Need information on wheel fitment
Old 07-22-2015, 10:06 AM
C.Austin88's Avatar
I'm wanting to buy a set of STR 607's for my 01 CL, I'm wanting 18x8.5 and want to know if they will work..can't really find anything on the Internet so I was just going to see with some of yall experience with these cars what the best options are. Thanks
Old 07-22-2015, 10:27 AM
Received 16,260 Likes on 11,971 Posts
it all depends on the offset.
Old 07-22-2015, 03:08 PM
aznboi2424's Avatar
What crabs said....
Old 07-22-2015, 07:04 PM
C.Austin88's Avatar
Offset is +35
Old 07-22-2015, 08:32 PM
3.5 psi
gnuts's Avatar
you'll need to roll your rear fenders and cut the bumper tabs there. Run some negative camber and probably a very mild tire stretch.
i'm running 18x8+35 with a full tire and i rub in the rear on big dips with rolled rear fenders. i have an ingalls rear camber kit waiting to go on that will solve the rubbing.
Old 07-23-2015, 07:06 AM
C.Austin88's Avatar
Ok I plan on dropping the car around 2". Not wanting to slam but have a flush look. I appreciate all the help guys!
Old 07-24-2015, 05:19 PM
aznboi2424's Avatar
Is there a lip on the wheels? If so then you'll definitely rub.
I'm running 18x8, +35 also with no lip on 235/40/18 tires. It rubs on big dips in the front. I'm dropped 1.2 inches.
Old 07-24-2015, 07:18 PM
3.5 psi
gnuts's Avatar
Why does having a lip matter? The rims are the same width regardless of a lip.
Old 07-26-2015, 07:58 AM
C.Austin88's Avatar
No rims have no lip, but to my earlier statement about the offset they are not +35 they are +30 but no matter I'm going to roll my fenders regardless. Now I do have another question...What type of suspension are you guys running?
Old 07-26-2015, 10:19 AM
3.5 psi
gnuts's Avatar
There are so many options. If you're running aggressive offset then you'll want some coilovers preferably with dampening option.
Old 07-27-2015, 05:29 PM
aznboi2424's Avatar
My fault, I have RL calipers so I'm sure my "lip" statement doesn't apply to the OP
Old 07-30-2015, 01:55 AM
CLSilk's Avatar
Don't mean to barge in on this conversation but for our cars (2003 CLS) the higher the offset the better? I'm looking at 18x 8 also running 235/40/18 tires. My car is dropped via tanabe nf210 springs and eibach pro dampers. Thanks.
Old 07-30-2015, 01:31 PM
3.5 psi
gnuts's Avatar
That's a very mild drop (had them at one point) so I don't think you'd rub either way, but to be safe stay +45 or higher.
CLSilk (08-04-2015)
Old 07-30-2015, 03:11 PM
C.Austin88's Avatar
Thanks guys this has all be really helpful
Old 08-04-2015, 01:24 AM
CLSilk's Avatar
@ gnuts, so let's say an offset of +45, +48, or +53....... On a 18x8 wheel. When is an offset too high if possible? Regarding to my vehicle I mentioned specifically. Thanks!
Old 08-04-2015, 09:46 AM
aznboi2424's Avatar
Well stock wheels have an offset of +55. It would be hard to find wheels that high or higher. But I wouldn't go past that because you risk hitting the inside of the wheel against your brake calipers.
02-25-2020 09:57 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
KB1_EJ6
11-13-2016 09:51 PM
Iain MacLeod
09-16-2015 02:38 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Need information on wheel fitment
