New to the TL World. Slow build
#81
Finally got the coils on!!! YAY!!! Lol. They ride SOOOOOOOOOOO good too. Can't wait to get the EDFC. Just trying to figure out where to mount the box...
Next mods: EDFC, front lip, J-pipe, mufflers, wheels, and a few misc items.
#83
Yes it does! Taking corners, the car feels more planted. I enjoy the smooth ride too. Took it on a 4hr trip yesterday and it handle well. Just waiting to get a set of wheels with some new tires. Gotta see what bills and all are gonna be coming out of the check this month. Need to get tires for the wife's 2010 TSX along with brakes, 55w HID kit, new fog lights, and a full detail. Gonna get some slotted rotors for the TL. Brakes don't seem like they...grip as they should.
#84
Latent car nut
Received 2,005 Likes
#85
Thank you for the input. But from what I've experience and the different people I talk to and the research I've done, slotted are great for dd. Drilled/slotted is good for track. Not for daily driving. Slotted gives you a little better stopping power IF you get a good brand. Not just some random brand off eBay. Depends on how you drive too. I'm a spirited type driver. So I'd make sure of them. But for cruisers, no. There's no real benefit.
#86
Latent car nut
I ask because the slots effectively reduce the friction area of the disc, and given outgasing isn't an issue on modern pads when used anywhere except on a track, the physics of the situation suggests, all else being equal, a high quality set of blanks will outperform an identical quality set of slotted rotors.
#87
So, by what mechanism do you believe slotted rotors provide better stopping power?
Originally Posted by BuyAutoParts.com
Slotted brake rotors offer a significant performance boost over a smooth brake rotors. Under heavy braking, pad wear and outgassing causes a layer of dust and gasses to build up between the pad and the rotor surface, dangerously decreasing friction and causing “brake fade.” Unlike a smooth rotor, the slotted rotor has channels, or “slots” as the name implies, machined into the friction surface of the rotor. These slots allow for gas and brake dust to escape, resulting in better contact between the pad and rotor. Also, as the microscopic debris and gases are vented away from the pad, they naturally follow the path of the slot ACROSS the surface of the rotor, spreading out the heat and reducing likelihood of warpage due to overheating. The slots can also provide more initial “bite” for your brake pad and increase braking effectiveness while maintaining a smooth and responsive pedal feel.
Originally Posted by Redline360
Slotted brake rotors are a great alternative to drilled rotors because they serve the same purpose of expelling hot brake gas, but since they retain the strength of the rotor, they do not crack like drilled rotors can. We highly recommend slotted rotors such as StopTech. Some people argue that the drilled rotors are more for show, and the slotted rotors are more for race and performance. Slotted rotors are also better designed for wet conditions as they move water away from the rotor more efficiently for superior wet braking.
Originally Posted by StopTech
Slotting and/or cross-drilling helps wipe away the debris that forms between the pad and the disc, adds more bite, and can help the rear brakes to match the aesthetics of a front big brake kit. The rotor finish helps prevent glazing of the pads and improves wet and dry braking performance.
#88
Latent car nut
Okay, call me the loyal opposition, but what they are quoting hasn't been true for well over a decade. Yes, it helps them to sell more expensive stuff (much like low restriction intake makers claiming better fuel economy), but the fact is, they are selling a lie.
#89
Well intakes, depending on brand and design, do offer better fuel economy. Lol. And from the times I've had slotted rotors, I've noticed the difference. Drilled and slotted aren't good for a DD since SOME of those gasses help with friction. But slotted are fine. QUALITY drilled are ok as well. Only bad thing I've heard is from cheap drilled ones when they crack.
#91
Latent car nut
Oh my, sorry for opening up another can of worms, but it isn't physically possible for an intake to improve fuel economy. Modern fuel injection systems weigh the intake charge downstream of the throttle body and inject the correct amount of fuel for the current conditions; hugely restrictive and dirty, clean K&N, clean OEM, or no intake at all, the fuel economy will be the same. Here again, the whole "low restriction intake will improve fuel economy" thing is a product of a bygone era (in this case the carbureted era).
#92
Well I can close that can of worms. Lol. From my watching my fuel economy before and after intake install on all my vehicles, it does offer better fuel economy. I keep a STRICT watch on my fuel. I notice how my different driving habits effect it. Even the different brand gas you use changes it. I've even used different routes to work to test the fuel economy driving the different ways and various speed limits in each area, stop lights, traffic and more. No matter what you say, from my experience, fuel economy is improved with an aftermarket intake(quality brand). Braking is improved with slotted, drilled, or drilled/slotted rotors(quality brand). If what you say was true, there would be no point for any company to use them. Racing or for daily driving. You're telling me, from what you're saying, you are smarter than the race teams and car manufactures who use these products on their vehicles.
I've never seen this "low restriction" description you're talking about. Honestly, it sounds like a cheap way to sell a product. Lol.
