Sizing
Old 04-19-2017, 03:04 PM
ppsevere's Avatar
Sizing
would anyone be able to tell me if I would be able to fit 285/60R20 on my ZDX???if so what would the offset need to be?
Severe
Old 04-20-2017, 09:23 PM
zdxsr's Avatar
Here's one of the better wheel and tire size calculators on the web.
https://www.wheel-size.com/calc/
Old 04-24-2017, 03:30 PM
J37A5
HondaOwnerForLife's Avatar
I am pondering summer wheels and tires myself. Looking at a 20 X 9 wheel with a +38 offset. Offset for the OEM optional 20 inch wheel is +45. Below are the specs for the optional OEM 20 inch wheel. I am not looking to procure the OEM optional 20 inch wheel. I am looking at a KMC wheel that I really like. The KMC wheel is a +38 offset and is 20 x 9. Not sure if the ZDX could handle, fitment-wise, the 20 X 9.5 wheel. I think the 9 inch will suffice, but need to be sure it will fit first!!ALY71798 Acura ZDX Wheel Chrome #08W20SZN200Make/Model/Year:Acura ZDX 2010-2013Product Specifications:
Product ID: ALY71798
Product: Wheel/Rim
Material: Aluminum
Style: 12 Spoke
Finish: Chrome
Lugs: 5
Bolt Pattern: 120mm
Offset: 45mm
Indents: SZN20090A, 08W20SZN200
OE Part Number: 08W20SZN200
Old 04-30-2017, 04:44 PM
monolith's Avatar
I think up to 285/50R20's will fit. You will probably get some rubbing during sharp turns when parking. 285/60R20s on the front will hit the back part of the inner wheel well when you turn the steering wheel. I just put 285/40R20's on my ZDX and there is only about an inch to go bigger in diameter before contact. I used 10" wide wheels with an ET40 offset. The recommended offset for a 20x10 wheel is ET35 from this site - https://www.wheel-size.com/size/acura/zdx/2010/ - I would stick with the ET40 to keep the wheel in closer to steering axis so it swings less front to back when you turn the steering wheel.
Old 04-30-2017, 11:59 PM
xxx_busa's Avatar
I believe that inner wheel cover is to be under the painted molding pieces, It fit better and wont buckle like the picture shows...
Great Look ride.... I have a 2013 with 19,500 on it. Black on Black,,,,,
Coils Springs dot com now has all the sample to make springs, I just received my -1.5" from them, will post here once I've installed.
LOOKING GOOD !
Old 05-01-2017, 09:07 AM
monolith's Avatar
Thanks and good catch on the wavy inner fender liner xxx_busa - I did not even notice that until you pointed it out. Both sides are wavy like that. I will get under there and remove the screws and see if I can tuck the liner behind the fender lip and lower trim. It is interesting that there are screws holding it on instead of the typical plastic push pins. I guess this is how it came from Acura - carfax was clean so I don't think it was repaired.. Anyone else care to share pics of their inner fender liner?
Old 05-01-2017, 10:37 PM
zdxsr's Avatar
Originally Posted by monolith
Actually, there was a TSB out there for the problem.The inner fender wells warp. I had both fronts replaced in 2014 and they added a stiffing brace that prevents the new ones from developing the same problem.
Additionally, the inner fender wells mount on the outside a quarter of the way up in the rear, then transition to the inside for the rest of the way around the wheel well.
Old 05-05-2017, 08:37 AM
J37A5
Still thinking and pondering......Now looking at a set of KMC wheels: 20 X 10 with a +40 offset. Using resources to help me determine if they will fit without rubbing/obstruction. Feedback and suggestions welcome.
Old 05-07-2017, 04:42 PM
AGENTCOZ's Avatar
Hey guys, the wavy fender is correct, Acura says its caused by heat. I tried getting it covered umder warranty, since that's regular use stuff. DENIED. There is a service bulletin on it that requires some sort of stiffener and a decent amount of $. GREAT IDEA, to tuck umder the fender if that's possible. Can anyone confirm if it works, and maybe post a pic?
Thanks!
Old 05-17-2017, 12:24 PM
monolith's Avatar
Quick update: I am getting some rubbing of the right front tire with my 285/40R20's when going around left bends on hilly roads when the right side suspension compresses. I am not sure where it is hitting yet, I am going to put some small pieces of painters tape on the fender lip and in the wheel well to see if i can locate where it contacts. I think the 285/50R20's might be a bridge too far...
Old 10-05-2017, 11:36 AM
monolith's Avatar
So after alot of checking and head scratching, I concluded there is no tire rub at all with my 285/40R20's. The traction control is kicking on prematurely (I can see the light flash on the dash) which makes a noise in the right front and also slows the car down a bit so it feels like a rub. I guess the Acura folks who tuned the traction control want me to slow down a bit. It only seems to trigger when there is an elevation change during the corner....
I started shopping for winter tires and would like to get something agressive looking. I may use the stock 19x8.5 rims. Any thoughts on max tire size for those rims? A taller sidewall from the 255/50R19 would be cool.
cl-lites
04-05-2004 08:59 AM
Quick Reply: Sizing
