DIY - Requests
#41
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by paradigmsk8er
hey all, im new here. i drive a 97 acura 2.2cl an dabsolutely love it..i just recently got it as my second car.
anyways ive been installing stereo stuff for awhile but i like to kno wwhat im getting into before i dive into a project...CD player and HU wise...is it a difficult install? is it iso mounted? what exactly do i have to do to put a new HU in? remove the dash?
any guidance and help is much appreciated! ive got some big plans for my Cl and im exicted to be here!
#42
so if the pocket is attached...i take it that means i have to get an adapter/dash kit to mount the HU huh?
http://www.cardomain.com/item/SCOHA1563B?vq_id=none
that work? anone know of a cheaper place? sounddomain just has a readily available stock...
also, is this an easy plug and play:
http://www.cardomain.com/item/SCOHA02B?vq_id=none
or does it require some fiddling to get it to work? ive used several that arent wired properly or marked...
thanks again for th ehelp!
#47
Originally Posted by Bigpimpin18
Hey klepto, would it be cool if I did a write up on installing an aftermarket alarm with remote start on my 97 2.2CL?
#48
www.ledautomotive.com will the kits for moonroof, sunroof, etc.. especially the CLIMATE CONTROL KIT work in the cl???? im so sick of the green!! all my other lights are done!! i just dont want to go about ordering tons of lights and shit if i can just get the kits for them u know!! does anybody know??
#49
#54
Request - DIY for changing the security LED to BLUE
Can anyone provide a step by step DIY on how to change the stock Red security LED to a BRIGHT BLUE? I would also like to know the size of the LED used and the correct voltage LED needed.
#63
Bagel Bomber
does anyone even check this anymore I can write the diy on the trunk and deck dynomat if its still needed. thinking about writing a diy on the clogged egr repair, anyone??
#65
Ahhhhhhhh
Originally Posted by Gaujo
i check, I'd be interested in reading about dynomatting too! Its expensive to have done at the audio shop.
#75
Originally Posted by herbalist
anyone got a DIY for the cigarette lighter? my phone charger plug made it all loose from all the twisting and now it doesn't work. anyone???
#76
You have to remove the center console(armrest) Then remove the trim under the steering wheel (pops right out) and remove the rubber stoppers from the glove box, there are screws behind both. The hu is mounted inside the console. It's bolted, so you have to get all that stuff out, then remove the headunit and pocket (they're attached) That's it. Not too hard, just figuring out how to get the console apart the first time is a bitch. After that, ripping your interior apart is simple, I do it all the time
#78
Failed Emmissions Test...Catalytic Converter Install
Hey Guys,
My CL failed the emmissions testing and I took it to a good friend who happens to be a high-end master mechanic. When he checked it out he said I needed a new cat. converter and it was going to cost $1400 installed. I don't have that kind of cash, so does anybody know if I can get an aftermarket catalytic converter online for cheap that would pass the tests? Also, should I try the install or should I take it somewhere? Also, does anybody have any clue how much coin I should expect to drop on this little repair if I let somebody else install it?
#79
Originally Posted by j8shua
Hey Guys,
