Hardwiring blackvue power magic pro - which fuses to tap?
Installing power magic with dash cam
If anyone has done this install ilx, where did you tap the red and yellow wires under the dash fuse box? Red is ACC - provides power when ignition on yellow is goes to a fuse that's always on. Black is ground |
just use a volt meter and go find what you need in the fuse box bro. it's easy whats what I did. there are multi points that provide this, and use tap-a-fuse to make thing even easier nuff said
