oil leak(pics) help with locating issue
Old 06-06-2018, 02:14 PM
Zeroskillet's Avatar
I’m getting an oil leak by the front motor mount on the left side of engine. trying to figure out what you guys think it might be ?
Old 06-06-2018, 02:16 PM
Received 16,260 Likes on 11,971 Posts
valve cover gasket perhaps?
Old 06-06-2018, 06:33 PM
Iggy's Avatar
^^^ that would be my guess as well
Old 06-06-2018, 08:08 PM
Received 1,732 Likes on 1,390 Posts
It could possibly be a leaky o-ring (#15) around the Front Camshaft Thrust Cover Assembly (#6) on the link below:
https://www.oemacuraparts.com/auto-p...nder-head-scat
Old 06-07-2018, 12:16 AM
Iggy's Avatar
OP. Take the plastic covers off. Spray the whole area with brake cleaner until it's nice and clean then take her for a drive and recheck to see where the leak is coming from. You can keep the plastic covers off to make inspection easier.
Old 06-14-2018, 11:40 AM
MBLiberty's Avatar
Interesting. I'm dealing with a leak in the same general area in the 3rd gen forum here:
https://acurazine.com/forums/3g-tl-p...-block-970154/
Old 07-31-2018, 11:59 AM
Baron Von Zeppelin's Avatar
Dipstick tube lower O-Ring is common leak - and will make a mess all the way across to the transmission.
Will appear as several leaks from everywhere at a glance.
One 10mm mounting bolt on its bracket - hidden in with serpentine tensioner mounting bolt .
[location circled in Red]
Clean lower entry area very well BEFORE removing dipstick tube.
[circled in Green]
I also use silicone above the new O-Ring , on the tube.
After it is installed and bolted , smear another bead of silicone around the entry area.
Let it dry as long as you can wait - preferably overnight.
GOOSEej
11-01-2018 11:17 PM
Fatfrii
06-10-2017 12:57 AM
fabrizzio71
1G CL Problems & Fixes
12-16-2012 04:50 PM
Acura604
11-30-2012 12:11 PM
edsonfire
07-23-2006 07:43 PM
Quick Reply: oil leak(pics) help with locating issue
