2005 RSX Weird Braking Issue
So first off I don't know much about cars so I apologize in advance if this question is daft...
I have a 2005 RSX-S with about 126K miles. Today while in traffic I put it into neutral while holding the brake down and the car started rolling backwards... I even pulled the E-Brake but it didn't stop the car from rolling backwards... I almost hit the car behind me.... The only thing that stopped it was when I put the car into 1st gear....
After about 10 mins of this behavior the brake starting working again and I could put the car in neutral while holding the brake down both with and without the clutch pushed down and the car would be stationary.
I had this happend one other time to me about 3 months ago in the parking lot but I thought it was an anomaly of some sort or I did something wrong since it didn't happen again afterwards.
Does anyone know what the problem might be here?
The brake pedal had pressure but it wouldn't stop the car from rolling back. I am not sure about going forward as I only experienced this on an incline. There was too much traffic for me to test it. It feels like I had no way of making the car stop rolling back.... Even the e-brake didn't work... granted it was rolling back slowly. Felt kind of like a ghost was moving the car
Acura Fanboy
If the power brakes lost vacuum, I could see how putting the normal amount of pressure on the pedal might not stop the car. But at idle, manifold vacuum is highest, so this shouldn't be the cause. The e-brake mechanism is separate from the pedal and should always work unless way out of adjustment.
I can't imagine an intermittent condition that could compromise both the regular brakes and the e-brake.
The following 2 users liked this post by knavekid:
justnspace (05-28-2015),
RomeWashington (05-28-2015)
It seemed like the only way to stop the car was putting into gear and then stepping on the brake.
Thanks. Unfortunately I am hardly a car buff so I am not sure what these are I suppose I should take it to my mechanic though. How much do you think this would cost?
Btw driving my car home from work I did not experience the issue at all. Both the E-Brake and Brake worked fine....
Maybe the car stalled and I didn't realize it? If the car stalled would it still move backwards on a hill with the car in neutral and the e-brake up? This is the only explanation I can think of....
cycdaniel
12-17-2019 10:58 AM
handsom-hustla
11-13-2015 05:04 PM
nuldabz
09-03-2015 05:49 PM
