Front Shocks
Old 07-06-2018, 12:46 AM
mporreca01's Avatar
Front Shocks
Can somebody help me out here...Sorry for the novice question....Are the front shocks on my 08' the same part or are they left side and right side specific? Do I need to buy a left shock and a right shock or just 2 front shocks? Thank you in advance for any input it is greatly appreciated!!!
Old 07-06-2018, 01:32 AM
redbeard1's Avatar
Assuming you are using OEM parts, if you are replacing the shock assembly (shock, spring, top hat), there are two part numbers - one left and one right. If you are just replacing the shocks inside the assembly, it is the same part.
for base 2008
https://www.acurapartswarehouse.com/...-absorber.html
Old 07-06-2018, 01:02 PM
mporreca01's Avatar
Ok that is what I was hoping...so I have 2 front left aspec shock assemblies...I would just need to swap the top hat out to make it work for the right side correct? or are there other parts I would need?
Old 07-06-2018, 02:03 PM
redbeard1's Avatar
hi,
I'm not familiar with a-spec suspension and am not sure if you can swap base coils/top hats with a-spec shocks. Sorry.
Supastardavid
11-04-2014 09:11 PM
Aretardedorange
04-22-2012 06:16 PM
Coebee
07-30-2008 12:39 PM
bobowah
06-10-2001 11:09 PM
Quick Reply: Front Shocks
