'97 Acura 2.2CL 37k : Torque Converter or Engine Related?
The facts of the problem:
I stopped the car, applied hand brake, shifted to Neutral, and opened the hood. The RPM still dips, and the engine shakes at that time. Holding a piece of paper to the exhaust, I see the exhaust also gives an extra puff at the same time as the RPM falling, blowing out slightly harder, not sucking in.
My specific question:
Can I rule out the TC as the cause of the problem, considering the RPM flutter in Neutral? Could this be bad spark plug/wires?
Thank you for any help!
- '97 Acura 2.2CL 37k
- Hesitation or RPM fluttering
- RPM falls by 1000 or more, sometimes to 0 when driving or stopped in gear, in park, and in neutral
- At speeds of 70 or more, RPM does not fall
- Problem occurs with no grade, up grade, and down grade roads
- Acura dealer tech diagnosis: Torque Converter (TC) is failing
- Service rep explained that the technician is seeing electrical problems, causing RPM flutter, with TC as the root cause
- Service rep says he cannot tell me what piece of the TC is failing because 'they do not open up TC's at his shop'
- Tech used a 'load test'
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
Skirmich
09-15-2015 06:41 PM
