2013 ILX,synthetic oil or synthetic blend oil?
Either will work just fine in your ILX. Just follow the MM.
Full synthetic oils are pretty cheap to find nowadays, so why not go full synthetic?
Pennzoil has a $2/quart rebate going right now on their full synthetic oils, so probably even cheaper than a blend.
justnspace (01-27-2017)
In the maintenance guide Acura doesn't recommend synthetic oil! Just saying I'm new to the Acura family
Q: I use synthetic oil. Should I expect to get more miles before the Acura Maintenance Minder indicates that I need an oil change?
A: Acura does not recommend the use of synthetic oils in models that do not require them as your Acura was designed and engineered based on the oil recommended in your owner’s manual. The Acura Maintenance Minder calculates your vehicle’s needs based on the oil recommended by the Acura engineers that designed your engine. The use of synthetic oil will not extend the oil change interval.
don't matter.
My MB came with full synthetic off the factory. ICE is ICE, as others have pointed out, full syn is cheap, there's is no reason to go blend.
Great info on the oils specs but when was the last time you you saw your engine temp meter go up to 240 F? You would have b bigger problems before worrying about oil meltdown
Latent car nut
Received 2,005 Likes
SoL_TeK
4G TL Photograph Gallery
49
05-01-2023 04:32 AM
