Acura ServiceNews Bulletins
Old 06-12-2008, 03:15 PM
  #81
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
Originally Posted by Ron A
It must be Honda. I did what I always do, which is copy the preceding month's data and then change the month code and the actual month, and it still doesn't work.
Maybe there's something in it they didn't want to get out, or whatever.
I'll check it occasionally and see if it comes back or if I can find out what's wrong.
Thanks Ron A.
I can't see PDF addresses anymore or I would've tried that myself. New laptop, new setting and PDF's open in the reader instead of as a webpage.
Old 06-12-2008, 07:46 PM
  #82
A_UFO's Avatar
They still have each item as a seperate PDF.
http://www.in.honda.com/Rjanisis/pubs/SN/B08030A.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030B.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030C.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030D.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030E.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030F.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030G.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030H.PDF
http://www.in.honda.com/Rjanisis/pubs/SN/B08030I.PDF
Why? I have no idea.
Old 06-17-2008, 03:57 PM
  #83
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
The original March 2008 is working again.
Old 07-02-2008, 10:28 PM
  #84
Administrator
Ron A's Avatar
June 2008 added.
Major topics for 3G TL:
The Best Way to Unwrap a New Oil Filter (applies to all cars-good information)
AIRBAG OFF Indicator Turns On and Off With Front Seat Occupied (05-08TL)
Old 08-05-2008, 09:08 AM
  #85
Administrator
Ron A's Avatar
July 2008 added.
Major topics applicable to 3G and 4G TL:
New Microphone Assembly Improves Voice Command Recognition (09 TL only)
Use Torque Screwdriver to Tighten TPMS Valve Stem Nuts to Spec (06-09 TL)
Old 09-02-2008, 09:43 AM
  #86
Administrator
Ron A's Avatar
August 2008 added.
Dead Battery? Check for a Bad HFL Control Unit (07-08TL)
15 pages this month but only one topic for us. And that one is more for the techs than the owners but included it for info purposes.
Old 10-02-2008, 10:22 AM
  #87
Administrator
Ron A's Avatar
September 2008 added.
Sorry, nothing new for you guys this month.
Old 11-02-2008, 10:08 AM
  #88
Administrator
Ron A's Avatar
October 2008 added.
Can't Find the XM Radio ID? Just View It Electronically (04-09TL)
Body Creaks: Some Handy Tips to Find and Eliminate Them
Old 11-09-2008, 08:38 AM
  #89
sb_mech22's Avatar
wow thanks soo much for this info, this post was def. a great sticky candidate...thanks again
Old 11-09-2008, 11:18 AM
  #90
gkr-718's Avatar
great info thx
Old 12-02-2008, 10:06 AM
  #91
Administrator
Ron A's Avatar
November 2008 added.
Fuel Cap Message On? The Fuel Fill Cap Is Loose or Missing (general info for all models)
Old 12-14-2008, 03:13 PM
  #92
crxb's Avatar
thanks for the info
Old 12-31-2008, 06:24 AM
  #93
04TL/SSM/Quartz/AT/Navi
srhewes's Avatar
Thanks!
These are great tips, such as leather cleaner, etc. Thanks for sharing with us!
Old 01-01-2009, 08:07 AM
  #94
Administrator
Ron A's Avatar
December 2008 added.
Transferring Personal Data To a New Navi Unit: A Few Facts and FAQ"S (all 08 and later equipped with navi except 09 TL)
Old 02-02-2009, 10:10 AM
  #95
Administrator
Ron A's Avatar
January 2009 added.
Don't Overtighten Those Battery Hold-Down Nuts (general information)
Old 02-10-2009, 05:55 PM
  #96
Sleepin on a master plan.
Jay-Boi's Avatar
Smile
Good info.
Old 02-10-2009, 05:56 PM
  #97
Jay-Boi's Avatar
yeah i like the lether info... good one
Old 02-10-2009, 05:57 PM
  #98
Jay-Boi's Avatar
Once again thanks for the info
Old 02-12-2009, 11:01 PM
  #99
bangbang007's Avatar
thanksw
Old 03-01-2009, 05:03 PM
  #100
Administrator
Ron A's Avatar
February 2009 added.
Can't Program Home Link? Try This Tip. 99-09 TL.
Power Mirror Works Erratically? Replace Just The Actuator. 04-08TL.
Old 04-02-2009, 11:04 AM
  #101
Administrator
Ron A's Avatar
March 2009 added.
Power Door Locks Won't Lock With Keyless Remote or Lock Switch (04-05 TL)
Old 05-04-2009, 03:02 PM
  #102
Administrator
Ron A's Avatar
April 2009 added.
