DIY - Requests
Old 08-09-2007, 02:03 AM
  #121
saiko_cl_duck's Avatar
Originally Posted by arstraub
I need to know how to remove the passenger door panel - my window needs to be fixed and the door handle is also broken.
while you search, dada da da da da daaaa.......
https://acurazine.com/forums/showthr...ghlight=window
Old 08-09-2007, 01:17 PM
  #122
ur as welcome as cancer
arstraub's Avatar
thanks guys
Old 08-10-2007, 08:41 AM
  #123
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
Originally Posted by Mach30SiR
Just replace the fuel filter on a 3.0 yesterday along with distributor cap, ignition rotor, pcv valve and other easy things.
Should have probably done a DIY for at least the fuel filter but its not that hard. Hardest part is reaching the screws that hold the filter mounting bracket. Anyways if anyone needs some help just let me know.
Fuel filter wasn't hard at all. Well it was a giant pain for me because the oem replacement part I bought leaked out of both ends, but soon as I bought one that didn't work, it went right on there
Old 09-06-2007, 10:36 PM
  #124
where is....
AznX TL's Avatar
Originally Posted by hellifino69n
well i just got done doing it, and ill tell you...
get it done at a shop
cause its a biatch
x10000 i even lifted the car to try to change it, couldnt get the metal end to budge.
btw can someone do one on changing the bulb on the shifter for the 97.
Old 09-06-2007, 11:04 PM
  #125
732xghost's Avatar
im gonna try and find out if we can use a 6disc cd changer from an 6th gen Accord EX-L. i have access to them no problem.
Old 09-07-2007, 08:30 AM
  #126
(Mid-Atlantic)
It's a #74 bulb, you don't need to unscrew anything, just turn the bulb wire and pull it out.
Old 09-07-2007, 08:46 PM
  #127
where is....
AznX TL's Avatar
how do you get to it? i got the arm rest off but i couldnt find where to take out the radio/shifter column screws.
Old 09-07-2007, 09:12 PM
  #128
(Mid-Atlantic)
U can't get the console off? or see the bulb in the shifter? If the shifter's exposed I can take a pic for u to see where it is, the console is a whole different issue
Old 09-07-2007, 09:33 PM
  #129
where is....
AznX TL's Avatar
yeah i cant get the middle console right at the shifter off........or dont i need to take that off?
Old 09-13-2007, 07:51 PM
  #130
1999 Acura 2.3 CL
leetuser's Avatar
Is there a DIY up for a AEM v2 cold air intake for a 2.3 first gen cl?
Old 09-13-2007, 09:29 PM
  #131
(Mid-Atlantic)
The console that the radio is in? or the piece around the shifter? The plate on the shifter doesn't need to come off
Old 09-13-2007, 09:30 PM
  #132
(Mid-Atlantic)
Just use the regular intake install diy, there's nothing special about the v2
Old 09-13-2007, 10:14 PM
  #133
where is....
AznX TL's Avatar
hmm can you get to the bulb from here?
i was under the impression that the whole entire shifter had to come out to get to the bottom to change out the bulb.
Old 09-14-2007, 07:32 AM
  #134
(Mid-Atlantic)
The shifter plate doesn't have to come out, I already answered this question once
You need to remove the console piece, but not the shifter plate, you can get to the bulb once the console is out of the way, it's underneath. I think I'll just take a pic for you
Old 10-24-2007, 12:11 AM
  #135
972.2's Avatar
somebody should do a tutorial for removing the balance shaft?
Old 12-18-2007, 10:13 AM
  #136
Azine's only Punk PFC
Andy2.3's Avatar
Request for cheapo blue climate control mod?
I saw the blue clock mod, and the climate control was discused, but how do you do take it apart? Any insight?
Old 04-21-2008, 08:58 PM
  #137
irresponsiblekid's Avatar
whatever the thing is that keeps the trunklid from falling and chopping me in the collarbone is failing, and I can't tell what the hell to replace ... anyone got a DIY for that :x:
Old 04-21-2008, 09:48 PM
  #138
278
xdaex's Avatar
http://honda-tech.com/zerothread/1908944
This a pretty good write-up, if this doesnt help then i dunno what will.
Old 04-28-2008, 07:50 AM
  #139
Damon7's Avatar
DIY FRONT ROTOR replacement for a 97 CL 2.2
Need a DIY FRONT ROTOR replacement for a 97 CL 2.2
Old 04-28-2008, 10:56 AM
  #140
Ballin' on a budget
Doctorsound's Avatar
BWAHAHAHAHA!!!!! Pain awaits all who attempts front rotor replacements!!
No, but seriously, I'd like to see this too, the last time I went to do my brakes I realized that I wasn't equiped to handle that. Apparently you need a special tool...
Old 04-28-2008, 11:20 AM
  #141
(Mid-Atlantic)
Search next time please, 3.0 and 2.2 are the same hub/rotor design
https://acurazine.com/forums/showthread.php?t=148107
Old 05-23-2008, 03:27 AM
  #142
yomomsbigpimp's Avatar
Is there a DIY for projector lights conversion on a 97 cl? I know I've seen some pics on a forum but I can't seem to find them.
