2016 Acura ILX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2016 Acura ILX Technical Service Bulletins:
TSB 15-002 - 2016 ILX: TQI and New Model Service Information
Applies To: 2016 ILX - All
http://www.urvi.net/forumfiles/SB/B15-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-002.PDF
TSB 15-003 - 2016 ILX: TQI of the Navigation System
Applies To: 2016 ILX - All with Navigation
http://www.urvi.net/forumfiles/SB/B15-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-003.PDF
TSB 15-027 - LKAS Does Not Keep Vehicle in Detected Lane
Applies To: 2016 ILX - All with AcuraWatch Plus - ALL
http://www.urvi.net/forumfiles/SB/B15-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-027.PDF
TSB 16-004 - Front Brake Noise
Applies To: 2016 ILX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-004.PDF
TSB 16-011 - Product Update: Monroney Label (Hawaii)
Applies To: 2015-16 ILX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-011.PDF
TSB 16-015 - Audio Unit Displays Wrong, Blank, or Random Character Presets
Applies To: 2016 ILX - Premium/Technology - ALL
http://www.urvi.net/forumfiles/SB/B16-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-015.PDF
TSB 16-025 - Steering Wheel Noise When Driving
Applies To: 2016-17 ILX - ALL - From VIN 19UDE2...HA000001 to 19UDE2...HA001454
http://www.urvi.net/forumfiles/SB/B16-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-025.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
Applies To: 2016 ILX - Tech - ALL
2017 ILX - Tech - From VIN 19UDE2...HA000001 thru 19UDE2...HA002407
http://www.urvi.net/forumfiles/SB/B17-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF
TSB 17-004 - Safety Recall: 2015–16 ILX and RDX Takata Driver’s Airbag Inflator
Applies To: 2015–16 ILX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-004.PDF
TSB 17-015 - 8-Speed Transmission (DCT) Has a Bump or Hard Shift When Coming to a Stop
Applies To: 2016–17 ILX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-015.PDF
TSB 17-030 - Water Pump Seizes or the Drive Belt Is Shredded
Applies To: 2016 ILX 2.4L - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-030.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-030.PDF
TSB 18-010 - Clunk From The Rear Suspension When Going Over Bumps
Applies To: 2013-17 ILX (except Hybrid) - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-010.PDF
TSB 18-016 - SRS Indicator On with DTC B0090-87
2017 ILX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-016.PDF
TSB 18-021 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2016 ILX and 2016 RDX (Expires February 28, 2026)
Applies To: 2016 ILX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-021.PDF
TSB 19-008 - Safety Recall: ILX Fuel Tank Production Date Inspection
Applies To: 2014-19 ILX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-008.PDF
TSB 19-012 - Knocking or Clicking From Engine During Cold Startup
Applies To: 2016-18 ILX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-012.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-012.PDF
TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized
Applies To: 2013-16 ILX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF
TSB 19-035 - Safety Recall: 2016-19 ILX Driveshaft Inspection
Applies To: 2016-19 ILX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-035.PDF
TSB 20-038 - Steering Wheel Rattles
Applies To: 2016-20 ILX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B20-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-038.PDF
TSB 20-047 - Warranty Extension: B-612P Catalina Blue Pearl or Bright Kinetic Blue Pearl Paint
Applies To: 2016-18 ILX - All vehicles with B-612P Catalina Blue Pearl or Bright Kinetic Blue Pearl paint - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B20-047.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-047.PDF (Link does not work)
http://techinfo.honda.com/rjanisis/p...l Paint v1.PDF (Link works, but is wrong)
TSB 24-008 - Safety Recall: 2016–20 ILX Fuel Pump Motor
Applies To: 2016-20 ILX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-008.PDF
Hawkins21 (01-06-2020)
Fighting with Acura Canada now about the front brakes. Dealer "Camco Acura" in Ottawa, Ontario finally flashed my trans, but never did the relearn, (I know because I watch my dashcam inside and out footage), even that was a bit of fight, and thats where I brought the dam car, they also said I need to call Acura Canada to get approved to fix the front brakes under it's TSB
I'll never buy an Acura again after all this, once this car is gone that's it. No more Hondas