Nothing applicable to our cars, but for general information:
Check Out the New Battery Cold Cranking Amps (CCA) Job Aid: Gives the Cold Cranking Amps for all Acura models. Might be helpful if you need to determine what the CCA is for your car when checking the battery, or if you want to check and see what size battery you will need for a replacement.
Old 06-03-2009, 08:32 AM
  #103
Administrator
Ron A's Avatar
May 2009 added.
Removing or Replacing Trunk Spoiler? Replace Clips and Grommets (07-08TL only)
Old 07-07-2009, 02:46 PM
  #104
Administrator
Ron A's Avatar
June 2009 added.
Disintegrating Clutch Disks Explained. All models with manual transmission.
Engine Oil Leaks From the Main Bearing Cap Side Bolts. Currently applies to all compact V6 models. I don't really know what this means but it may help someone with an oil leak.
Old 08-05-2009, 09:15 AM
  #105
Administrator
Ron A's Avatar
July 2009 added.
Broken TPMS Valve Stems Can Break Your Wallet (All models with TPMS) Deep well air chucks are dangerous for your TPMS
Tire Puncture Sealants Are Bad News for Tire Pressure Sensors (All models with TPMS)
XM Sound Cuts Out; OK After Cycling Ignition Switch (Non-Navi 06-09 TL)
Old 08-15-2009, 01:11 PM
  #106
'06 NBP TL 5AT NAV
Waveform's Avatar
Thank you Ron A. I check these every month, they certainly help me with my Service Writer discussions when I have a problem with my TL, especially when that problem is covered in one of these articles.
Old 09-04-2009, 10:01 PM
  #107
Administrator
Ron A's Avatar
August 2009 added.
Connecting Rod Breakage Explained. General Information. May be helpful to those with CAI's who live in areas with lots of rain or are prone to flooding.
Trouble Resetting That Power Window Control Module? Check This Out. 04-09 TL
Old 10-05-2009, 09:58 AM
  #108
Administrator
Ron A's Avatar
September 2009 added.
Properly Set ATF Dipstick to Avoid Starter Motor Failure-04 and later TL
Fix-It Tips For a Faded or Blotchy Dashboard-04-08 TL
Old 10-21-2009, 05:38 AM
  #109
kaj1's Avatar
Thanks for the info!
Old 11-04-2009, 10:23 PM
  #110
Administrator
Ron A's Avatar
October 2009 added.
Major topics applicable to 3G and 4G TL: None.
General information: effective July 1, 2010, any automotive shop doing repair or maintenance in California must check the tire pressures.
Old 12-05-2009, 01:55 PM
  #111
Administrator
Ron A's Avatar
November 2009 added.
Trunk lid leak? Keep reading. 2009-10 TL (Base model only with the accessory spoiler)
Old 01-06-2010, 09:49 AM
  #112
Administrator
Ron A's Avatar
December 2009 added.
Slow month. Nothing to add.
Old 01-10-2010, 11:11 PM
  #113
6th Gear
No_Nothing's Avatar
Thanks for the info. I've been reading your thread every month since I've joined.
Old 01-16-2010, 01:28 AM
  #114
8th Gear
rdrsgnn401's Avatar
This thread is basically become the new bible in my life!
Old 02-05-2010, 10:09 AM
  #115
Administrator
Ron A's Avatar
January 2010 added.
General information applicable to all models:
HomeLink transmitter won't learn remote transmitter's code.
A few words about 0-20 engine oil.
Old 03-04-2010, 08:38 AM
  #116
Administrator
Ron A's Avatar
February 2010 added.
No music with iPhone plugged into USB adapter cable (09-10 TL)
No road name at bottom of navigation screen (04-06TL)
Honda logo at bootup; Navigation system features won't work (04-06TL)
Old 04-09-2010, 10:42 AM
  #117
Administrator
Ron A's Avatar
March 2010 added.
Red sticker inside keyless access remote means water damage. 09-10 TL with tech package
Limited warranty policy changes with '11 models. General information
Old 04-11-2010, 09:04 AM
  #118
Administrator
Ron A's Avatar
April 2010 added.
Sorry, not a darn thing for TL's this month.
Old 05-06-2010, 10:10 AM
  #119
Administrator
Ron A's Avatar
May 2010 added.
Sorry, not a darn thing for TL's this month also.
Old 05-06-2010, 09:48 PM
  #120
pearlUA7's Avatar
this is good stuff, THANK YOU!
Quick Reply: Acura ServiceNews Bulletins
