Help with door panel '12
The drivers door panel had this damage when I purchased. They said 'it just happened'
IDK but I do want to fix it. http://www.pbase.com/robpp/image/167881295/large.jpg in this one you can see the LOWER part of the door panel is gray :i miss PB :( http://www.pbase.com/robpp/image/167881223/large.jpg I checked car-part for salvage....there is a '11 but part number on door panel is different part is available through acura Im just not sure what color to order. They have 'black' and 'gray' my interior is Taupe according to window sticker. Door panel seems to have both black on top and handle. and gray lower part. and its called LOWER so iMA thinking its the gray. There are some screws so most of the components might screw on but I have done some plastic welding and recovered some door panels so I not too scared to try and reconstruct. Link to parts page. Its 20 and 30. |
heres a better picture. id rather not remove the door panel just to get the part number/
my interior is called taupe. so is this door panel GRAY OR BALCK TIA https://www.pbase.com/robpp/image/167895635/large.jpg |
It would be the grey one, as it states (lower)-(medium grey). The lower color on the door panel is grey. I guess they call it taupe on the window sticker because it sounds classier (richer).
Originally Posted by zdxsr
(Post 16275139)
http://www.pbase.com/robpp/image/167999604/medium.jpg |
Its not 'just happened', its previous owner was driving with elbow leaning on this panel
so be careful with new panel)
Originally Posted by robpp
(Post 16271953)
IDK but I do want to fix it. https://www.pbase.com/robpp/image/167881295/large.jpg in this one you can see the LOWER part of the door panel is gray :i miss PB :( https://www.pbase.com/robpp/image/167881223/large.jpg I checked car-part for salvage....there is a '11 but part number on door panel is different part is available through acura Im just not sure what color to order. They have 'black' and 'gray' my interior is Taupe according to window sticker. Door panel seems to have both black on top and handle. and gray lower part. and its called LOWER so iMA thinking its the gray. There are some screws so most of the components might screw on but I have done some plastic welding and recovered some door panels so I not too scared to try and reconstruct. Link to parts page. Its 20 and 30. |
NEW:
http://www.pbase.com/robpp/image/168047692/large.jpg OLD: https://www.pbase.com/robpp/image/167881295/large.jpg |
