D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
Old 11-08-2008, 08:37 PM
  #241
horsepowercrzy18's Avatar
wheel fitment
will 19x9.5'' +35 offset all around with 245/35/19s work good for me on my 3g tl?
Old 11-09-2008, 02:05 AM
  #242
E55>>>TLS
dr_brains510's Avatar
So my front breaks are done and I don't want to get the brembos b/c they make a lot of noise. So are these the next best alternative that WILL fit on my 07 TLS?
http://www.customcarscentral.com/rtr...l--04-up-.html
Old 11-09-2008, 10:37 AM
  #243
E55>>>TLS
Can anyone confirm that the ones I posted are the next best alternative?
Old 11-09-2008, 06:36 PM
  #244
94 DC4 RS LSV/Turbo
stillhere153's Avatar
Originally Posted by SinCityTL
Is it possible to make 5 x110mm wheels work on the TL? I believe the TL TypeS require 5x114mm? I have wheels from my saab I would like to use if possible.
if you get the wheels custom done yes... they will drill new holes
  #245
94 DC4 RS LSV/Turbo
yes very aggressive but it will work
Old 11-09-2008, 06:37 PM
  #246
94 DC4 RS LSV/Turbo
excelerate carries those you should pm him for a better or equal price as that website
Old 11-10-2008, 12:28 PM
  #247
Retired!!! ON TOP!!!
rodneyc77's Avatar
You'll have to use 225/35/19 up front with a minimum of 1 degree of camber...
the rear should work with a rolled fender and the 245/35/19...
Good Luck
Old 11-11-2008, 03:43 AM
  #248
lowering
ok so even though im not lowered i still have to go 225 up front? 225 would be a super stretch on a 9.5'' wheel
Old 11-11-2008, 06:50 PM
  #249
94 DC4 RS LSV/Turbo
wait u have a 6speed, it won't clear your brakes
Old 11-12-2008, 02:10 PM
  #250
nam9684's Avatar
Will these wheels have any problem(s) fitting a 2004 TL AT /w aspec drop?
Wheel Make/Model:Axis Hiro
Wheel Size (19X8.5):
Wheel Offset (+45):
If lowered (1"?): Aspec drop
Thanks!
Old 11-12-2008, 03:01 PM
  #251
rodneyc77's Avatar
Wheel Offset (+45):
Thanks!
Nope... no problem all... well except for them being REALLY sunking into the car
Old 11-12-2008, 03:50 PM
  #252
nam9684's Avatar
how bad? Got any pics? It's my first time buying wheels
Old 11-12-2008, 08:31 PM
  #253
nam9684's Avatar
So I went and did some research which brought me to this thread:
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/offset-explained-569837/
and this calculator:
http://www.1010tires.com/WheelOffsetCalculator.asp
According to the calculator and assuming that the stock wheels are 17x7.5 +45 offset and the Axis hiro's 19x8.5 +45, the inner clearance will 13mm less and outter clearance will be 13mm more.
Again, I don't know much about wheels or have ever purchase any after market wheels, but all the numbers above seems ok to me. Correct me if I am wrong. Thanks!
Old 11-13-2008, 06:27 AM
  #254
rodneyc77's Avatar
stock wheels are 17x8 +45....
Like I said... you'll still be sunken in... but if you want to buy wheels without having to roll your fenders... then you'll be okey...
Old 11-13-2008, 11:15 AM
  #255
5th Gear
roger78745's Avatar
Question New TL Owner with wheel question
Great site and full of good information. I am looking at:
20x 8.5 front
20x10 rear
no drop
2006 TL Auto
Not sure the offset. Gianelle Qatar wheels.
I want the staggered look but not sure they will fit. The wheel guys (as I have read on here) don't always know. Before I make this investment I want to know what I can.
Sounds like the best tire for the ride will be the 245/30 that I am reading about here.
If the 20x10 fits what tire should I get for that wheel?
Again, thanks for the great information.
Roger
ATX
Old 11-13-2008, 11:45 PM
  #256
TorqueSteer's Avatar
Question on BBK clearance
6spd
05 base
ASA JH8
19x8.5
35mm offset
1" drop
Old 11-14-2008, 01:50 AM
  #257
94 DC4 RS LSV/Turbo
Wheel Offset (+45):
Thanks!
I went with the +35 when I had the hiros, they looked perfect
Old 11-14-2008, 01:52 AM
  #258
94 DC4 RS LSV/Turbo
20x 8.5 front
20x10 rear
no drop
2006 TL Auto
Roger
ATX
20x8.5 with an offset between +35 and +45 (245/30-20) or (235/30-20)
20x10 with an offset between +45 and +55 (265/30-20) or (255/30-20)
Old 11-14-2008, 01:53 AM
  #259
94 DC4 RS LSV/Turbo
6spd
05 base
ASA JH8
19x8.5
35mm offset
1" drop
should clear no biggie
Old 11-14-2008, 08:32 AM
  #260
rodneyc77's Avatar
20x 8.5 front
20x10 rear
no drop
2006 TL Auto
Roger
ATX
I don't think those wheels flow well with the car... But of course you have you own taste in the matter... Are you sure you want to spend close to $2,500 w/tires on those One piece Chrome Wheels???
Stillhere153 answered your question corrently...
Old 11-16-2008, 05:37 AM
  #261
Down for a photoshoot?
crzygosu87's Avatar
2006 Acura TL A/T
Wheel Make/Model: Works CR Kai
Wheel Size: 18x8.5
Wheel Offset: +25 (pretty aggressive ... but I hear the 3Gs can tolerate a lot)
If lowered: Tein Basics ... ~1-1.5in???
