slammed on my brakes...
Update: I've put 9,000 miles on the 2010 ZDX and change the oil every 3,000 miles. My consumption is below:
1st 3K mile change: 3/4 QT low at 3,000 miles 2nd 3K mile change: 1 QT low at 3,000 miles 3rd 3K mile change: 1/2 QT low at 3,000 miles I have the oil changed at the dealer so that I and the Service Manager can document the consumption. So far, I am not concerned. The 2010 6MT TL consumed oil at a much higher rate and Acura, because I had documentation and a customer-focused Service Manager, replaced the short block. I don't experience inordinate oil consumption with the ZDX at this time, but will continue to monitor and document. My 2006 CRV consumes more oil than the ZDX at this point, but in part that's because my daughter knows no other starting method than the jack rabbit start!! |
My 2010 ZDX with 83,000 miles showed a low oil alert on my gps display yesterday. thankfully i was on my street heading home when it happened but i was 4qt's low and changed my oil 4k ago so i will be calling acura tomorrow to schedule an oil consumption test. ill update everyone with the findings and repairs.
Update with exact mileage:
1st oil change: 2,493 miles and down ¾ QT 2nd oil change: 3,006 miles and down 1 QT 3rd oil change: 2,675 miles and down ½ QT 4th oil change: 2,949 miles and down 1/3 QT |
TSB 18-009 - Engine Oil Consumption Exceeds Client Expectations was released for the 2010-2013 ZDX.
https://acurazine.com/forums/fourth-.../#post16202099 |
(Post 15928764)
Thanks! |
Originally Posted by felixangelov
(Post 16239949)
Was the process of replacing the short block on the TL easy, or did you have to escalate it with Acura?
Thanks! The 2013 ZDX is going on an oil consumption test starting Monday June 11th, 2018. I added between 1/3 and 1/2 QT since last oil change, at about 2K miles after the last oil change. Just want to get it on record via completion of the Acura oil consumption test. |
The 2013 ZDX is now on the oil consumption test. I'll post details at the 1,000 mile mark.
Go figure. At 40K mi., my oil consumption has suddenly slowed significantly. If this was the 50s (when engine builders typically used chrome rings), I might assume delayed break-in (?). |
Oil consumption
hey everyone new this place, bought a zdx last year with 98000 km in Canada. Found out it burns about 1 litre every 1500 km. has anyone had the pistons and short block replaced and found that it helps. The last update with the service bulletin was posted in June which is recent. Any thoughts on whether I should repair it or trade it in? The dealer is pretty nice and understand that this oil consumption is no fault of my own and is offering a trade.
Personally I'd work with the dealer, or trade for another ZDX. I am too much a fan of the ZDX to recommend parting with it, unless for another ZDX.
Im waiting for another zdx in his used car lot. In the mean time I'm gonna get him to convince acura canada to do the job. I agree that I really don't want any other car for the price point I paid. Ill post my updates as well with the engine repair.
(Post 16247413)
First check today at 1,000 miles even: No oil added. Read right at the full line per the tech and the service advisor, as I spoke with both. Will see what it reads at the 2K mile mark.
Stupid Acura Canada says my warranty is over, but my dealership if fighting for the repairs. If they repairs won't be covered by Acura Canada then I guess Ill have to sell the care back. Hopefully the dealership gives me my money back at a fair price. Ill let you guys know what happens, anyone else have issues with Acura Canada?
No, Canada sucks
Engine Warranty Extension
https://cimg0.ibsrv.net/gimg/acurazi...604a838b8.jpeg
Came in the mail yesterday...Due to oil consumption Acura extended the power train warranty for 8yrs or 125,000 miles! |
Yeah, I got the letter as well, though I don't have any consumption issues.('13 with 55000 Miles)
Originally Posted by lumpulus
(Post 16388300)
