"New" Official 2nd Gen TL DIY Thread
Old 01-19-2009, 10:05 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Thumbs up "New" Official 2nd Gen TL DIY Thread
Posted 1 October 2019
DUE TO CIRCUMSTANCES BEYOND OUR CONTROL, MOST OF THE LINKS IN THIS THREAD DO NOT WORK.
It appears that the non-working links were deleted or otherwise corrupted.
There are some that work so we hope that the topic you are interested in is still available. If not, we apologize for the circumstances but there is no way to get it corrected.
Tires/Wheels/Suspension DIY's
Upper Control Arm replacement DIY
https://acurazine.com/forums/showthr...3#post11487963
FAQ Will they fit?
https://acurazine.com/forums/2g-tl-tires-wheels-suspension-100/faq-wheel-rim-size-will-they-fit-580759/
Lowering/Spring Install
https://acurazine.com/forums/2g-tl-tires-wheels-suspension-100/diy-lowering-dropping-your-tl-623631/
http://www.cardomain.com/ride/184466/7
Camber Kit Install:
http://www.cardomain.com/ride/184466/15
Trimming Tabs DIY
https://acurazine.com/forums/showpos...1&postcount=30
Replaceable Sway Bar End Links:
https://acurazine.com/forums/showthread.php?t=191709
Lighting DIY's
Bulb Application
https://acurazine.com/forums/2g-tl-1999-2003-98/bulb-application-614883/
Type-S Gauge Cluster retrofit
https://acurazine.com/forums/showthr...wap+99+cluster
Revers glow gauges DIY
http://files.subtledream.com/TL/reve...low_gauges.htm
Dash Clock Light Replacement DIY
https://acurazine.com/forums/2g-tl-problems-fixes-117/dash-clock-light-out-621510/
Amber to Clear Taillight conversion DIY
https://acurazine.com/forums/showpos...07#post2040881
Ignition Switch Replacement DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-99-tl-ignition-switch-686000/
HID Removal DIY
https://acurazine.com/forums/showpos...24&postcount=2
Ballast/Inverter Repair
https://acurazine.com/forums/showthr...llast+inverter
Projector Retro Fit
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-hid-projector-retro-fit-02-03-headlights-618263/
99-01
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/00-tl-projector-headlight-project-617333/
Lexan Fog light replacement
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-02-03-fog-light-lens-replacement-707132/
https://acurazine.com/forums/2g-tl-1999-2003-98/lexan-fog-light-fix-painted-fog-lights-diy-694354/
DIY Fog lights (99-01)
Accord
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-installing-accord-fog-lights-99-01-tl-corner-pocket-565298/
https://acurazine.com/forums/2g-tl-1999-2003-98/replica-6g-accord-4dr-foglights-diy-612321/
Civic Fog DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-alternate-fog-diy-01-03-civic-fogs-613806/
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-01-03-civic-fogs-99-01-tl-624705/
Fog Light Mod (02-03)
https://acurazine.com/forums/2g-tl-1999-2003-98/fog-light-mod-alternate-version-549015/
Door Handle LED
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-door-handle-leds-613711/
DIY 745 side markers
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-745-side-markers-545900/
HID Fog install
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/3000k-hid-foglight-install-pics-56k-think-again-602180/
Cleared and Painted Housings
https://acurazine.com/forums/showpos...71#post2013918
https://acurazine.com/forums/2g-tl-photograph-gallery-99/cleared-painted-housing-brushed-aluminum-grille-frame-%2Apics%2A-567498/
https://acurazine.com/forums/showthr...=757845&page=2
Headlight Clearing
http://www.cardomain.com/ride/184466/18
DIY Radio LED Retrofit:
https://acurazine.com/forums/ramblings-12/attn-angelcl-186556/
http://www.n4te.com/images/acura/leds/guide/
Window Switch LED
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-led-power-window-buttons-620689/
Headlight Ballast Install:
https://acurazine.com/forums/audio-video-electronics-navigation-22/tv-navi-possible-191816/
Engine/Mechanical/Miscellaneous DIY's
Spark Plug DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/spark-plug-replace-change-diy-760163/
MDX/Pilot intake spacer DIY
https://acurazine.com/forums/showthr...4#post11434934
RDX Fuel Injector Mod