#93
Latent car nut
I submit your anecdotal observations really don't prove anything. Here is a very detailed study which clearly shows, regardless of restriction, fuel economy will remain basically unchanged:
#94
Yep. Controlled testing. Meaning the temps were always the same. The amount the gas pedal was depressed was the same. The engine is either at two temps: warmed up to standard running temps or cold start. Not the in between temps. This was all done in a lab where test controls are all the same. Not out in real world where there's stop and go, traffic, below speed limit driving, above speed limit driving, at speed limit driving, different contaminates in the air(filters don't filter 100% of contaminates in the air because no filter can). As I said. MY experience and testing has proven different. Am I smarter than them? Nope. But I have real world test. Where it counts.
Look at the window sticker of a 2016 Honda Accord Touring. You'll see that the 3.5 V6 gets 33mpg. That's what their "test" showed for its fuel economy. My sister showed me she was getting 42mpg. On paper is good and all. But REAL WORLD test is what shows. Being in a controlled environment means if the environment was exactly like this, these are the results you'll get. But driving around town will never be a static temps or driving conditions.
#95
Latent car nut
Sorry, not a chance, modern fuel injection systems do not even remotely act the way you suggest.
#97
Latent car nut
Joecop67 (04-04-2018)
#99
Latent car nut
#100
I don't know the exact science behind it. What's you point to this? You don't agree with me, there's no point for you to keep posting in here. You're not going to change my thoughts on it. You have your papers and opinion. I have my experience. This isn't a science project.
#101
Latent car nut
In essence, allowing the engine to breathe easier helps with fuel economy. Less work the engine has to do, the more efficiently it'll work.
#102
As I said. I don't know the exact science behind it. But it works. I don't question it. It doesn't cause harm. It saves me money over time.
polobunny (04-14-2018)
#104
Wrong subject. I'm talking about me watching my fuel economy and better braking. Not how much power a mod adds.
But hey. Go tell the automakers they're wrong for added drilled rotors on their vehicles because it doesn't make the vehicle stop any faster. Let me know how that works out.
#105
Fluvial Geomorphologist
"My experience" = "butt dyno".
The scientific method exists to make comparisons relevant by changing only one variable. There is no rational basis to argue that "real world" driving is more representative when that includes continually changing multiple variables.
Automakers do a lot of things that don't serve any actual function because they know it helps sell more vehicles. Drilled/slotted rotors look sportier, so they add them on. Most spoilers/aero features do nothing for the cars they're on, but they look cool, so they add them on. I have the A-spec kit on my car because it looks good, not because it improves teh downforces.
Enjoy your cosmetic enhancements--there's nothing wrong with it!
Pair of TLs (04-06-2018)
#106
#107
BUTT-DYNO! Luv it!
I'm stealing that, just so you know.
Since I drive like an old man and never come close to over-working the brakes (or tires) I replace my OEMs (when they wear out) with slotted/drilled rotors 'cuz it looks cool. And I've never had a set wear out, and if I did, brakes on these babies are a piece of cake.
#108
BUTT-DYNO! Luv it!
They've always looked great to me. Especially behind some aftermarket wheels.
I've been thinking about the wheels I wanted to go with. I might put wheels on hold for the time being so I can make an actual decision on which ones I want to get. 18x9.5 or x10s is the specs I plan to go with. Not sure which wheels yet. Ugh. I'm sure by the end of the year, I'll end up having like 3 or 4 sets of wheels sitting at home. Lol.
#109
Got my EDFC in yesterday thanks to shayan! Can't wait to install it. Got some 25mm wheel spacers as well. Gotta get a strut bar from Heeltoe to be able to put the motors on the front.
#110
Finally got my 25mm spacers put on yesterday. Rides smooth. No vibrations. No rubbing. Gotta figure out where to mouth the EDFC control box tho. Hmmm.....
Gonna buy the RV6 strut bar this week so I can install the motors on all 4 corners next week.
Shadow2056 (04-19-2018)
#113
Perfect fitment
#114
Thanks! Now I'm waiting to be able to order my RV6 strut bar from Heeltoe so I can put this EDFC on! This is the suspension set up I've wanted since I was 18. I'm SOOO glad I didn't end up selling it.
Last things on the list for this car:
-J pipe
-Mufflers(still trying to decide if I'm gonna get the ATLP mufflers Heeltoe has or just some oval style).
-Type S ASpec front lip
-Some 18x9.5s or 18x10s
#115
-J pipe
-J pipe
#116
#117
Thanks. I have a couple of friends who've used them and love them with no issues. Mine ride great with no extra vibrations too.
#118
Pic I took the other night at work....I love this car. I need to get a new phone that can take some better pics at night. Lol.
Still on the list of mods:
-Oval style mufflersa
-J Pipe
-Install EDFC
-new tires
-Not sure if I want to do a Type S ASpec lip or just an STi lip
-J Pipe
-Install EDFC
-new tires
ACCURATEin (08-30-2018)
#120
I'm the same way. I don't want to do a lip without suspension.
The drop is without adjustment from Tein. Installed them right out the box. Love the drop. If/when I get some 18s, I'll have to drop the rear a little lower. Have it a balanced look all around.
