Broken driver's side lock
The lock on the drivers side of my 02 RSX won't respond to my remote key. I have to manually unlock the drivers side, then click the remote which will then unlock the passenger door and the trunk. I have a feeling it is just jammed. Is there an easy way to take off the door panel? I have tried once before, but can't find one easy way to do it...
Acura Fanboy
If you do a web search on Ab0VE Acura RSX Service Manual (Ab0VE with zero instead of O), you should find a version of the RSX service manual that you can download. This will have instructions on removing the door panel and replacement of the door lock actuator.
rockyboy
12-06-2022 02:29 PM
acura_dipset_tl
01-01-2016 03:02 PM