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-fitting-rdx-injectors-into-tl-cl-716741/
Seafoam DIY
https://acurazine.com/forums/showpos...52#post2033721
Intake Resonator removal
https://acurazine.com/forums/showpos...58#post1870075
CAI install DIY
http://wizardsworks.org/chod/acura/cai/printme.html
Radiator Removal
https://acurazine.com/forums/2g-cl-2001-2003-50/griffin-radiator-install-write-up-pictures-486321/
Brake Switch DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-brake-switch-614710/
Timing Belt/Valve Adjustment DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-timing-belt-695821/
https://acurazine.com/forums/2g-tl-1999-2003-98/120k-service-completed-610450/
Valve Adjustment
https://acurazine.com/forums/2g-tl-1999-2003-98/valve-adjustment-diy-progress-643700/
Wheel Bearing DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/wheel-bearing-diy-620807/
Thermoblock DIY/EGR cleaning DIY (99)
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-thermoblok-spacers-install-egr-cleaning-615644/
2000-2003 EGR Port Cleaning
https://acurazine.com/forums/showpos...67&postcount=8
99 EGR port cleaning
LinkDeny
http://www.justanswer.com/uploads/ac...52_B00-004.pdf
Replace Motor Mounts
https://acurazine.com/forums/showthr...ht=mount+motor
https://acurazine.com/forums/showthr...gine+mount+diy
Trans Fluid Drain Fill DIY
https://acurazine.com/forums/showpos...38&postcount=3
Header Install
http://www.cardomain.com/ride/184466/19
Header Torque Spec Values:
https://acurazine.com/forums/showthread.php?t=190202
Replacing broken wheel lug
https://acurazine.com/forums/2g-tl-problems-fixes-117/replacing-broken-wheel-lug-stud-596439/
Pics of IACV - idle air control valve (Need to find threads on cleaning):
https://acurazine.com/forums/showthr...+control+valve
https://acurazine.com/forums/ramblings-12/goddam-its-hot-184758/
Purge Valve Solenoid Pics (if it ticks, you need to replace it):
https://acurazine.com/forums/showthr...light=Solenoid
DIY motor mount poly filling:
https://acurazine.com/forums/showthr...ly+fill+mounts
Installing a Type-S Intake Mmanifold on a Premium Model Engine:
https://acurazine.com/forums/ramblings-12/atrocities-taliban-read-187979/
DIY Trans bypass filter replacement
https://acurazine.com/forums/2g-tl-problems-fixes-117/transmission-bypass-spin-filter-replacement-852465/
DIY Banging/Chattering Wipers
https://acurazine.com/forums/2g-tl-p...ura-tl-776382/
Paint and Body
Rear Door handle removal/replacement
https://acurazine.com/forums/second-...cement-919892/
Engine Cover painting DIY
https://acurazine.com/forums/showthr...1#post10607521
Painting CAI DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-paint-your-cold-air-short-ram-intake-638335/
99-01 Front Lip installation DIY
http://picasaweb.google.com/amgala/1...nInstructions#
02-03 Front Lip installation DIY
http://picasaweb.google.com/amgala/2...nInstructions#
99-03 Side Skirt installation DIY
99-03 Rear Skirt installation DIY
DIY Spoiler Install
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-spoiler-install-626023/
Car Care
https://acurazine.com/forums/wash-wax-23/acurazine-car-care-faqs-293029/
DIY: Taking off front grille (02-03)
https://acurazine.com/forums/2g-tl-photograph-gallery-99/diy-taking-off-front-grill-pics-572103/
Painting Engine cover info/diy
https://acurazine.com/forums/2g-tl-1999-2003-98/question-painting-engine-cover-584623/
Wetsanding Headlights DIY
https://acurazine.com/forums/2g-tl-photograph-gallery-99/fun-sandpaper-580286/
Removing "B" Pillars
https://acurazine.com/forums/2g-tl-problems-fixes-117/remove-b-pillar-2nd-gen-tl-%5B56k-beware%5D-583946/
Debadge
https://acurazine.com/forums/2g-tl-1999-2003-98/how-remove-badging-pics-vid-inside-3g-garage-e-016-a-581721/
Black Mesh Grille
https://acurazine.com/forums/2g-tl-photograph-gallery-99/black-mesh-grille-inspired-%40cur%40-tl-555133/
Brakes
Brake Pad and Rotor DIY
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/diy-rotors-pads-%2A%2Ahow-w-pictures%2A%2A-620983/
http://www.cardomain.com/ride/184466/24
http://www.cardomain.com/ride/184466/23
How to: Brake lines threads:
