DVD-Audio Primer
#161
Originally Posted by vipvop
Re: humans hearing sounds that have a frequency of 44,100 HZ or more - I thought our hearing maxes out at 20,000 HZ? Allowing for the nyquist theorem (highest frequency that can be recorded without aliasing is half that of the sampling rate) a CD should still be able to get frequences of 22,050 HZ onto it, which should still be higher than our hearing...
@ 44.1kHz the sampling is just at the bare minimum to reproduce it. If you got to say 10x that so 200kHz the signal is captured almost perfectly (within limits of the ADC). Even at 5x the improvement is very noticable when compares to 2.2x that CDs are. There are many debates about what the human can really hear and what effects the upper harmonics have on the perception of sound.
#162
I've searched this thread and some slight mention, but didn't see a definite answer here or in the manual. With a DVD-Audio disc is there a way in the TL to select the 2-channel layer instead of the multi-channel layer? I couldn't locate a setting that would let me listen to the 192/24 instead. Thanks in advance.
#163
The one disc I have (Sinatra At The Sands) has 192/24 Advanced Res Stereo and can be accessed by the menu. Unfortunately, there is no way you can access the menu through the ELS. Or try changing groups by holding the scan and repeat buttons simultaneously till you get a beep. If should change to group 2 and that maybe the 2 channel layer. I'm shootin in the dark here.
#164
Well the one disc I have is the Seal Best of 1991-2004 which has DVD-Audio 5.1 plus 5.1 for Acoustic tracks. Gotta figure out how to access these additional tracks.
#165
#166
Originally Posted by bigman606
Hawhyen51 is the winner. Yes, if you want to hear the other Group on a DVD-A, then pressing SCAN & REPEAT buttons will give you a beep and the display will register Group 2. Good job. Thanks for all your help. Oh and the Seal Best 1991-2004 DVD-Audio disc is fantastic - great acoustic tracks too.
#167
Originally Posted by That Girl
This DVD -A that is in the new 2004 tl will not play regualr C'D's ?
I am not into technical things' but I love my music .does this mean I can't play my regular C'D's ..and that I'll have to buy DVD-A music ,where there is not many choices of songs' because not much music is out yet for DVD-A .!
It plays both
#168
DVD Concerts--Converting audio to playable format for TL
Any new ideas on how to convert my legit DVD collection into playable stereo files that can be read by the TL drive? I won't cry about losing the 5.1 on the originals that have it if the quality is still decent. To boot, it would be cool to get these DVD songs onto my Ipod.
#169
#170
I'm a new TL owner, and I learned the hard way that the John Mayer Heavier Things DualDisc I bought won't play in my TL (not the DVD side, anyway).
Does this mean that pretty much any Sony DualDisc will not be compatible with DVD-A? At this point, I'm assuming that unless I see "DVD-Audio" somewhere on the CD cover, it won't play in my system. This sort of sucks, because there are a lot of titles I'm interested in that come in DualDisc format.
#171
CD or XM
Question I did not find covered in this thread. Does the TL audio system simulate 5.1 or surround sound when playing a CD or XM as a home theatre system could, or does it only play them in conventional 2 channel stereo?
#172
MonkeyTrucker
12-12-2017 08:59 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
sailorman
02-28-2006 02:42 PM
