Go Back  AcuraZine - Acura Enthusiast Community > Acura RSX Community > Acura RSX Discussion
Reload this Page >
RSX Shifter Bushing Repair DIY Instructions
Notices
Old 05-28-2018, 07:23 PM
Acura Fanboy
knavekid's Avatar
If your cable shifter has a lot of play fore and aft, its bushing has deteriorated and there is no part from Honda to repair it unless you want to replace the shift cables. This DIY repair replaces the bushing in the existing cable.
Noisy shifter with lots of play:
Source of this problem:
First, you need to get a replacement bushing to fit the shaft and cable end. I measured the shaft diameter to be 0.317”. The inside of the cable end is 0.394” and its width is 0.235”.
The bushing size needed is 3/8” outside diameter and a 5/16” inside diameter by about 1/4" wide. I purchased some 3/8” diameter Teflon PTFE tubing with a 1/4” inside diameter and drilled it out to 5/16”. I then used a plastic washer between the shaft mount and the cable end. The tubing I used is no longer available from the supplier. However, if I were to do this again I would purchase one of these bearing components:
https://www.mcmaster.com/#6627K409
Note that the inside diameter might be a little tight. You can use a drill to open the diameter up a bit or cut it lengthwise to allow it to slide over the shaft.
Once you have the components, follow the steps below:
1. Remove the shift knob by tugging down on the boot ring to disconnect it and then unscrew the knob.
2. Remove the shifter cover. Open the cup holder and tug upward on the shifter cover and then carefully pulling up on the sides to free the retaining clips.
3. The shift cable is connected to a shaft on the shift lever. Rocking the shift lever fore and aft will expose any play in this connection. You will likely see debris from the failed bushing at the base of the shift lever.
Failed bushing.
4. Remove the cotter pin that retains the washer and cable end on the shaft.
5. Remove and inspect the retaining washer which is steel with plastic on one side.
6. Slide the cable end off of the shaft and wipe off any debris from the shaft and inside the cable end.
Disassembled.
7. Slide the plastic washer onto the shaft followed by the bushing. If using a flanged sleeve bearing like the component from McMaster-Carr, slide the bearing onto the shaft flange-side first.
Parts.
Parts installed on shaft.
8. Apply some lithium grease to the bushing and then slide the cable end onto the shaft.
Grease applied.
Cable installed.
9. Apply some lithium grease to the side of the cable end and slide the retaining washer onto the shaft, plastic side first.
10. Insert the cotter pin and bend the ends around either side of the shaft.
Repair complete.
11. Replace the shifter cover and reinstall the shift knob.
This completes the repair.
No more play:
knavekid is offline
Old 05-29-2018, 08:59 AM
Registered Member
Awesome DIY! Need to do this on my RSX. Thanks for sharing!
nats007 is offline
knavekid (05-29-2018)
Vlad_Type_S
Third Generation TL (2004-2008)
04-05-2014 09:11 PM
vlo421
17
02-03-2013 03:02 PM
ITL
58
06-27-2012 07:27 AM
ivan06106
01-26-2011 03:35 PM
GSGOMEZ
11-08-2005 12:23 AM
Quick Reply: RSX Shifter Bushing Repair DIY Instructions