https://acurazine.com/forums/showthread.php?t=118783
https://acurazine.com/forums/showthread.php?t=182598
https://acurazine.com/forums/showthread.php?t=143104
Interior/Electrical
Steering Wheel Removal
https://acurazine.com/forums/showthr...steering+wheel
Radio/Cruise button fix
http://www.geocities.ws/kara_mino/b03-015_2.pdf
Removing door panel/wood door panel trim
https://acurazine.com/forums/showthr...light=Speakers
Alarm/starter DIY
https://acurazine.com/forums/audio-video-electronics-navigation-22/alarm-starter-diy-709590/
Radio Removal
http://www.megaupload.com/?d=JV89XXGB
Converting to Hand Brake
https://acurazine.com/forums/showthr...=handbrake+mod
Switching the Sport Shift + - Direction
https://acurazine.com/forums/showpos...7&postcount=79
LOC converter Installation
https://acurazine.com/forums/2g-tl-1999-2003-98/attn-wdptls-loc-install-instructons-629209/
Door Panel & Wood Grain Removal
https://acurazine.com/forums/2g-tl-1999-2003-98/d-i-y-removing-door-panels-wood-grain-626785/
Door handle separation fix
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/diy-my-interior-issue-485828/
Heated seat fix DIY
http://joshsworld.com/cars/acura-tl-seat-heater-fix/
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-heated-seat-successed-cost-only-%243-607220/
Shift Gate modification
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-shiftgate-redo-update-621805/
Door Lock Knob modification DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-door-lock-knob-adjustment-620740/
Replacing Rear View Mirror
https://acurazine.com/forums/2g-tl-1999-2003-98/replacing-tl-rear-view-mirror-619196/
DIY Dash Rattle
https://acurazine.com/forums/2g-tl-1999-2003-98/dash-rattle-found-fixed-pictures-546283/
Radar Detector Hardwired into auto-dim mirror
https://acurazine.com/forums/2g-tl-1999-2003-98/radar-detector-wired-into-auto-dim-mirror-593753/
AC Cabin Filter DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/updated-diy-ac-cabin-filter-change-567712/
DIY Non-Navi to Navi
https://acurazine.com/forums/2g-tl-1999-2003-98/d-i-y-non-navi-navi-573887/
Load Equalizer/Resistor
https://acurazine.com/forums/showpos...00#post2074444
Maintenance
EZ Drain Valve DIY
https://acurazine.com/forums/2g-tl-1999-2003-98/ez-oil-drain-valve-install-w-pics-611400/
Seafoam DIY
https://acurazine.com/forums/9053510-post/
Resetting the Maintenance Light
https://acurazine.com/forums/showthread.php?t=178269
Resetting SRS light
*If after you reset the light it comes back on BRING TO THE DEALER to be serviced*
Maintenance Schedule for Normal and Severe Conditions
6 Speed Swap/info
6spd conversion on a 2G TL:
Discussion: https://acurazine.com/forums/ramblings-12/my-job-132196/
Pics: https://acurazine.com/forums/technology-16/anybody-have-sony-t616-132270/
6MTUA5's Swap thread
https://acurazine.com/forums/2g-tl-1999-2003-98/finally-started-ordering-parts-swap%2A%2Awork-starts-pg-9%2A%2A-631849/
Phees 6 speed Swap thread
https://acurazine.com/forums/2g-tl-1999-2003-98/phees-99-tl6-swap-thread-parts-list-price-list-question-thread-703784/
InspireTL's Swap thread
https://acurazine.com/forums/2g-tl-1999-2003-98/inspiretls-swap-thread-progress-56k-please-upgrade-645076/
6 Speed Module Thread
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/yo-richiev6-699063/
6spd mods - clutch dampening device bypass, shifter cable bushings:
https://acurazine.com/forums/showthread.php?t=183560
https://acurazine.com/forums/showthread.php?t=184271
Fill Plug on the 6spd (pics and helms scans):
https://acurazine.com/forums/showthread.php?t=188979
DIY 6spd Shifter Bushing:
https://acurazine.com/forums/showthr...hifter+bushing
Warranty Info
SRS indicator light warranty extension
https://acurazine.com/forums/showthread.php?t=179416
Transmission Problem FAQ
https://acurazine.com/forums/2g-tl-problems-fixes-117/under-construction-transmission-problem-faq-please-read-before-posting-573111/
TL Trans failure thread
https://acurazine.com/forums/2g-tl-problems-fixes-117/tranny-failure-thread-566833/
Tensioner Recall affected VIN's:
https://acurazine.com/forums/showthr...nsioner+recall
Trouble Codes.
