"My seat won't move/recline" thread
Old 02-29-2016, 06:40 AM
  #121
7th Gear
cota50's Avatar
There is a $700 electrical part under the seat, memory module. Has to do with the memory feature. Junkyard.
cota50 is offline
Old 06-02-2016, 09:00 AM
  #122
tsx04A's Avatar
Seat Jammed
Originally Posted by Scott Tuley
Just got my 05 TL about a month ago and only one of the motors to move the seat forward and back works. I want to try and replace the other.... Anyone know how to replace the motors that move the drivers seat foward and back, and where to get motors for a good price?
Hey guys, I'm having a similar issue. Pressing the switch has no effect, almost like its jammed. Although the lever for moving forward and back is working fine. Just the lumbar recliner that's jammed. Would anyone be able to walk me through how to go about this. Much appreciated. Thanks for your time.
tsx04A is offline
Old 12-16-2016, 03:41 PM
  #123
killer ride's Avatar
Originally Posted by TOPHER33884
No, it is not an electrical short.....your gears are stuck! Pop off the plastic cover on the side of the seat by the cloth part where the seat folds.....move the carpet/cloth out of the way, and you will see the gears, Get soem WD-40 spray the hell out of them, and get a flat head screw driver in between the gears and keep hitting the switch while moving the screw driver...it will break loose.
are you talking about the plastic part where the switches are?
killer ride is offline
Old 12-24-2016, 06:15 PM
  #124
Jaywil's Avatar
can u please help me with the my passenger seat in my Acura Cl it's stuck and I heard u can help my email is jaywil135@yahoo.com
Jaywil is offline
Old 03-01-2018, 04:10 AM
  #125
tracimarie79's Avatar
Seat recline moved all the way back and will not move back up
I have a 2002 Lincoln LS. Seat motor not making noise, i opened up the switches on the side of the seat and i see no obvious corrosion. I have tried forcing the seat while using the switch. Nothing has worked. Any ideas?
tracimarie79 is offline
Old 08-07-2018, 04:57 AM
  #126
MangoBS's Avatar
Just to help anyone who needs it. I was vacuuming and must have hit a wire out of place. Driver seat would recline and tilt up and down but could not move back and forth. It was back all the way wich is a problem because im like 5'6. I looked under the seat from the front and saw a blueish gray plug that came un done. After plugging the two ends back together it worked. I could see a blue mark on the plug, probably a marking from the factory.
MangoBS is offline
Old 02-15-2019, 11:37 PM
  #127
Miss McQueen's Avatar
Seats won’t recline 2001 Acura CL
Can someone please help me? Both drivers side and passenger side seats won’t recline
Miss McQueen is offline
Old 02-18-2019, 02:29 PM
  #128
I need help my seats want recline
Old 02-18-2019, 05:44 PM
  #129
Received 1,736 Likes on 1,392 Posts
Miss McQueen, the best advice I can give, reluctantly, is if you are in a metropolitan location and have access to an Acura dealer you may want to consider taking it there and pay the 'diagnostic' fee to have your situation looked at. With that said, the reason I say 'reluctantly' is because I'm mentioning taking it to a dealership in the same sentence.
In addition, your issue may be as simple as a blown fuse(s) or as complex as faulty electrical/switch connections, faulty actuating motors/sensors et al. These seats are complex operating units and your issue may involve many electrical tests, involving the potentially faulty items in the previous sentence, that only an experienced individual, with the proper skillsets, can perform.
Good Luck!
zeta is offline
Old 07-27-2019, 07:28 PM
  #130
alex zamora's Avatar
You guys are awesome..
Originally Posted by stonedcl
my passenger seat did not recline fopr like months at one point but then on of my boys didnt wanna sit up erect so he started forcing it back while holding the switch and it started working again!
worked like a charm! Thank you!
alex zamora is offline
Old 08-24-2019, 07:49 PM
  #131
Janored VanSolkema's Avatar
Did you try the method that I gave you on the seat fix? If you dont understand what I am talking about......I have walked thru this with 4 members over the phone. If you interested, I will give you my number so that I can assist you thru it.
I need help with this problem too
Janored VanSolkema is offline
Old 02-17-2020, 06:41 PM
  #132
Timothy Elliott's Avatar
Could you give me a call??
could you give me a call please?
Timothy Elliott is offline
Old 02-17-2020, 10:28 PM
  #133
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Welcome to the forums.
Why do you want him to give you a call? You should post your question here, if you have one.
You shouldn't expect to receive a call anytime soon since the person you requested a call from hasn't logged in since 06-10-2016, alomost 4 years ago.
And even if he did, he would have to conjure up your telephone number since you didn't post one.
Unless he's a long lost friend and knows your number.
Ron A is offline
whitetiger5 (02-20-2020)
Old 05-17-2020, 11:26 AM
  #134
BecMDX's Avatar
How do I PM Topher for help?
how do I PM Topher for help with my Acura MDX drivers seat? All the adjustment buttons are working EXCEPT moving the seat forwards and backwards. I cannot drive the car again until this is fixed. Help please?
BecMDX is offline
Old 05-17-2020, 12:22 PM
  #135
Administrator
Ron A's Avatar
Topher33884 hasn't logged in since 06-10-2016 and hasn't posted since 07-05-2015 so your chances of getting a reply would be pretty slim.
Your best bet would be to post a new thread which might gain more attention than this old old thread and get you some helpful replies.
This thread is now closed.
Ron A is offline
uzzmaan
03-12-2024 10:03 AM
02-25-2020 09:57 AM
Joeyc850
10-30-2015 12:15 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
Quick Reply: "My seat won't move/recline" thread
