DIY: Rust Removal (60pic)
Old 03-26-2006, 07:15 PM
One custom CL
SupraManAG's Avatar
As promised, I took the initiation to take care of the rust spots on my father's 96 3.2TL. Rust was present on doors, trunk and rear fenders. The whole process took me about 2 days due to dry/cure times. All materials and paint from www.paintscratch.com ran for less then $100. In the end I am more then happy with the results. I'm an amateur at this, which goes to say that anyone can do this if you don't feel like paint body shops arms and legs.
I started by putting a wire brush blade on the grinder and grinding away all the rust.
I then proceeded with the rust treatment.
After 2 applications of the treatment the metal turns black. The treatment also serves as a good primer.
Allow 24 hours for proper drying.
The next day I started filling and sanding with 100 grid paper to desired shape.
Prepping for priming. Blue tape newspapers. Leave only small area uncovered. I didn't do that but will explain later why its best to do so. Do not prime what doesn't need priming. Shake the can well and spray 8-10 inches away. Don't make your coats heavy because you will be creating more work for yourself.
Wet sanded primer with 800 grid sand paper. You could primer again after but I chose not to.
When painting, make sure you wear latex gloves and a doc mask. Shake can very well to get an even color and spray 10 inches away. Thin coats. Repeat process until fully covered. In between coats, you can wet sand with 1000 grid sandpaper but its imperative that you do not do the final coat.
After the paint dried, I applied 4 or 5 coats of clear coat. Here comes the trick and my earlier mistake I made. Even though the color was matched to the vin, it will never be identical. After you remove the newspapers and the tape you will see the lines on where the tape was placed. In my case the color was a tiny bit darker. I used rubbing compound to rub away the rained lines.
Line is visible in this pic.
After rubbing away lines, I gently gave it light coat around the already painted area to create a mist affect so paint difference would be less visible. My mistake earlier was that I left myself too big of an area to prime and paint that when I needed to make the paints match it was harder. It will also depends on where you are painting and what color.
I applied a few more coats of clear coat.
In the end it came out better then I ever thought.
If I missed any small detail I apologize in advance.
Have fun.
Old 03-26-2006, 08:18 PM
Blenz's Avatar
Wow, great work with the write up and pictures. I don't have rust problems on my car, but I'm sure this will be greatly appreciated by anyone that does.
Old 03-26-2006, 08:29 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,405 Likes on 3,017 Posts
Nice job man, I used the same type of touch up paint cans to do my bumper, worked out well. Nice job
Old 03-26-2006, 08:37 PM
Peace, Love & Acura
ajtcl's Avatar
That really turned out nice.
Old 03-26-2006, 08:41 PM
wobie's Avatar
I knew the AmNewYork would come in handy for something, someday haha
Nice Job! Not bad at all especially for the money.
Old 03-26-2006, 09:17 PM
1999 CL3.0
dragon084's Avatar
i saw this in person, it looks like SHIT!!!
JK, that shit is incredible for a DIY, good job my man
Old 03-26-2006, 09:22 PM
One custom CL
SupraManAG's Avatar
lol
If I only had the patience to DIY the rest of the things I did to the car.
Did a coolant flush Name:  DSC02258.jpg
Looks like someone took a crap in my radiator
Old 03-26-2006, 09:34 PM
teh CL's Avatar
great work
and your coolant looks like ...i dont even wanna know what mine looks like
Old 03-26-2006, 09:44 PM
O.G.
krazy99cl's Avatar
that shit is nice....wow what a autobody pro! good work
Old 03-26-2006, 10:41 PM
Si says "shut the fuk up"
$peed])emon's Avatar
good....
i did something like that but the rust just came back....kinda annoying...
Old 03-27-2006, 11:49 AM
acuratl_2nr's Avatar
Originally Posted by $peed])emon
good....
me too,. but I didn't do the steps like you did,.. i'll follow theses steps when I do it again in the next couple of weeks
Old 04-02-2006, 01:48 AM
First EVER K24 Turbo CL
starboy2nv's Avatar
nice job arber!
Old 04-13-2006, 08:35 AM
Gaujo's Avatar
v nice, where do u get the supplies?