Old 11-16-2008, 03:54 PM
  #262
94 DC4 RS LSV/Turbo
what tires are you planning?
the front will be ok with 245/40-18 if you aren't lowered more than 1.5"
the rear will require negative camber
Old 11-16-2008, 05:20 PM
  #263
mondagi's Avatar
would ronjon devotion 1pc 19 x 8.5, 5 x 114.3, with a 56 offset fit my 08 tl??
please let me know thanks!!!
if not is there any way i can make this fit my car?
Old 11-16-2008, 05:42 PM
  #264
94 DC4 RS LSV/Turbo
is your tl auto? if so it will fit but will look like a sunken battle ship, so you would likely have to work with an ichiban 10mm or 15mm hubcentric spacer which is 64.1mm center bore
if you tl is stick you will need a 20mm spacer
good luck
Old 11-16-2008, 05:54 PM
  #265
mondagi's Avatar
thank you so much for quick reply... but one more thing once i get those spacer i would clear everything >? i wont rub n e thing?
Old 11-16-2008, 06:49 PM
  #266
94 DC4 RS LSV/Turbo
for 19x8.5 +56 you would want to put on some 245/35-19 tires
which will not rub even with a 20mm spacer
Old 11-16-2008, 10:36 PM
  #267
7th Gear
04_tl_driver's Avatar
I have 04 TL 6MT/brembos
Privat Netz grey 18in
what sizes will fit: Wheels and tires
Old 11-16-2008, 10:59 PM
  #268
7th Gear
I am looking to purchase the privat netz or somthing like them.
Any sugestions on wheels for MT/Brembo fitment would be very helpfull.
Where would be the best place to buy them?
Old 11-17-2008, 02:00 AM
  #269
94 DC4 RS LSV/Turbo
well the privat nets will fit if you buy them in 18x8 +30... you would be limited to 235/40-18 tires
me personally I would buy these instead simply because in 18" it is much more of an aggressive look
http://elementwheels.com/products.asp?cat=2351
18x8 +37 i believe should clear the brakes, at most will require a 5mm spacer which is no biggie, if that though, i don't think it will
Old 11-17-2008, 11:51 AM
  #270
7th Gear
Thanks Stillhere.
What size tire would you recommend for the tenzos
Old 11-17-2008, 03:17 PM
  #271
.:dedicated:.
chinkwapin's Avatar
what would you recommend for the offset if im looking for 19x8.5 vs-xx's? and tire sizes as well? im currently not dropped but im looking to do this at the same time as the rims =].. oh and btw i have a 6mt so i have brembos in the front. THANKS!
Old 11-18-2008, 10:54 AM
  #272
94 DC4 RS LSV/Turbo
keep the offset between +35 and +40
anything above 40 will have the sunken ship look
anything bellow +35 might rub on dips depending which tire size
235/35-19 is a good size if you have good roads
245/35-19 is a better size for cushioning
Old 11-18-2008, 10:55 AM
  #273
94 DC4 RS LSV/Turbo
Thanks Stillhere.
235/40-18
245/40-18
either works
Old 11-19-2008, 11:10 PM
  #274
Babnik's Avatar
Will the 16" steel rims that the Honda dealership sells for winter tire packages for Accords fit my 04 TL?
Old 11-20-2008, 12:02 AM
  #275
20'' clearance
i have an 04 tl 6 speed. wanting to put 20x8.5 with +35mm offset and 255 35 20. will it work? im not lowered
Old 11-20-2008, 10:38 AM
  #276
ewg302's Avatar
Questions on Wheels
Wheel Make/Model: Stern ST-2
Wheel Size (**X**):18x8.5
Wheel Offset (+**):+38mm
If lowered (amount):no
How will these fit on an 05 auto with 245's?
Old 11-20-2008, 10:53 AM
  #277
rodneyc77's Avatar
The 255/35/20 is too big... a better fit would be a 245/35/20 or 225/35/20... but you'll NEED to roll your rear fenders to make it work or add a 2 degree camber in the rear...
Good Luck
Old 11-20-2008, 10:54 AM
  #278
rodneyc77's Avatar
Originally Posted by ewg302
Questions on Wheels
perfectly... with a 245/40/18
Old 11-20-2008, 05:31 PM
  #279
Crow's Avatar
Questions on Wheels
Wheel Make/Model: Axis Penta
Wheel Size (**X**): F:19x8.5 - R:19x9.5
Wheel Offset (+**): ?
If lowered (amount): None
Questions on Tires
Tire Make/Model:Suggestions?
Width/Sidewall-Diameter (***/**-**):F:245/40-19 - R:255/40-19
Can you guys please help? I'm sorry, but i just came across this thread; if i knew i wouldn't have post a new one asking this same question.I got an 05 TL and I'm thinking about getting Axis Penta 19s (19x8.5F) (19x9.5R) but do not want to go with 30-35 series. Really want to do 40 series, since I've had horrible riding experience with 35s in the past. Does anyone know if this will cause the tires to rub? I don't plan on dropping the TL.
If i can't do this, then I will probably do the 18s" Penta Maxis (fake staggered). Please advise!!!
Old 11-20-2008, 08:49 PM
  #280
test fit
so i test fitted my 20x8.5 with +35 offset and 255 35 20 tires today on my 04 tl 6 speed and the wheel hit the brembos. im just wondering what size spacer you guys think il need to make it work. 3mm or 5mm spacer?
Quick Reply: D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
