OEM spring color code ??
Old 06-19-2012, 09:41 PM
mattyd6911's Avatar
I have 2 sets of OEM springs, both with different color markers on them. 1 front set has blue & white, the other front set has pink & white.. Is there a difference? Could they be an Automatic / Manual difference for weight reasons? Can anyone confirm what model or trans each set should be on?
Old 06-19-2012, 09:46 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
Part numbers?
I know for various bolts the paint colors mean "tightened" at the factory. Not sure what the paint marks on the springs mean, but wouldn't count on it being part identification.
Old 06-21-2012, 12:39 PM
Former Sponsor
WholesalePartsGuy's Avatar
Just called the factory and they said those paint dots should simply indicate left and right on factory spring/strut assemblies. I noticed those as well on some take off springs and struts I have in stock.
mattyd6911 (06-21-2012)
Old 06-21-2012, 02:27 PM
mattyd6911's Avatar
My real concern is that I changed my springs from oem 04 ones to oem 06 ones. They are both for an A/T, but I see 2 listings for springs in 06 and above for A/T that are way different in price.. I think I might have mine backwards from left to right. Is there a difference between the left and right for A/T after and including 06? Im guessing so to account for the trans weight difference.. Any chance of finding that out? I havent had any luck. My car pulls to the left with a perfect alignment, and I think that might be the prob..
Old 06-22-2012, 01:22 PM
Former Sponsor
Yes. The right and left are different for the fronts and could be the reason for your pull like you said.
mattyd6911 (06-22-2012)
Old 06-22-2012, 01:25 PM
mattyd6911's Avatar
Would that also make the car feel less solid than it should when hitting bumps, and dip more to the drivers side than the passenger when making turns?
Old 06-22-2012, 01:42 PM
mattyd6911's Avatar
How could I even figure out which is left and right wasting time swapping them?
Old 08-15-2018, 03:23 AM
Chad05TL's Avatar
So which color is right and which color is left?
ExcelerateRep
12-11-2015 12:58 PM
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
HeloDown
09-08-2015 06:51 PM
MyKids&Cars
09-01-2015 12:53 PM
Quick Reply: OEM spring color code ??
