GP16's *Show Off Thread* Mystical Photoshoot! [Updated 7/24/17]
Old 02-03-2012, 05:52 PM
  #201
nivekov's Avatar
so much <3
guitarplayer16 (02-04-2012)
Old 02-04-2012, 01:49 PM
  #202
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Just bought my footwell LEDs
http://cgi.ebay.ca/ws/eBayISAPI.dll?...ht_4234wt_1163
Supposedly this listing DOES ship worldwide haha.
How do you guys think I should wire them?
1. When ANY door is open, they all turn on.
2. Have the footwell LED turn on only for the door that is opened.
3. Any front door open, turn on both the front footwells, any back door open, turn on both the back footwells.
I'm leaning more towards option 3.
What do you guys think?
Old 02-04-2012, 02:04 PM
  #203
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ LOL those are your options ? LOL
1> I dont think you can do that....
2> Yes....that is a good option....and very very easy....the wire just goes to the door switch
3> I dont think you can do that either....
In option 1 and 3 you will have to wire 1 LED module to more than 1 switch....so if both the doors are open you will be pumping a lot of current thro both the led bars....
have you considered the following options as well:
4> kill switch....turn on and off as you will....so you can wire the LED's to door switch and have another kill switch....so if you dont want them to come on with the door's just flip the switch....
5> kill switch....turn on and off as you will....wired to fuse #32....so they are ON all the time and you can turn em on and off as you will
6> fuse #32....ON ALL THE TIME.....
7> wired to the console....MAX brightness button....so you can use the console buttons to control the brightness....so looks like it came STOCK....
I had option 5....went to option 6....and now am trying to do option 7 LOL....
Old 02-04-2012, 02:25 PM
  #204
You're right, thanks swoosh.
I rethought it and now lauging at my disability of wiring lol
Old 02-04-2012, 02:48 PM
  #205
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
^^^That's how I have mine, although they are a subtle single led that mimics the intensity of the map light mood lighting...blue all around, under dash up front and under seats...wired in parallel...then tapped a wire from my parking lights wire to a toggle switch. If I leave it ON, they just come on when I turn on parking lights but I have option to switch off at all times.
Actually thinking of running some wires into the bay to put in an on/off switch for my DRL module...sometimes I feel like yellow light coming from my oem fogs as DRL's and sometimes I like the crisp white of parking lights or NOTHING AT ALL>
Old 02-04-2012, 02:52 PM
  #206
Damn I never knew you had footwell LEDS lol
I might just wire all 4 together and tap into the domes.
rockstar143 (02-04-2012)
Old 02-04-2012, 05:13 PM
  #207
Just be careful...pretty sure the domes are wired up to the multiplex unit...which is sensitive and if fried, an expensive fix. I lost my driver door courtesy light to a short I caused in it...not worth the fix but I wish I hadn't.
Old 02-04-2012, 05:15 PM
  #208
swoosh's Avatar
^^^ someone from the TSX side had wired em up that way without a problem....
and on you bring in your DRL's in GP's footwell leds ....sorry cudnt resist....LOL
Old 02-04-2012, 05:27 PM
  #209
attempted derail...
FAIL!
swoosh (02-04-2012)
Old 02-04-2012, 05:32 PM
  #210
swoosh's Avatar
^^^ gotta learn a lot from you J....
Old 02-04-2012, 06:33 PM
  #211
KarKraze's Avatar
My first visit to your thread and i must say that you car looks outstanding,very tastefully modded,keep up the good work.
Old 02-09-2012, 10:58 AM
  #212
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
I did my fronts to
any front door that opens my 2 front will turn on.
I'm debating if I even want to do footwells in the back of my 6.
Jeremy did you order that CCFL?
Old 02-09-2012, 11:44 AM
  #213
2014 Jeep SRT
ebelp's Avatar
Received 1,615 Likes on 1,030 Posts
Honestly, I don't see why any of these options wouldn't be possible....
