How to remove/paint your grill
Note: This is for a 97 grill, although the 98-99 is different, removing it should pretty much be the same. Its up you how you want to paint it, this is just what I decided to do with mine.
1. Pop your hood. Removed the screws in red, pop out the clips in blue
2. Carefully remove the grill and then take out all the screws where its marked red
3. Separate the two pieces, and clean them well to prepare for the primer.
I got the can of primer, gloss black paint, and clear coat from home depot. They were pretty cheap, like $4 a can. I took my paint code to a shop and had them mix me a custom can with my cars color (frost white) for the outside, that ran me a bit more
4. After the pieces are nice and clean, go to a well ventilated area and begin to lay your primer. I put on about two coats with 20 min intervals. I then put on 2 coats of gloss black for the inner part and the same was done for the outer. The amount of coats is all up to you, although you don't want to put too much or else the paint will start to run. Make sure you take 20-30 min intervals between each coat.
5. Apply 1-2 coats of clearcoat and let it dry overnight. I decided to do this mod at night with a chance of rain and my clear coat didnt fully dry so im some parts it looks kinda crappy. I would HIGHLY suggest doing this during the day, preferably a sunny day.
Note: you can also paint your emblems like I did above, 1 coat of each (primer, paint, clear) should be good.
hmm
well this is my work before i add that clear coat.
I use a dremell to take out the plastic and all, and then i painted it out and added the mesh.
Now I gatta buy a set of fog lights and then do the bottom.
Whats a good inexpensive set of foglights?
Originally Posted by boriqua0240
so you did the emblems to huh. i wanted all my emblems in black but i need to know what the best way to stick em back on is?? howd you do it?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
That looks nice, did you use factory paint, or spray paint?
Originally Posted by SilverCL97
looks good but i dunno about cutting the lower grille
Originally Posted by spencer_homer
is it the same white that is on the 99? and how did u get them to mix it, did u bring them a sample or what?
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by jumpmanbsktbll
anyone have a custom grill on primrose?...pictures.... would like to check it out and get some ideas for mine
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by acuratl_2nr
Has anyone had problems with the paint peeling off?? I already have a few chips in mine
I'm n00b, disregard that post^^
better question though... can/should/has anyone painted the inner part of the grill? the part that is basically the structure for everything else...?
4x4- fat chicks cant jump
(Mid-Atlantic)
(Mid-Atlantic)
Waiting to paint mine, it's supposed to snow this weekend, so I can't paint yet
in the first step... are the "screws" supposed to pull off or twist off cuz when i twist it, it feels like its gonna break...
But it doesnt feel like its gonna break... It jsut keeps twisting... it never makes any progress... is it supposed to unscrew so like a lock on a locker or unscrew all the way cuz mine doesnt...?
(Mid-Atlantic)
(Mid-Atlantic)
So undisregard that...