Acura Factory Trouble Codes (DTC's) (in pdf format):
http://www.in.honda.com/Rjanisis/pubs/SB/B03-010.PDF
Miscellaneous
DIY: How to program the keyless remote (key fob)
]https://acurazine.com/forums/showthread.php?t=141058/url]
DIY: HomeLink Garage MOD - Key Needed to Use (with photos)
url=https://acurazine.com/forums/showthread.php?t=127721
DIY: How to program Homelink with Rolling Codes
https://acurazine.com/forums/showthr...hreadid=121019
DIY: How to program Homelink with an older garage door opener
https://acurazine.com/forums/showthread.php?t=95563
Transmission Gear Ratios (Automatic and 6spd)
https://acurazine.com/forums/showthread.php?t=173378
Where to get the OEM Service Manual/Owners Manual for the CL
https://acurazine.com/forums/showthread.php?t=178375
Honda Acura reformulated manual transmission fluid for 6spds:
https://acurazine.com/forums/cooking-dining-47/back-food-forum-185873/
Programming The Keyless Remotes:
https://acurazine.com/forums/showthread.php?t=51087
https://acurazine.com/forums/showthread.php?t=190577
Engine Torque Dampers:
https://acurazine.com/forums/ramblings-12/wallpaper-glue-solvent-185859/
https://acurazine.com/forums/showthread.php?t=173429
Adjust External Temperature Readout:
https://acurazine.com/forums/showthread.php?t=109089
Tightening the Power Outlet Next to the Coin Tray:
https://acurazine.com/forums/showthr...t=power+outlet
Mileage after gas light goes on:
https://acurazine.com/forums/showthread.php?t=183123
OEM pop-screws/plastic rivets cheap replacement:
https://acurazine.com/forums/audio-video-electronics-navigation-22/attn-streeteffectz-192746/
fsttyms1 is offline
The following 10 users liked this post by fsttyms1:
cheekoo (11-24-2012), DaBubbla (09-22-2013), dqbeat (12-12-2014), hedwig (10-15-2012), heybeni (02-14-2013), Ken1997TL (06-17-2011), RONE (11-14-2012), Sturmgewehr44 (03-11-2012), TEgo821 (07-23-2012), webmastir (04-21-2012) and 5 others liked this post. (Show less...)
Old 01-30-2009, 06:42 PM
fsttyms1's Avatar
Mod List
Alright, Got the colors back up! With new additions!!
PERFORMANCE:
Intake systems:
AEM:
-V2 Intake: Part#24-6016 {99-03 TL-P}
-Cold Air Intake: Part # 21-419 {02-03 TL-S}
-Cold Air Intake: Part # 21-416 {99-03 TL-P} NP
-Short Ram Part # 22-416 {99-03 TL-P} NP
Injen
-Cold Air Intake: Part # RD1660 {99-03 TL-P}
-Short Ram Intake: Part # IS1660 {99-03 TL-P} NP
-Cold Air Intake: Part # RD1481 {02-03 TL-S}
Comptech
-Ice Box Cold Air Intake: Part #330-141{99-01 TL-P}
-Ice Box Cold Air Intake: Part #330-140{02-03 TL-P}
-Ice Box Cold Air Intake: Part #330-145 {02-03 TL-S}
K&N
-Replacement Filter For Stock Applications: Part 33-2133 ( All Models )
Headers
-DC Sports: Part # HHC5528 {99-03 TL-P/S}
-XS Headers: {99-03 TL-P/S}
-Comptech Headers/Downpipe: Part # 220-042{99-03 TL-P/S}
Exhaust
AxleBack Systems:
-HKS Dragger: Part # 3302-EX06 {99-03 TL-P/S}
-Magnaflow: Universal Axle Back {99-03 TL-P/S}
-Comptech Axle back: Part # 240-110 {99-03 TL-P/S}
Catback System
-Apexi WS World Sport Series: Part #116-KH22 {99-03 TL-P/S}
-Tanabe SM Hyper: Part # T4078Z {99-03 TL-P/S}
Pulley
Unorthodox Racing
-Ultra S Crank Pulley: Part# 020611002 {99-03 TL-P/S}
-Stock Diameter Crank Pulleys (Ultra Sc): Part # 120611012 {99-03 TL-P/S}
-Ultra S Crank Pulley Set: Part # 040602002 {99-03 TL-P/S} NP = Due To Crank Pulley Only Needed
-Stock Diameter Pulley Sets (Ultra SSc) Part #140602012 {99-03 TL-P/S} NP = NP = Due To Crank Pulley Only Needed
Spacers
-ThermoBlock Spacer Kit: Part # P8A/P8F {1999 TL-P}
-ThermoBlock Spacer Kit: Part # P8E/P8F {00-03 TL-P}
-ThermoBlock Spacer Kit: Part # P8E/PGE {02-03 TL-S}
Grounding Kit
-Make your own using 4Gauge Wire {All Models}
-Apexi Grounding kit {All Models}
Battery
-Optima Red/Yellow {All Models}
Engine Swap
- For a TL-P - TL-S/CL-S Motor & CL-S 6 Speed
- For a TL-S - Stock Motor & CL-S 6 Speed
Forced Induction
-Comptech Supercharger: Part # 350-062 {02-03 TL-S}
-Custom Turbo Kit {99-03 TL-P/S}
-AV6 Honda Accord V6 Supercharger: {99-03 TL-P }
Nitrous
-Zex, Nitrous Express, Venom, NOS Wet/Dry Kit {99-03 TL-P/S} NP
Combinations/Notes
Bolt Ons!
