Can OEM suspension bushings be pressed out?
Old 04-19-2018, 09:26 PM
Iggy's Avatar
Looking to do a bushing refresh. Can any of the factory bushings be pressed out and replaced with aftermarket rubbers?
Old 04-19-2018, 10:59 PM
Received 8,578 Likes on 6,628 Posts
Yes
Old 04-20-2018, 07:28 AM
Iggy's Avatar
Thanks Thoi,
Any recommendations on brands?
Old 04-20-2018, 07:30 AM
Personally when I did LCA's I went with OEM bushings they work well enough so didn't bother fixing something that isn't broke
Old 04-20-2018, 07:31 AM
https://www.oemacuraparts.com/auto-p...lower-arm-scat
I did 12 and 16 on the LCA above
Old 04-20-2018, 09:45 AM
Received 1,733 Likes on 1,390 Posts
Don't use Moog, stay with OEM if possible for the LCA's. While you have the LCA out and disconnected from the front radius rod(s) consider doing the Radius rod bushings as well. I used the ones below and they were much better then the soft OEM ones:
Front Strut Arm Bushings - Honda Accord - 16.7103
ProfessorFunk (12-24-2018)
Old 04-20-2018, 01:10 PM
Iggy's Avatar
Thanks guys. I'll tackle the bushings while I pull the trans to track down this goddam oil leak
Old 06-14-2018, 05:02 AM
Iggy's Avatar
I went to install the RR bushings and wouldn't you know it, the package had 3 small and one large bushings in the box. It's always something. Ordered another set.
I'm guessing the larger bushings go on the front of the radius rod?
Side note, LCA bushings were a real PIA! The old ones were seriously a bitch to get out.
Old 06-14-2018, 05:08 AM
Iggy's Avatar
Quick question, The service manual doesn't specify but i'm assuming the LCA bolts should be tightened with the suspension in it's normal ride height?
Old 06-14-2018, 06:35 AM
If you don't use a new RR self locking nut, put a little 'blue' thread locker on.
Which radius rod bushings did you finally settle with?
From Helms 'Lower Arm Replacement' section:
First install the suspension components and lightly tighten bolts and nuts, then place a jack under the lower arm, and raise the suspension to load it with the vehicle weight before fully tightening bolts and nuts to specified torque values.
Old 06-14-2018, 07:08 AM
Also, IIRC'ly, when it was time to torque the self-locking nuts to the 40lbf-ft, I didn't have a 'deep' enough socket to tighten all the way, so I used a 12mm (I think) crows foot to get the proper torque. It's real important to keep tightening until your torque wrench indicates the 40lbf-ft; otherwise, you might have movement or 'thuds' appear as the RR's do their thing. Especially with that beefy 3.5 you now have.
Old 06-14-2018, 07:19 AM
Iggy's Avatar
I went with the Energy suspension bushings as you suggested. Thanks for the tips man!
Old 06-14-2018, 07:39 AM
Nice. I hope they work out for you. They helped 'stiffen' up the front of my car just enough to notice, even with the added weight of the SC'er, it was apparent.
Old 07-30-2018, 09:46 PM
Hey Iggy, did you ever get around to installing the ES radius rod bushings?
If so, what are your impressions.
Old 08-02-2018, 04:51 AM
Iggy's Avatar
I did! They definitely tightened things up and everything is nice and quiet up front now. To be honest though, I don't really push the car's suspension very hard so I may be a bad test case.
zeta (08-02-2018)
Old 11-26-2019, 03:40 PM
2007 LSM KB1 Tech w/CMBS
stevieray's Avatar
So you guys are using OEM bushings from a '99 TL to replace the front LCA bushings on a KB1? Can the UCA bushings be pressed out and if so, what bushings are used to replace them? Thanks!
Old 11-27-2019, 10:39 AM
whitetiger5's Avatar
@stevieray this is the 2G TL forum, they are referring to replacing parts for their 99-03 TL.
For questions on the KB1 (assuming you mean RL) I would post in the appropriate forum.
about bushings: almost any can be pressed, but the real question is it worth the time and effort needed? a lot of the time not really. for example: I would replace the bushings on my LCA, whereas the UCA I just replace the whole thing.
Old 11-27-2019, 12:39 PM
stevieray's Avatar
Thanks, bro. My bad, I have no idea how I ended up in the TL group. Thanks for the advice on when and where to replace bushings, that's good to know.
whitetiger5 (11-27-2019)
MrVtech
12-04-2019 06:51 AM
jimbodude
09-17-2018 03:58 PM
t3hhcaptain
12-27-2016 01:03 PM
waynema
02-28-2006 10:57 PM
Quick Reply: Can OEM suspension bushings be pressed out?
