Toyo Proxes T1R's 235 45 17 With 17x9 Rims
Hello everyone, I'm new to the wheels and tires. Im planning on getting Toyo Proxes T1R's 235 45 17 tires on my MB Battle 17x9 rims. Do you think the fitment will workout?
Originally Posted by Winson C
(Post 16367470)
(Post 16367476)
What are the specs of the wheels you're planning on using?
(Post 16367491)
Im not sure whats my offset, all the original owner told me that it was 17x9.
(Post 16367470)
What matters is your drop and clearance within the wheel well to prevent rubbing/touching of the suspension components or fender liner. Knowing the offset would definitely help with that. |
Originally Posted by nats007
(Post 16367710)
I assume the wheels are already on your car... If so, then for 17x9, 235/45r17 should work. Many run 245/40r17 as well for a square fit. Some run 255 if you want the meaty tire look.
https://cimg1.ibsrv.net/gimg/acurazi...16b5d394d3.jpg
BTW this is my car. |
(Post 16367755)
(Post 16367756)
Clean bro! Then I recommend you run 245/40r17 then