-Intake, Headers, Spacers, Pulley, Exhaust = 260HP/TQ to the crank {99-03 TL-P}
-Intake, Headers, Spacers, Pulley, Exhaust, Supercharger= 300+HP/TQ to the crank {02-03 TL-S}
-All the parts give about the same results when combined with each other expect for "Not Preferred" Items.
-To compare products, do research before asking, tons of threads and posts.
-Nitrous will also help but isn't recommended, a 75 shot is about 75 HP, 50 shot is about 50 HP to the crank
SUSPENSION
Coilovers
TEIN
-SS Super Street Coilovers: Part # DSH94-KUSS2 {99-03 TL-P/S}
-Type BASIC: Part # DSH94-LUSS2 {99-03 TL-P/S}
-SS-P Super Street w/ Pillow Ball: Part # DSH94-2USS1 {99-03 TL-P/S}
Tokico
-Tokico HPK Performance Suspension Kit: Part # HPK285 {99-03 TL-P/S}
-Tokico ILLumina Suspension Kit: Part # ILK286 {99-03 TL-P/S}
Springs
-Comptech Sport: Front 2 / Rear 1.7: Part # 110-135 {99-03 TL-P/S}
-Eibach Springs Pro Kit: Front 2.1 / Rear 1.6: Part # 4041.140 {99-03 TL-P/S}
-H&R Race Springs: Front 2.2 / Rear 1.75: Part # 51859-88 {99-03 TL-P/S}
-Neuspeed Sport Springs: Front 1.75 / Rear 1.75: Part # 55.20.38 {99-03 TL-P/S}
-TEIN S-Tech: Front 2.1 / Rear 1.6: Part # SKA34-AUB00 {99-03 TL-P/S}
-TEIN H-Tech: Front 1.5 / Rear 1.0: Part # SKA34-BUB00 {99-03 TL-P/S}
Shocks
-KYB , Koni , Bilstein , Tokico
-You'll have to research, to many to list for front and rear
Strut Bar
-CUSCO Suspension: Part # 332540A {99-03 TL-P/S}
-Neuspeed Front Upper Strut Tie-Bar: Part #352096 {99-03 TL-P/S}
-Comptech Front Titanium Barr: Part # 150-070 99-03 TL-P/S}
Sway Bars
-Eibach Anti-Roll-Kit ( Front/Rear ): Part # 4040320 {99-03 TL-P/S}
-Neuspeed Rear Sway Bar (19mm): Part # 2520193 {99-03 TL-P/S}
-Neuspeed Front Sway Bar (27mm): Part # 1520271 {99-03 TL-P/S}
-Comptech Front/Rear Sway Bar Kit: Part # 140-215 {99-03 TL-P/S}
NOTES
-Tein coilovers are preferred because it allows the consumer to adjust the springs and provides the maximum amount for a drop.
-If coilovers are not in your budget, then springs and shocks should be bought together for a firmer ride.
-Sway & Strut bar will provide maximum ability for a sharper turn.