1. Tap all LED's to the dome power.
2 .Tap each LED to the corresponding door power switch (as swoosh mentioned).
3. Wire both front LED's to the front driver AND passenger door power switch (that way if either front door is opened, the front LED's illuminate. Same with the rears...wire both rear LED's to both rear door switches. This option uses a lot more wiring, but should be feasible.
Old 02-09-2012, 01:13 PM
  #214
I did order the CCFL...actually, have 2 of them sitting on my breakfast nook as we speak. Will probably install this weekend.
J.
Also, Guitarplayer, did you end up making that DIY? I wanted to see how you made your reflector for the bulbs.
Old 02-09-2012, 01:19 PM
  #215
Flipster23's Avatar
Ok i'll be placing my order today as well.
Old 02-09-2012, 01:29 PM
  #216
swoosh's Avatar
am not saying its Impossible....what i meant John is, you will have to wire multiple led's to multiple places.....
i dont know how much power the dome unit sucks and to wire multiple LED strips to the dome unit in my head didnt make too much sense....
i wish there was a little module, like an AND gate we guys could use....that would be optimal
Old 02-09-2012, 01:47 PM
  #217
2014 Jeep SRT
ebelp's Avatar
You just tap the LED's into the interior (dome) lights' 12v source at the fuse panel. You don't literally run wire to the dome lights. I'm sure you knew that...just wanted to be clear.
Also, if your dome/interior lights are already LED's, then very little power should be "sucked".
Old 02-09-2012, 02:05 PM
  #218
swoosh's Avatar
^^^ true....i completely forgot about the dome LED part....
Old 02-09-2012, 02:20 PM
  #219
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
i remember i did that when i did my puddle light installation. had no idea i could tap into the fuse panel spot.
oh well
Old 02-09-2012, 02:31 PM
  #220
2014 Jeep SRT
ebelp's Avatar
Yeah, these little bad boys are key:
Old 02-09-2012, 02:41 PM
  #221
BANNED
^add a fuse?
i didn't want to tap into that bc then the puddle lights would be on whenever the car was.
Old 02-09-2012, 02:47 PM
  #222
2014 Jeep SRT
ebelp's Avatar
^ Depends on which fuse you tap into. If you tap into the interior light fuse, power will only be triggered when a door is open...which I assume is only time you want the puddle lights on..?
Old 02-09-2012, 02:50 PM
  #223
BANNED
^which fuse is for the courtesy lights?
i thought that particular fuse wasn't located in the fuse box were talking about. but another location further up towards the steering column.
Old 02-09-2012, 02:59 PM
  #224
2014 Jeep SRT
ebelp's Avatar
Fuse #6...located on the panel next to the dead pedal.
Old 02-09-2012, 03:03 PM
  #225
BANNED
Old 02-09-2012, 03:08 PM
  #226
swoosh's Avatar
where do you get all this stuff from Sharky hahahah lol....
Old 02-09-2012, 03:14 PM
  #227
BANNED
http://knowyourmeme.com/
Old 02-09-2012, 05:01 PM
  #228
Damn i thought this thread was dying until you guys had a whole convo lol
will be home to reply.
Bad news.
i feel my car has degrded a couple grand.
Something happened on the freeway
Old 02-09-2012, 05:04 PM
  #229
swoosh's Avatar
^^^ we love keeping good threads ALIVE
whats up with the car value going down ? Did you just hit a MILESTONE ?
Old 02-09-2012, 05:37 PM
  #230
Worst; damage.
Old 02-09-2012, 06:14 PM
  #231
If you can guide me through how to do number 3 I would give you a million kudos lol
How would I wire it two triggers, exactly?
If I can't do option #3 I'm just gonna tap into the fuse 6 (dome lights?) or tap into the wire indicated on this thread:
https://acurazine.com/forums/3g-tl-2004-2008-93/puddle-light-wiring-up-schematics-detailed-pics-835659/
What's the difference anyway?
