2013 ILX Fuel Injector
Old 06-16-2017, 05:21 PM
Zubair Khatarwala's Avatar
My car is 2013 ILX Hybrid with 70K miles. is this the time I should get Fuel Injector & Carb cleaned? I am noticing bit low pick up on my car. it is 4 cylinder engine 1.5
Old 06-16-2017, 06:07 PM
Received 16,260 Likes on 11,971 Posts
No. Premium fuel has cleaners and detergents in it. That's all you have to do to keep your injectors happy. Fill it with premium fuel
Old 06-20-2017, 10:45 AM
Chrifff's Avatar
Justnspace, is right.... If you usually don't use premium fuel you can try a cleaner additive and then use premium fuel occasionally. Also this generation is not direct injection, hence keep the ilx in a lower gear and let the rev's hang higher a bit to help burn off anything on the carbs (if there is anything).