BRAKES/PADS
BBK - Big Brake Kits
-Brembo Front Kit 13": Part # 430-6015AIA {99-03 TL-P/S}
Replacement Rotors
-Racingbrake HP Brake Rotor /Slot-Drilled / (Rear Pair): Part # 9701-141 {99-03 TL-P/S}
-Racingbrake Two-piece Rotor /Slot/ (Front Pair): Part # 2067.311 {99-03 TL-P/S}
-Racingbrake UP Brake Rotor /Slot/ (Front Pair): Part #90761 90762 {99-03 TL-P/S}
-PowerSlot Brake Rotor /Slot/ (Front Pair): Part # 946PSL & 946PSR {99-03 TL-P/S}
Replacment Pads
-Hawk Performance Ceramic Front Brake Pad Kit: Part # HB366Z.681 {99-03 TL-P/S}
-Hawk Performance Ceramic Rear Brake Pad Kit: Part # HB145Z.570 {99-03 TL-P/S}
-Hawk Performance HP+ Front Brake Pad Kit: Part # HB366N.681 {99-03 TL-P/S}
-Hawk Performance HP+ Rear Brake Pad Kit: Part # HB145N.570 {99-03 TL-P/S}
-Hawk Performance HPS Front Brake Pad Kit: Part # HB366F.681 {99-03 TL-P/S}
-Hawk Performance HPS Rear Brake Pad Kit: Part # HB145F.570 {99-03 TL-P/S}
- RACING BRAKE PADS COMING SOON
Exterior Appearance
Body Kit
-OEM Body Kit {99-03 TL-P/S}
-WW Body Kit {99-03 TL-P/S}
(These two are the best ones)
Spoilers
-M5 Spoiler {99-03 TL-P/S}
-OEM Spoiler {99-03 TL-P/S}
-Mugen Spoiler (Rare) {99-03 TL-P/S}
-Aspec Spoiler (Rare) {99-03 TL-P/S}
-WW Flush Mount {99-03 TL-P/S}
-Sonora Roof Spoiler {99-03 TL-P/S}
Wheels
-COMING SOON
-Note: Wheels WILL affect performance in either a ( + or - ) way. Choose wisely
-Stock Offset is 55MM, lowering the offset increasing chances of rubbing, depending on wheel setup ( Example , 18/19 X 8 +40 offset, need to cut tabs and roll fenders )
NOTES
-Its YOUR car, not anybody else, do to your car as you please but with safety and confidence.
-If you post your car with parts people will disagree on, then be prepared to listen to them and not take it offensively but more of a advice from them.
Lighting
-02 - 03 Tail Lights {99-01 TL-P}
-Upgrade HID Bulbs: Higher Kelvin, Lower Lighting Output {99-03 TL-P/S}
-Interior Bulbs LED Replacement (Sylvania.com) {99-03 TL-P/S}
Custom
-Headlight Housing
-Fog Lights
-Side Markers
-Interior Wood Trim/Shift Knob
Vendors
-Excelerate
-MrHeeltoe
-Check Black market and Group Buy Sections!![/QUOTE]
Any Comments Are Welcome! Thanks!!
fsttyms1 is offline
The following 13 users liked this post by fsttyms1:
01DEPTL (10-30-2012), 02 TL (03-20-2012), acuradriver925 (10-08-2012), AyyCee (05-03-2015), donchicago48 (08-09-2015), GK03TL (10-25-2015), MrMoAcuraPar (08-04-2013), RONE (11-14-2012), Sturmgewehr44 (03-11-2012), therealjgall (12-22-2016), w0nd3rlusTL (08-06-2012), webmastir (04-21-2012), xakura21 (03-17-2013) and 8 others liked this post. (Show less...)
Old 01-30-2009, 06:43 PM
fsttyms1's Avatar
If you have a new DIY or know of anything to add PM Me or one of the other 2nd gen moderators so we can add it.
fsttyms1 is offline
The following 7 users liked this post by fsttyms1:
acuradriver925 (10-08-2012), BLADE RUNNER (01-18-2014), Homestead12 (09-25-2017), NighthawkBlue (06-10-2012), paakwesia (11-26-2012), raydog318 (03-26-2012), Sturmgewehr44 (03-11-2012) and 2 others liked this post. (Show less...)
rets
01-01-2013 09:50 PM
Jonesi
05-16-2009 09:29 PM
tegkid
12-18-2008 09:45 AM
sauceman
TSX Frequently Asked Questions
08-16-2005 01:00 AM
rets
06-22-2004 04:25 PM
Quick Reply: "New" Official 2nd Gen TL DIY Thread