J.
Get them installed tonight!
I have the DIY pretty much done.
Should I post it anyway?
Old 02-09-2012, 06:21 PM
  #232
About the damage my car incurred on the freeway...
I was driving down the freeway, in the middle lane.
The 300C infront runs over what looked like a metal ladder , but it ended up being something plastic and HARD. Well, you guessed it.
Hard plastic pieces all came flying into my car.
I'm not trying to blame the car infront.
They tried to swerve into the other lane to dodge the thing, and that's how I saw the debris, when they moved over a little lol
They were blocked in or something and it was too late.
It was pretty loud. A piece managed to smack the windshield which scared me the most.
So I pulled over, and checked out the damage to the front.
I didn't see any.
Then I got home and noticed my driver's side is all scratched and paint chipped, and I got creased dents (front the road debris that smoked my car).
The A-Spec sideskirt is scuffed and scratched, and I have many random scratches on my roof (probably the piece that smacked my windshield and deflected along my roof?). IDK. There was like 10 pieces that came flying into my car. Scratch on the side of my rear bumper.
It's RANDOM as hell where the damages happened because like 10 thigns hit my car.
It's not like "oh, a piece of wood kicked up and hit my door". Man, damages are everywhere and random.
Pics soon...
Old 02-09-2012, 08:04 PM
  #233
Wow...I'm really sorry to hear that, man. Let's see some pics. I hope it's fixable.
PS...about messing around with using fuse 6...be VERY careful as that fuse is linked to the multiplex control unit and if you short it out, it's a very expensive and PITA piece to fix. I would absolutely NOT touch fuse 6 for any of our mods. It is also the fuse for keyless entry, dome lights, alarm...the list goes on.
Old 02-09-2012, 08:25 PM
  #234
Ah, thanks for the warning!
I guess I'll just ask Roger555.
He's been very helpful and a huge part of the success of my car lol
From Accord fogs, to blacking out headlights, to now footwell lighting lol
He knows his stuff!
As for the damage, definitely fixable.
The dent I can't fix myself, though.
As for the paint chip and scratches, I could probably use touchup paint.
I could also try buffing most of it out. We'll see. Way to cold to do anything right now, though.
Oh, and check the 3G TL general forum for my DIY.
Old 02-09-2012, 08:33 PM
  #235
Ok, will look for it. Thanks man...
Yeah, I mean, I'm sure you CAN use FUSE #6 but I had a short in the courtesy light that I caused when running my wires and MAN, what a PITA...fuse 6 wouldn't hold a fuse it would just pop and I'd lose everything...2 days with no keyless/lights/alarm etc...finally I jumpered it out and fried the short circuit in the multiplex permanently. Oh well.
Old 02-09-2012, 09:08 PM
  #236
Thanks man.
I remember that
rockstar143 (02-10-2012)
Old 02-09-2012, 09:28 PM
  #237
Bone stock tl-s
jptl04's Avatar
sorry about the accident mishap. i know the feeling. something similar happened to me while driving behind a semi truck, it kicked up some freeway debris that i couldnt avoid damaging my front bumper. needless to say it needs to be repainted.
cold cathodes look nice! the foil tape is the key. i guess you managed to see the DIY link before it expired. it was one of my first mods on my 07. easy and cheap.
Old 02-09-2012, 09:32 PM
  #238
I'm Craig
cjTL's Avatar
That sucks to hear about your little incident tonight.
Old 02-09-2012, 11:02 PM
  #239
swoosh's Avatar
HOLY SHIT DUDE !!!
glad nothing MAJOR happened....i hope the damage is fixable....insurance should/will cover this right ?
Old 02-12-2012, 09:54 AM
  #240
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
DIY Post #1 updated today.
Quick Reply: GP16's *Show Off Thread* Mystical Photoshoot! [Updated 7/24/17]
