The $200 '04 TL scenario
Old 04-11-2018, 07:55 PM
  #81
Pair of TLs's Avatar
Wow, nice work so far!
For $200, a few parts and some elbow grease you guys have come a long way and we're all looking forward to updates.
(I'd subscribe to this thread if I knew how.)
Now you'll need a little patience--drilling out the broken PS mount bolts and retapping will be fun.
Unless--does anyone know--do these capture nuts slide into the frame and can they be replaced? Take a look...
But we're here to cheer you on!
Old 04-12-2018, 10:05 AM
  #82
brotatertot's Avatar
Originally Posted by losiglow
Autolites
Based on the previous owner of the car, it's likely that a mechanic replaced those plugs. Do they not even look at the shop manual when servicing cars anymore?
Sweet project so far. That's a lot of work. Love your profile pic BTW.
Thanks! Yeah that was a result of way too much boredom in one sitting lol.
I'm willing to bet the mechanic was employed at an independent shop, most will do whatever it takes to sell a job.
Thanks! Unfortunately they do fasten like that, bummer is it would be a lot harder because there's multiple layers of steel to drill through underneath. It was quoted to be a 7hr job, because the subframe needs to be dropped, a smaller drill can fit down from the top for one bolt, but not for the other.
Old 04-12-2018, 12:20 PM
  #83
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Might be able to only loosen the subframe instead of dropping completely, thus do it in the driveway/garage instead of on a lift.
Old 04-18-2018, 08:14 PM
  #84
treal512's Avatar
Loving this thread so far! I've been sidelining all my new parts since last year, but this here is pretty motivating. Thank you for sharing, sir.
Why are you jealous? He spent $50K on a Civic, and you spent $200 on a luxury car.
LOL, right? But he has no understeer
Old 04-19-2018, 09:23 AM
  #85
Motivation is hard to come by for me as well, there's more to come!
Old 04-19-2018, 09:42 AM
  #86
Had an extra can of Seafoam I found in the garage, so Brian & I loaded this bitch full of it & smoked out..
It does run & start a bit smoother now.
Old 04-19-2018, 10:02 AM
  #87
There were a couple more mounts that needed to be replaced, so I tackled that while changing the oil.
There's a slight film of sludge all over the inside of the engine, I noticed this under the cap, I think I might investigate some flushes in the near future.
Old 04-19-2018, 10:12 AM
  #88
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Hmmm, that looks like a small amount of either coolant or condensation water emulsified with oil. If it is only on the (relatively cool) oil filler cap, no harm, no foul; however, if it is all over inside the engine I'd be looking for a culprit (leaking head gasket or something).
Old 04-19-2018, 10:15 AM
  #89
Received 8,568 Likes on 6,621 Posts
Yeah that's quite sludgy and almost milky brown..
Do you know if there's any issues with the HG or coolant/water going in? Judging by the sludge, i'm not surprised the seafoam was that smoky
Old 04-19-2018, 10:33 AM
  #90
A bad head gasket is what we've been leaning towards as mentioned previously, kind of a bummer, looks like it's been bad for quite a while..
Old 04-19-2018, 10:35 AM
  #91
rockstar143's Avatar
Received 19,914 Likes on 14,457 Posts
I don't like it that color...that might be bad.
Good job on the mounts!
Old 04-19-2018, 10:41 AM
  #92
Thanks! Yeah me either, & with its mileage being 268,000 I'd almost just replace the motor, who knows what it's been through on that long & brutal journey.
Old 04-19-2018, 11:03 AM
  #93
i don't read, i just look at the pictures
Old 04-19-2018, 11:04 AM
  #94
careful... if you give a mouse a cookie it's going to lead down to,
well.. might as well drop a J35A8 in there.. oh and a J37 TB and IM.. oh and 6 speed swap it..
Old 04-19-2018, 11:07 AM
  #95
Brian had time to buff it out, first with compound, then back over it with a machine glaze, I followed behind with a paste wax afterwards.
50/50 for comparison
Old 04-19-2018, 11:08 AM
  #96
Although.. at the rate you guys are working, it might be worthwhile to do just that.. it's going to be a CLEAN AF car when you guys are all done
Old 04-19-2018, 11:22 AM
  #97
Haha, I remember days like that, I've had to trade in all my cool kid ways for dumb stuff like a mortgage, lawn mower, 401k, sedan(s), stress & cheap beer.
Old 04-19-2018, 11:24 AM
  #98
looking fucking good, man.!
Old 04-19-2018, 11:27 AM
  #99
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
good job on works so far, at this rate mind as well restore the whole car. That paint correction and the headlight doesn't goes together.
Old 04-19-2018, 11:43 AM
  #100
edit*
Old 04-19-2018, 11:47 AM
  #101
Thanks guys! Yes the headlight is next ion the list, then more attention to painting both bumpers.
Here are some after shots in the sun, it's got a lot more depth & clarity.
Old 04-19-2018, 12:17 PM
  #102
90foxnotch's Avatar
That's looking really good. My f150 does that same pudding under the cap and I was advised it was just condensation causing it usually in the winter time, so hopefully it's good to go. I almost want to donate a new fender for that poor car haha Keep up the good work man
Old 04-25-2018, 09:42 AM
  #103
Brian buffed the headlight while I started bodywork on the rear, Here are the before and after results of his work.
