Aftermarket rotors/caliper for 2007 TL
Old 09-24-2018, 11:21 AM
VictorTL's Avatar
Hi. Where is a good place to buy aftermarket rotors and caliper. My rear left caliper is stuck/sticks and creating heat. I lubed the caliper pins but it doesn’t help. I don’t want to replace the rotor and pads without fixing the sticky caliper first.
Old 09-24-2018, 11:24 AM
VictorTL's Avatar
Here is my rear rotor
Received 16,260 Likes on 11,971 Posts
rockauto, ebay, amazon
Old 09-24-2018, 11:31 AM
VictorTL's Avatar
do you recommend any particular brand?
Old 09-24-2018, 11:38 AM
wusty23jd's Avatar
Go with an OEM caliper and chose whatever brake pads and rotors you like. There are about a billion threads on this topic already and your choice is dependent upon what you want to achieve from your setup.
Rotors are rotors are for the most part. If you have a daily driver and don't care that much about street performance or looks, head on over to Autozone and pick up a cheap set. Otherwise, do some research and figure out what you'd like.
I personally like Centric blank rotors with the painted hub and lip. I like to compliment the rotors with Akebono ceramic brake pads since I'm not a fan of brake dust. I'm not racing on the streets, so I can sacrifice a little stopping power for lower dust.
Old 09-24-2018, 11:49 AM
VictorTL's Avatar
Ok. Thank the oem caliper are too expensive.
Old 09-24-2018, 12:02 PM
get in where you fit in
Old 09-24-2018, 12:27 PM
Jeff2018Acura's Avatar
I always use SP Performance for my brakes. The quality is amazing and their customer service is second to none. I highly recommend them.
Old 09-24-2018, 01:04 PM
Received 8,582 Likes on 6,629 Posts
rockauto.com has OEM replacements.
Old 09-24-2018, 01:55 PM
VictorTL's Avatar
thank tou sir!! Do you know how to fix the sticking rear caliper? What is causing the sticking, corrosion caliper piston or collapse brake hose closed to the caliper?
Old 09-24-2018, 01:57 PM
Typically corrosion in the pins so people end up rebuilding them with new seals and use a wire brush /drill attachment to clean up the corrosion inside.
You can actually buy the rebuild set as well
https://www.oemacuraparts.com/v-2007...is--rear-brake
Old 09-24-2018, 05:32 PM
VictorTL's Avatar
One more question. What is the best method to remove the two screws holding the rotor without a power tool or power drill? I will be working on the street without any AC outlet available.
Old 09-24-2018, 05:40 PM
wusty23jd's Avatar
PB Blaster and an impact screwdriver will be the tools you want to start with. If possible, try to find a Japanese Industrial Standard (JIS) bit to use instead of the normal Phillip's head bit as well. It might help the process.
If the screws don't budge after using the above items, you may have to try using a MAP torch.
Two weeks ago, it took me almost 15 minutes/screw with my wife's RDX. They just would not budge, but patience is key!
Old 09-24-2018, 05:59 PM
VictorTL's Avatar
Thanks for the tips!
Old 09-24-2018, 09:21 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
Rockauto.com should have everything you need. The caliper piston probably has rust inside causing the sticking! When is the last time you changed the full brake fluid? Brake fluid absorbs water and can rust the brake system from the inside out so you need to replace the brake fluid completely every 2-3 years MAX
Old 09-24-2018, 09:38 PM
VictorTL's Avatar
i will do a brake fluid flush soon
Old 10-13-2018, 09:47 PM
VictorTL's Avatar
Before I order these parts can someone verify they will fit 2007 Acura TL? Thanks
Akebono ACT787 ProACT - front brake pad
Akebono ACT536 ProACT - rear brake pad
Centric 120.40046 - front rotor
Centric 120.40061 - rear rotor
Old 10-14-2018, 07:59 AM
Turbonut's Avatar
All correct for '07 TL
Use 933364788182531 and receive 5% discount on parts, expires 12/2/2018
Old 10-14-2018, 09:27 AM
VictorTL's Avatar
Thanks! Another question. I want to do a brake fluid flush before changing the rotors and pads. How many bottles of Honda brake fluid do I need ? 2 or 3 bottles?
thanks
Old 10-14-2018, 06:39 PM
VictorTL's Avatar
I changed all 4 rotors and installed brand new pads and the damn left rear caliper is still bitting onto the pad and not freely moving back after releasing the brake. I think I have a stuck or sticky piston. When I changed the pads I noticed strong resistance with the C-clamp that I was trying to push the piston back. Anybody knows what is the aftermarket brand that is as good as the OEM? Thanks
Old 10-14-2018, 07:26 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Not uncommon for Honda brake calipers. Between 2014 and 2016 I had to replace all four calipers on my Accord, and they are the same basic design as the ones on the TL.
