Crankshaft Position Sensor
Old 01-23-2014, 09:56 AM
chigdon92's Avatar
Ok guys, this is my first post here, I have searched google and various Acura forums for a couple weeks and have no definate answer.
My wife has a 1997 Acura 2.2CL. I am about 100% sure the crankshaft position sensor is bad as the engine will randomly stall while driving, the rpm tack will dance around before it stalls and will completely die sometimes after it stalls.
I also have the engine error codes for the VTEC system showing up, which is unrelated to this issue but maybe a second opinion.
Now my real question, anyone have a guide or instructions to make it easier to replace the crankshaft position sensor? I know where its at and know the sensors go into the timing belt case, I know I will have to take off the 2 belts prior to taking off the timing belt case but will I have to remove other parts inside the case to replace the sensor or will this process be more simpler than I am thinking?
Old 12-31-2015, 08:02 PM
1999 Acura CL 2.3
Gigolo's Avatar
old post but i had similar issue..
turned out to be ignition switch..i was thinking it was the crank shaft senor to
MrHeeltoe
20
02-23-2023 01:54 PM
RobbDizzle
10-15-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
thegipper
09-28-2015 01:01 PM
Quick Reply: Crankshaft Position Sensor