After sanding
After polish
We both worked on the broken off steering rack bolts, but had no luck. The rack can be safely moved far enough to remove the front bolt, but our bits aren't really biting, I think the problem is our current easy-out set.
Old 04-25-2018, 10:14 AM
  #104
MyGuti's Avatar
I'm still amazed at what a lil TLC can achieve, especially on the headlights!
Old 04-25-2018, 10:45 AM
  #105
Hope you clear coat the headlights after polishing so they stay mint!
Old 04-25-2018, 11:08 AM
  #106
90foxnotch's Avatar
Those look really good, +1 on a UV protectant or clear coat, Good luck with the rack
Old 04-25-2018, 11:12 AM
  #107
No just wax, I'm more concerned with the steering rack right now, it's making or breaking the car at this point unfortunately. I'd rather not spend 7-$800 to have a shop drop the sub-frame, but it might come to that.
Old 04-25-2018, 10:31 PM
  #108
truonghthe's Avatar
gotta drop the sub frame if you planning to remove that broken bolt, if you can get your hand on a lift. IT keep me wonder what the hell the previous owner run over? a mountain?
Old 04-26-2018, 09:36 AM
  #109
I bet it happened the same time the fender got pushed in, one of the wheels is a different production with the squared off valve stem relief, probably cracked the original wheel as well.
Old 04-26-2018, 10:04 AM
  #110
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I was quoted a couple of hours of labour to replace engine mounts by dropping the subframe. $700-$800 is insane...
Old 04-26-2018, 10:45 AM
  #111
Latent car nut
horseshoez's Avatar
Sounds about right; hence the fact I had all of my engine and transmission mounts done when the subframe was down for the new clutch.
Old 04-26-2018, 03:44 PM
  #112
I called the local dealer for estimates, I'm sure other places are cheaper.
I installed all of my mounts through the top side of the car, using extensions & a floor jack for support, sounds weird that they'd drop the sub-frame for that, it took me a shade over 2hrs to do them all....with one arm.
Old 04-26-2018, 03:56 PM
  #113
The shop was having a 50% off labour rate and I got my brake fluid changed for $30. After I left their shop I called and I asked them about changing engine mounts and they told me 2-3 hours doing it by dropping the subframe and they always drop subframe to do engine mounts.
I told them it's well known online to just use a jack and do it from the top and that's where I went wrong; they took offense to my question because I guess I crossed the boundary of "telling them how to do their job".
Needless to say, I ended up doing them myself.
Old 04-26-2018, 03:59 PM
  #114
Needless to say. I ultimately did them myself.
I gotcha, that can be a difficult situation, it's frustrated me a time or two.
Old 04-26-2018, 09:13 PM
  #115
truonghthe's Avatar
According to your description that wheel belong to a 06 model as its the first year of TL has TPMS.
I don't think it gonna cost you $800 for dropping the sub-frame as most engine harness connector need to be disconnected along the radiator hose. After that it a pretty straight forward IF you got a lift that is.
Old 04-27-2018, 05:52 AM
  #116
iWhine S/C 6MT TL
04WDPSeDaN's Avatar
Received 2,563 Likes on 1,317 Posts
At $200, the vehicle doesn't really owe you guys anything. I was more concern about the horrific body repair that was done to this car. You can see the radiator support was replaced and the panels up front are still misaligned. It's had a real rough life and just put back together with the bare amount of money. My honest suggestion is to buy this cradle https://www.ebay.com/itm/2004-2006-A...lXwz4e&vxp=mtr and do the swap. A lot of members here have dropped their cradles to do work. And if you don't have one, you could use this engine support bar Blackhawk BH2700 Jack, Bottle - Lifting Equipment It's $49.00. Another cheap solution, go to home depot and buy some 2x4's, cut 3x of them to fit from the inner part of fender to fender and screw all 3x 2x4's together. Use a chain around them and hook to the engine.
Option 2, drop it yourself and redo the threads.
Option 3, shop around for prices to do the job.
I only suggest replacing the sub frame because I have a feeling it's been abused and could be tweaked from whatever accident(s) it had.
Old 04-27-2018, 09:06 AM
  #117
but then nothing they hammered into place to fit on the old twisted subframe will fit!
Old 04-27-2018, 10:05 AM
  #118
I was more so looking at all the variables involved and where to stop putting money into it, I would also hate to have spent money on parts only to unearth other problem(s). Part of the attraction to this was to ultimately having something for next to nothing, so far we are up to about $650 total, and it's liquid value is probably only about $1500 in it's current state. I also have a full driveway now with 2 other projects on hold that need my attention, I said in the beginning if it gave us a bunch of hassle, then it's getting 86ed. We'll see how it plays out.
Old 04-27-2018, 10:11 AM
  #119
I wish I was smart enough to keep my projects cheap.
Old 04-27-2018, 10:24 AM
  #120
But cheap projects aren't any fun!
Quick Reply: The $200 '04 TL scenario
