Notices
RSX surging Problem Please Help!
Old 06-22-2019, 08:02 AM
Registered Member
I have a 04 RSX and I have surging problem at Idle I have changed the Vtec Solenoid and Did a valve adjustment !
It still surges anyone know how to fix please thank you!
ThatCL is offline
Old 06-24-2019, 01:36 PM
Registered Member
Clean your Idle Air Control Valve (IACV) underneath the throttle body. The IACV internals should spin freely. Use Brake cleaner to clean it out and you may have to do it several times until the it spins freely removing all the build up. Also, double check and make sure you do not have any vacuum leaks as that will cause surging idle as well.
nats007 is offline
Montaigne
03-14-2017 10:59 PM
NedShneebly
07-09-2009 05:43 PM
I hate cars
09-24-2007 08:08 PM
socalyaser
06-07-2006 07:40 PM
Clman02
First Generation CL Discussion (1997-1999)
14
04-14-2005 01:06 AM
Quick Reply: RSX surging Problem Please Help!
