Burtch07's CGP Build
Old 04-07-2018, 02:00 PM
  #361
Burtch07's Avatar
Originally Posted by 90foxnotch
Just read through this whole thread and I lol'd at work like 3x, Car looks awesome. Inspiring me to put the Koni yellows/ H and R springs on this spring. Great Work
Thanks man! It’s nice to have people appreciate the hard work. Drop it! Only way to drive is slow and low
Old 04-07-2018, 02:13 PM
  #362
Burtch07's Avatar
It’s still not spring here in Michigan!!
So again yet again I went for MX over mods!! I replaced my old worm OEM rotors and pads with these drilled/slotted joints. I also painted the calipers (properly) red to match the new lugs tat will be going on. I’ll get that Aspec one day....hopefully. I’ll do the rears in a few weeks, let’s pray it warms up by then.
Old 04-07-2018, 02:57 PM
  #363
Burtch07's Avatar
Originally Posted by exiLe
Butch, read through your whole thread and I either missed it or you never posted any more detailed shots of your exhaust tip setup and the specs on the tips.
From what I can tell your removed the black plastic portion around the tip outlet and spaced the tips outwards a bit more. Are the tip 3.5" in diameter? That's what I'm hoping to do on my base bumper as well.
Any guidance would be greatly appreciated!
Correct, the shop I took it to in SLC relived the black plastic piece, cut the tip length down as well as the exhaust, then tweaked em outwards. I do believe the tips are 3-3.5”. I can’t recall honestly
Old 04-09-2018, 07:57 PM
  #364
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Good looking rotors.
Old 04-09-2018, 11:17 PM
  #365
Burtch07's Avatar
Thank you kind sir
Old 05-04-2018, 10:40 PM
  #366
Burtch07's Avatar
So i sold the Niche’s and I’m looking at changing the wheel set up. So far I’m leaning toward the Avid AV20 or Avid AV32. I’m going with 18’s this time around for ride comfort and so i don’t have to raise to the TL, I likes it low!! Question is what width and offset will help me accomplish a flush to the fender look? I’m also running15MM spacers on all four corners. Open to all suggestions. I can’t keep it like this for long, the wife is hounding me!!
Old 05-06-2018, 07:36 AM
  #367
Burtch07's Avatar
So I decided to go with the Avid1 AV20 version in white w/ specs of 18X9.5 +22 offset. Going to take the spacers off as well. So another question is what is a optimal tire size? I was thinking 215/40 but I also want a more comfy ride. Suggestions?
Old 05-07-2018, 09:38 AM
  #368
BreezyTL's Avatar
215 on a 9.5 isn't going to be comfy. That's like a fat man in skinny jeans!
Old 05-07-2018, 08:44 PM
  #369
Burtch07's Avatar
hahahaha dood I got a good visual! Yea I ordered the wheels today and I think I’m going to go with 235/40 after talking to Numriah
Old 05-11-2018, 07:40 PM
  #370
Burtch07's Avatar
Finallly!! Really liking these more than the Niche’s
Avid1 AV20
Old 05-12-2018, 08:04 PM
  #371
Burtch07's Avatar
ordered a set of Nankang tires in 235/40, should be here in the 17th hopefully get them mounted/balanced and on the car next weekend
Old 05-13-2018, 04:56 PM
  #372
Burtch07's Avatar
I’ve been so super excited to get these on! Looking at the pics they poke out quite a bit, going to have to run some negative camber for sure. Since moving to Michigan the TL is a summer ride only. Thoughts??
Old 05-13-2018, 08:43 PM
  #373
BreezyTL's Avatar
Those fronts look like they will be a pain in the ass...
Old 05-14-2018, 12:58 PM
  #374
Burtch07's Avatar
Oh I know! No doubt it’ll have to raised up! I’m scared to see what it looks like after all back together hahahahaha
Old 05-15-2018, 03:33 PM
  #375
Shadow2056's Avatar
White wheels on a grey car. Perfect color combo!
Old 05-15-2018, 07:29 PM
  #376
Burtch07's Avatar
Thanks Shadow! I’ve been changed the color of my old wheels a million times, white just looked best. Now time to get rubber on em
Old 05-19-2018, 11:43 AM
  #377
Shadow2056's Avatar
Can't wait to see it man. Makes me want to go with some white wheels like I originally planned.
Old 05-19-2018, 10:54 PM
  #378
Burtch07's Avatar
Old 05-20-2018, 12:18 PM
  #379
BreezyTL's Avatar
Bout time!
Old 05-20-2018, 02:03 PM
  #380
Burtch07's Avatar
Bout time!