Old 10-18-2007, 04:59 PM
Dicorp's Avatar
does this actually work? like how long before it comes back?
Old 10-19-2007, 12:43 PM
its JDM yo!!!!!!!!
young03's Avatar
great job bro
Old 10-23-2007, 04:57 PM
240z4u's Avatar
First off, it looks like you did a decent job with the finish work. Nice job.
Its your method of rust repair that I take issue with. This is the wrong way to do rust repair. This type of repair is temporary, and will lead to more rust in the future. Its never okay to fill holes with bondo, filler whatever. Its not designed to do what it was used for. Even if you did totally eliminate the rust and stop it in its tracks, it would be back. Reason is filler absorbs water from the air, and the back side of the repair deteriorates. Viola, more rust.
Also, if you DO decide to tackle this yourself don't be afraid to cut out all the rusty metal. Get a grinder with a cutoff wheel, whatever. Just get it cut out completely.
You can get another piece of sheet metal and get it shaped by bending to roughly the contour of the old part. If you cannot weld, have someone do it for you. It won't cost an arm and a leg if you do all the finish work.
Make sure the metal is seam welded, not just tacked every 1" or so. If its tacked, the filler will crack again.
This basically leaves all the steps seen above. This is the correct way to fix rust. It will give a long lasting repair.
Problem with covering up rust, it comes back, and usually worse.
SupraMan, I am not posting this to rain on your parade. Please don't take offense. It just concerned me that so many people were considering doing this.
I got dicked over by a bodyshop years ago, and have learned to do almost everything myself so it won't happen again. The did a repair like shown in the photos and it came back with a vengance after a year or two
Evan
Biggest tip for anyone who is serious about their car, learn to weld. Its the most useful car related skill I have.
Old 10-26-2007, 12:59 AM
DemonZ's Avatar
In addition to what 240z4u said, I can tell you from experince that rust is car cancer. The only way to really get rid of it is to cut it out.
Even after you have, unless you treat the metal, repainted the car(not just primer) and make sure it's really well sealed, It will come back.
There are a lot of people who will take their car down to metal, and then spray it with some primer and leave it that way. That's a BAD idea. Primer acts like a sponge, it soaks up water and bring that moisture back down to the metal. Priming isnt a bad thing, but leaving it that way is. After you prime the car, paint it, dont just leave it.
Old 02-11-2009, 05:39 PM
What your problem is?
indoMFP's Avatar
Evan
Sorry for bringing an old thread back up, but I wanted to know if one is not to use filler or bondo, then how does one fix the rust that has been removed???
Old 02-23-2009, 11:37 PM
s10httnswtchs's Avatar
overall this isnt a bad DIY write up. Of course the fix is only temporary but spending a little over a hundred dollars beats at least prob a grand to fix it by a profesional.
There are a couple flaws in everybodys comments... cutting it out isnt always the best way to get rid of rust, sometimes having and area media blasted is a better alternative as long as the rust hasnt eaten any holes. I just dont recomend to newbs or amateurs alike to start cutting out panels and welding them back up on automotive sheetmetal. It takes lots of practice to weld sheetmetal without warping a large area around where your welding. Plus some of these problematic areas you wouldnt be able to just cut out like in the inner shell of the door.
To keep rust from coming back all rust needs to be removed from the metal or neutralized, the metal then needs to be sprayed with an etching primer folowed by a good 2 part eurethane primer. sealer then can be sprayed followed by color then clear.
Body filler(bondo is a name brand and a low grade) is sometimes needed to fill in small pitts or after a panel is welded in.. but should never be used to fill in holes except for a cheap DIY fix. yes primers are porous and have tiny holes in them that will allow moisture down in it
Old 03-05-2009, 10:45 AM
Old School Ridin Clean
WineRed2.2CL's Avatar
where did you get that spray can? with your exact color?
Old 07-28-2016, 05:26 AM
diyautoftw's Avatar
Great work, turned out nice!
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
CL-S progression 01
01-26-2016 04:15 PM
lanechanger
10-13-2015 10:56 AM
polish_pat
09-30-2015 12:22 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
Quick Reply: DIY: Rust Removal (60pic)
