Ideas for New Rims
Ideas for New Rims
Im in the market for some new rims due to the lovely events that took place here:
https://acurazine.com/forums/third-g...65-mph-972446/
For the record, I currently have Motegi Racing MR107 (18"x 8") (+42 offset) with stock suspension, no spacers, and I dont have any plans of lowering anytime soon. If I do lower my car in the future, then it would be tasteful (with coilovers) and not slammed with camber (not my style).
I want to keep a 5-spoke 18" or 19" rim while entertaining a black and silver combination. Here are a few options that I am considering (Most recommended tire packages with 18 rims are 235/40/18):
1) Vision 469 Boost Gloss Black with Machined Face (18 X 8) (+38 Offset)
2) Vision 469 Boost Satin Black (18 X 8) (+38 Offset)
3) Touren TR73 3273 Black with Milled Accents (18 x 8) (+35 Offset)
4) KMC KM685 District (18x 8) (+38 Offset) OR (19 x 8.85) (+42 Offset)
5) Mach ME1 Satin Black (18x8) (+35 Offset)
Any thoughts are welcome! Thanks in advance.
Josh
Josh
my vote
losiglow (08-30-2018)
So, I finally made a decision. I fell in love with the look of the Hyundai Genesis Coupe rims after stumbling across these threads:
https://acurazine.com/forums/3g-tl-t...-05-tl-896644/
https://acurazine.com/forums/market/973204
It took quite a while to find a good set, but I found a seller on eBay (with hundreds of excellent reviews) who had a brand new set that were powder coated from the factory and used on a demo car.
The rim specifications are the following:
Front: 19x8.0 +35 offset (Part #52910-2M120)
Rear: 19x8.5 +35 offset (Part# 52910-2M130)
I also purchased some aluminum 67.1 mm to 64.1mm hub centric rings.
With regards to the center caps, my research concluded that these Hyundai caps are 2 5/16'', which aren't obviously interchangeable with our Acura caps, since they are 2.75''. To give it the "Acura" authenticity, I plan to take the top cover off, paint the caps black, drill three holes, and add the chrome Acura emblem from a set of OEM Acura center caps. The problem is that Acura center caps are pretty expensive, so I hope I can find a cheap set somewhere online. We shall see.
The following 2 users liked this post by wusty23jd:
csmeance (11-05-2018),
Shadow2056 (11-05-2018)
Damn that looks good
did you use oem hyundai lug nuts or use oem acura tl lug nut? I am looking into the 19s genesis r spec wheels but wanted to make sure if I have to purchase hyundai lug nuts
[/QUOTE]
[/QUOTE]
Do NOOOOOOTTTTT use the OEM lug nuts. You NEED to make sure that you use the correct lug nut designed for the rims of your choosing. The only reason I purchased new rims is because I ruined my old ones by using the incorrect lug nuts. Please refer to my thread here:
https://acurazine.com/forums/3g-tl-p...65-mph-972446/