So here’s a few shots from the garage. Still have to bleed the brakes one more time and put new 3M tape on the rear visor, so please go easy on me because I know it’s a filthy whore right now!
Old 05-20-2018, 04:15 PM
  #381
Burtch07's Avatar
Bath time
Old 05-21-2018, 01:21 AM
  #382
UA6MT
numairh's Avatar
Wow, the new setup looks phenomenal! I love the color combo, fitment, etc. Great work!
Old 05-21-2018, 07:35 AM
  #383
racerock's Avatar
Lift...
In looking at your garage, looks like the builder saved abotu $100 and put standard doors in. You can still convert to "High Lift" Doors and get a lift (or two) in your garage
- There is a person in the midwest that can spec and send the parts you need
- Takes about a day of mods per door. More on the first if you take your time
- Need to get a shaft driven opener (much quieter) like a LIftmaster
- Then get a nice two post assimetric and put your jack stands away.
- Impressed you have a drain.
Old 05-21-2018, 04:07 PM
  #384
BreezyTL's Avatar
I'd kill for that garage!
Old 05-21-2018, 10:49 PM
  #385
Burtch07's Avatar
The garage is a mess and will be cleaned up this weekend!! My 3rd car spot is used table saw and other shop items for the wife’s Etsy business. As far as a lift I’d be nice but I don’t plan on staying here in Michigan long term. With that being said Breezy the house will be up for sale in 3 years if you want 1st dibs!
BreezyTL (05-22-2018)
Old 05-22-2018, 08:14 AM
  #386
90foxnotch's Avatar
That looks great, definitely nailed the color combo
Old 05-22-2018, 09:57 AM
  #387
BreezyTL's Avatar
What does the rest of it look like? Cost?
Old 05-23-2018, 08:14 PM
  #388
Burtch07's Avatar
Don’t mind the kiddie pool
The house is actually really nice! 4 bed, 3 bath, fully finished basement, and about 2500 sq ft. I believe we paid around 240K for it, maybe 230K.
Old 05-24-2018, 08:29 AM
  #389
90foxnotch's Avatar
House looks really nice man and so does the car in the evening damn. Just curious where in Michigan are you?
Old 05-24-2018, 08:50 AM
  #390
BreezyTL's Avatar
No exterior lights? I don't want it! haha
Nice looking place. Wish I had a 3 car garage, hell I'd take a 2.5 at this point. My 2 car is tight with both in there. Can't have anything on the walls and its not super deep so you walk out of the door to the house and you are on the bumper of what ever car is there... Never again will I have a 2 car garage, but for a first house and a budget you have to compromise a little.
Old 05-24-2018, 09:54 AM
  #391
Shadow2056's Avatar
Wheels look great mounted man!
Old 05-24-2018, 08:23 PM
  #392
racerock's Avatar
Nice house and home. You should be proud.
Nice Flex as well. I like the flag on the rear window.
Congrats on doing well.
Old 05-26-2018, 09:12 PM
  #393
Burtch07's Avatar
We have outside lights, they’re just recessed under the awning near the garage doors. The neighborhood is really nice and I can’t complain. Thanks for all the compliments fellas
Old 05-26-2018, 09:15 PM
  #394
Burtch07's Avatar
Aspec keeps slipping away!!
So I had half the cash saved up for that Aspec kit but I am electing to do a repaint on the front end, hood, and 2 fenders. I was quoted at 1700 which I thought was more than reasonable. Aspec will have to wait yet again
Old 05-29-2018, 09:44 AM
  #395
BreezyTL's Avatar
You know I still have a set of black seat belts!
Old 05-29-2018, 10:51 PM
  #396
Burtch07's Avatar
I need those in my life! I just have to many other maintenance issues I need to address 1st
Did take me lady out for a drink tonight. I parallel park and she says why so far away? I said girl Poppa and get close to scuff them new shoes!!
Old 05-31-2018, 01:54 PM
  #397
Shadow2056's Avatar
New shoes look great man!
What did you do to your fogs to get them that color?
Old 05-31-2018, 07:37 PM
  #398
Burtch07's Avatar
I ordered em like that, thinking about going back to clear fogs and I might put them up for sale.
Shadow2056 (06-05-2018)
Old 06-03-2018, 09:21 PM
  #399
UA6MT
numairh's Avatar
I really dig the new setup! You pulled off the EZ lip very nicely too. Loving it, keep it up!
Old 06-05-2018, 05:35 PM
  #400
Burtch07's Avatar
I loved the EZ lip but it came off too EZ hahahahaha! I’m looking into something more permanent
AfilthyHOBO
01-29-2020 04:12 AM
Quick Reply: Burtch07's CGP Build
