Parking lights/taillights not working
I installed LED fogs, DRL and turn signals today and when I went to try the signals, only the passenger side worked. Upon inspection, all the blinkers (front,mirror,rear) on the drivers side, parking lights and taillights (driver and passenger), and both front sidemarkers did not work. Anyone experience this before? Which fuses or relays should I be looking at?
You may have flipped the polarity on one of he bulbs
you installed your turn signal LED backwards.
LEDs are polarity sensitive. So installing it reversed won't work.
Also your blew your fuses bevause your shorted the circuit while installing the bulbs. Be careful or be safe and unplug the battery. Worst case scenario: you can get your MICU.
Each other meaning what?
con5tant (03-28-2017)
