My 02 tl-s here we go...
#281
Because a J32 6spd with a CT S/C is so subpar! lol
teh CL (01-16-2018)
#285
its actually tan
Funny you should suggest that type of a project.......
Andrew, if there was a 4 door Coupe version of the CL, I am sure if would do just fine on it's own.
OP, every time I look at the bits and pieces in your interior.......whoa....can't even imagine trying to put that all back together. Much respect to you.
MidoriTL (01-17-2018)
teh CL (01-19-2018)
#292
#293
its actually tan
Lol this is hilarious
And don't worry I took advantage of it during Christmas for my wife, I could mail you some
#294
LMAO, I'm gonna assume your offer is for the ones she hasn't yet worn
Funny, my gf was hinting at it to me the other day...oh babe, you haven't bought me bra and panties...
Better get on that!
You are making me want to make a bisimoto swapped rotrex sc 6mt odyseeeeeeee
Better get on that!
#298
UA5_PDX
HOw?
Bro how you make that fit? I'm having issues with my 18x8 +35 neoz wheels.215/40/z18 I had to take the rear wheels off because it would rub too much in the rear. attempted to roll the fender but didn't work. I cut the tabs in the front and it still rubs, only on sharp turns. btw I have a 2.5f & 2.25r drop. any advise, or what did you do?Thanks.
#299
its actually tan
It wasn't easy, being that my tires are stretched tho it made it a little more easy, now I did take a sanding pad on my grinder and sand down the back corners where the body meets the bumper, it seemed to work well but I still had to get camber kits for both front and rear, and on the front I spaced out the fender a little with washers. You might can tell from some pics I've put up but that does help a good bit as well, and with the front camber kit I'm running full negative lock on the ingalls kits. Don't remover the numbers tho 😅
#300
MidoriTL, I saw a similar one of those Toyo Tundra's shown in post #248 you parked next to in my local area today. As soon as I recognized the 'color' it reminded me of this thread, lol. In person, the color looks suite!
So, what's the status on your 3.5 6-speed swap? It's been kind of quite in here, just curious.
#301
its actually tan
Working on the wiring. Really need some solid direction on what others have done to get it to work and have full functioning rear doors and tail sections, while using the front half of the cl wiring.
#305
its actually tan
its actually tan
can someone on here that has a 02-03 tl go to the fuse boxes inside the car and do a little recon for me?
i need someone to unplug the top green plug harness in each side (should go toward rear of the vehicle) and tell me what does and doesnt work lol. im looking for rear doors functionality or tail lights
#307
Unregistered Member
Once you get the car started, I can help you fix the wiring stuff. I would just focus on getting the car running first. If you have an 02 TL like me, then a bunch of stuff won't work initially. The rear tails and the fuel level sender have a ground that won't earth. You will have to splice that to a constant ground. Just a bunch of simple stuff like that, but you will need the electrical diagrams.
#308
its actually tan
I have an 02 TL. If you want to retain 100% OEM functionality, you really must buy the Electrical troubleshooting manual for both the TL and CL cars. Honestly, I wouldn't consider the swap without them.
Got it running, which wires do I need to ground?My tail lights work fine btw
teh CL (01-25-2018)
#309
its actually tan
Got the dash back in and got the car to run today now just gotta finish up the little stuff this weekend and hopefully drive it, also put down a small layer of sound damping should help keep some road noise out
#310
Congrats to you on your successful 3.5 6-speed swap. In the next few months, when time/money allow for it, consider installing a set of 6-speed headers, like XS-P or Manzo, to really wake up that J35A1.
teh CL (01-25-2018)
#314
its actually tan
i work at The Speakerbox in huntsville as shop manager and we carry the metra brand ballistic and that stuff is pretty decent but we had ordered some buzzmat on the cheap to try it out. it seemed to stick and stay stuck better but we ended up not switching so i got the last little bit we had to do my floor since i had the carpet out lol its all really the same stuff though to be honest lol and you can buy stinger or ballistic bulk packages cheap online
#316
its actually tan
Does anybody have a link to a decent sized full exhaust, all I can find is the ws2 apexi system but plenty of others for 04-08 tl's not much for the 2nd gens.
#317
T70078 - Tanabe Medalian Exhaust - Medalion Touring - Excelerate Performance - European, Exotic and Japanese Performance Specialists!!
Otherwise, you can get an initial set of Manzo headers for $125 + shipping:
https://www.redline360.com/manzo-hea...l-tl-v6-TP-048
#318
I know late question to your build, but how do you like the ff coils? I'm looking at the type 1s but read mixed reviews on az. I mostly just like how those come with the top hats and don't need to mess with spring compression. Also, color scheme matches my brake calipers vs the Teins.
#320
its actually tan