Old 05-23-2008, 07:57 AM
  #143
its JDM yo!!!!!!!!
young03's Avatar
search
Old 05-23-2008, 11:25 AM
  #144
(Mid-Atlantic)
YOu have to make your own projector lights, and there are plenty of writeups on here about how to do it
Old 05-27-2008, 03:39 PM
  #145
JORTS's Avatar
DIY REQUEST: TUNE-UP with pictures.....I realize doing a tuneup is a relativiely easy process...but i am not mechanically inclined!!! 98 2.3 with 115,000 miles. I have owned the car since 80k and nothing done to engine besides new clutch. I feel the MPG are not as good as they use to be...
PLEASE DIY for changeing spark plugs, wires, distributer cap, fuel filter and anything else sugguested!! also, should i just pick these items up at autozone??
thanks
Old 06-10-2008, 01:20 PM
  #146
JORTS's Avatar
thanks
come on guys help a guy out with a tune-up cant be hard just let me know exactly how to do it!!
Old 07-31-2008, 04:26 PM
  #147
Mmmm...
CLpwner's Avatar
Bump because I'm curious... It's pretty much discussed in the Haynes manual I have, but I want color pictures... hahahahah
Old 09-14-2008, 09:33 PM
  #148
jaimelinwu's Avatar
Has anyone removed the rear interior side panels, like the interior door panels, but by the rear seats? Are there any special tricks I should know before I try and possibly tear the panel off?
Old 09-14-2008, 09:38 PM
  #149
jaimelinwu's Avatar
I found this "1997-1999 SERVICE & BODY REPAIR MANUAL" for Acura CL on ebay. Has anyone tried or heard about it? Is it any good?
http://cgi.ebay.com/ebaymotors/ws/eB...m=370084672319
Old 09-14-2008, 10:46 PM
  #150
(Mid-Atlantic)
Unbolt/unscrew it
Old 01-09-2009, 02:19 PM
  #151
floridagatorz1983's Avatar
Radiator fan replacement?
Is there a DIY for radiator/ condensor fan replacement?
Old 01-09-2009, 03:09 PM
  #152
(Mid-Atlantic)
It's only 4 bolts, I believe there was an alternator replacement diy that told how to take it off, but it's 4 bolts and a wiring harness clip, not too hard, I had to take mine off to do my radiator
Old 01-16-2009, 11:06 AM
  #153
7th Gear
nappy99cl's Avatar
New headunit with factory Bose???
I did a few searches on installing new head units and have seen many people say they can either use the factory amp with a new head unit or bypass the bose amp very easily, but nobody ever explains how to do this. I found a few pictures of factory radio harness, but still dont see a wire to trigger the factory amp. So i suppose my question is how, if you can, how can you power the factory amp with a new head unit, or how can you easily bypass the factory amp with out running new wires to every speaker? maybe im just being lazy because i dont want to take my car apart for just a few wires, just looking for the easiest possible way or a shortcut
Old 02-23-2009, 02:03 AM
  #154
Boats and Hoes!
Mike86's Avatar
Has anyone put a 98-99 console on a 97 model?
Old 02-23-2009, 08:12 AM
  #155
(Mid-Atlantic)
dragon084 has
Old 02-23-2009, 10:16 AM
  #156
CL in lawnmower status
mitch14's Avatar
dragon084 has
^really, i thought he didn't do it
Originally Posted by dragon084
all you need to do is buy the console.
you need the whole assembly though.
i however, did not do the swap.
^that was taken from Cheehos's Public Profile as response to when he asked Greg about the swap
here's a thread where Cheehos started to gather info about the swap but i don't think it's actually complete yet
https://acurazine.com/forums/1g-cl-diy-faq-74/center-console-97-98-99-a-703873/
Old 02-23-2009, 12:47 PM
  #157
i like acura
spencer_homer's Avatar
wow. how much time did you waste trying to prove someone wrong.
he has it done.
he didnt do it. as in he had someone do it for him
Old 02-23-2009, 04:39 PM
  #158
mitch14's Avatar
i didn't spend a lot of time, i just remebered it from the time that Cheehos started his thread, thought i'd share it with you guys especially the link to the thread and the member Cheehos to see the replies from Greg that he wrote on Cheehos's public profile. If he did have the swap done, then atleast my info plus links will keep him from asking Greg (dragon084) the same questions that Cheehos did
btw when did i say that he didn't have it done? i just said what greg had replied to Cheehos with, and i wasn't proving it one way or another all i said is that's what i "thought"
Originally Posted by mitch14
^really, i thought he didn't do it...
Old 02-23-2009, 07:22 PM
  #159
Boats and Hoes!
Mike86's Avatar
Hmm, well I just wanted to know for sure if someone has, and if so, if there was much modification that needed done to fit it. It probly won't be easy to find a 98-99 manual trans console anyway, but if I did come across one for a good price I would buy it if it is interchangeable with mine. I'm a fan of the wood trim and I think it looks so much cleaner and classier than the 97's
Old 02-23-2009, 10:38 PM
  #160
(Mid-Atlantic)
shouldn't matter if it's manual or not, the console only has one square opening
Quick Reply: DIY - Requests