Old 10-15-2018, 05:16 AM
WDPanda's Avatar
Why did you change the rotors/pads before the caliper when you even said you should?
You can warp your new set in no time.
have your current OEM caliper rebuilt.
Old 10-15-2018, 09:03 AM
djw88's Avatar
thanks
just buy a large bottle from the parts store doesn't need to be Honda stuff. you can buy re-manufactured calipers from any parts store bring your old one with to make sure its the same and you will give them your old one to so you don't have a core charge.
Old 10-15-2018, 11:39 AM
BROlando's Avatar
Received 1,163 Likes on 874 Posts
A parts store caliper will work, and usually has a lifetime warranty. No, its not anywhere near as good as OEM. But again...warranty.
This problem probably occured from lack of brake fluid flushes, BTW. It causes rust to form inside the lines.
Old 10-15-2018, 03:42 PM
VictorTL's Avatar
Ok thanks everyone. I just want to make non Honda brake fluid is safe to use.
One more issue. The backing plate shield is completely rot to hell and I just ripped off the entire plate to make it look clean. I read online that it’s not necessary need it and trying to install it is a lot of work.
Old 10-15-2018, 05:42 PM
wusty23jd's Avatar
You should definitely use a backing plate. If you don’t have one, go to your local auto parts store and buy a brake hardware kit.
Old 10-15-2018, 06:03 PM
https://www.oemacuraparts.com/v-2007...-front-brake-1
It's 26 dollars for OEM..
Old 10-15-2018, 06:52 PM
VictorTL's Avatar
The part is reasonable priced but it’s too much work to install.
Old 10-15-2018, 06:59 PM
yeah gotta remove the hub apparently
just cut it off and hope nothing hits the backside of your brakes while driving
Old 10-16-2018, 09:27 AM
djw88's Avatar
yes non honda brand brake fluid is perfectly fine. backing plate is to prevent crap from the road from hitting your rotor and getting between the rotor and pad. may be fine without it but I'd replace it if you care about your car.
oh and FYI re-manufactured calipers are just rebuild OEM ones if you didn't already know
Old 10-16-2018, 10:31 AM
VictorTL's Avatar
Thank you guys!! Just one more thing. The E brake pad is almost gone. Should I go back and install the E brake pad? How often you need the E brake? I never used it
Old 10-16-2018, 11:01 AM
why not, you're already pulling off your calipers and rotors..
Old 10-17-2018, 07:12 PM
VictorTL's Avatar
Question on parking brake shoe part 43154-S47-N01 . Does this only one brake shoe for that price? I assume Acura doesn’t sell them as a set like a regular brake pad.
Old 10-18-2018, 11:02 AM
It's per shoe.. so you'll need 4
Old 10-18-2018, 01:37 PM
VictorTL's Avatar
Ok thank
Old 10-20-2018, 10:47 AM
VictorTL's Avatar
Is it Ok to use this brake fluid for flushing?
Prestone high temp synthetic brake fluid
is it ok to mix with Honda brake fluid?
Old 10-20-2018, 10:50 AM
djw88's Avatar
as long as they are both dot3 it will be fine.
Old 10-20-2018, 11:14 AM
Latent car nut
horseshoez's Avatar
All DOT3 and DOT4 brake fluids are compatible; you can even mix them.
Old 10-20-2018, 01:44 PM
VictorTL's Avatar
Thank you
Old 10-20-2018, 03:49 PM
08 TL type-S
StealthTL-S's Avatar
Thanks for this thread! I got some oem copys by Centric, they've changed OEM number to Centric 30110010. look forward to the pads! I put on the aftermarket from O'reilly's Carbon Metallic, they squeak , and squeak, and squeak again... I want some ceramic oem.....
Ceramic Pads w/ShimsCentric's engineering team carefully selects and tests each friction compound to ensure proper stopping performance throughout the lifetime of the brake pad. With three in-house brake dyno's and real-time vehicle testing Centric is the aftermarket leader in brake pads and shoes.
Features:
  • 100% shimmed to eliminate noise and vibration.
  • Positive molded.
  • Specialized ceramic friction formulas provide excellent stopping power.
  • Ceramic friction compounds provide extended pad life.
  • Linear response both cold and hot; never "grabby".
  • Low dust formulations keep wheels clean.
  • 100% Asbestos-free formulas.
  • Scorched for improved bed-in.
CENTRIC Warranty Information:
90 days/3,000 miles
Quick Reply: Aftermarket rotors/caliper for 2007 TL
