235 or 225
Old 06-05-2015, 01:12 AM
CLSilk's Avatar
235 or 225
So I just lowered my '03 CLS (auto) via eibach pro dampers and tanabe nf210 springs. I know.... I know...... coilovers would of been a better choice but for my situation I felt this was a decent setup for my priorities...... Long story short. I'm going to get a set of new shoes and I'm wondering what the differences in ride quality, if any are between 225/40/18 and 235/40/18? I know some have said the "235" will allow the speedometer to better read??? I have read alot of the posts in here already but my main question is ride quality? Rim of choice is enkei rpf1, 18x8. I'm only lowered 1 inch in the front and about half to 3/4 in the rear. Thanks in advance.
Old 06-05-2015, 01:14 AM
CLSilk's Avatar
I have took the time to read all that I can on here so please have some patience. I'm just looking for some current advice from members with their wheel and tire setup(s). Thanks.
Old 06-05-2015, 03:43 PM
aznboi2424's Avatar
I'm running 235/40/18 for the reason to keep the speedometer accurate. This is the size that will keep it the most accurate.
Never ran 225/40/18 but compared to 235s, the ride on the 225 will be harsher because the sidewall is shorter. You will also lose some traction because of the narrower tire. But I think the tire prices are better for 225s. To me, it wasn't worth it, 235 all the way.
CLSilk (07-12-2015)
Old 06-08-2015, 08:08 AM
GroundeDCustoM
GroundedCustom's Avatar
Depends on width of rim. On 8" go 235 for sure. On my stocks i run 235/45/17
CLSilk (07-12-2015)
Old 07-12-2015, 05:44 PM
CLSilk's Avatar
Thanks guys!
Old 07-15-2015, 12:03 PM
3.5 psi
gnuts's Avatar
I'm running 18x8 RPF1 with 235.
Old 02-28-2016, 09:42 PM
Oldsman71's Avatar
Any rubbing issues with the 18x8 +45 offset and 235/40/18 tires? My car is sitting down about 1" in front and 3/4" in back (from stock) with H&R OE sports and bilsteins. I never had any problems with the 225/45/18 on 18x7.5 +53. I was even wondering if 245/40/18s would fit without being a problem. I do not have rolled fenders or a camber kit.
Old 02-28-2016, 10:47 PM
Lone Wolf
brian6speed's Avatar
I would think you could run 235 or 245 and be fine. Your current wheels have 13mm more inner clearance and 1 mm less outer clearance than my SSR wheels that are 18x8.5 +52 that I run 255 tires on.
Oldsman71 (02-29-2016)
Old 02-29-2016, 09:33 AM
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
I have h&r sport springs and koni yellows with 18x8 +45 aspecs. I run Michelin pilot super sports in 235-40-18 and when I rub occasionally. When I first put them on the back would rub any time somebody was in the back seat until I trimmed the bumper tab. The only problem I have is the front rubbing when turning and there is a dip. It rubs on the the front fender liner clips
Old 02-29-2016, 06:24 PM
Oldsman71's Avatar
Thanks for your responses. I Thought I was going to get a set of those 2005 18x8 A-Spec wheels on ebay. Just got a refund from seller instead. Will probably go with a 17" rpf1 or GT7. Really bummed out now.
Old 02-29-2016, 06:55 PM
Ordered a set also and go the refund as well.
Old 02-29-2016, 10:40 PM
JarrettLauderdale's Avatar
Well I'm pretty sure that there's nothing wrong with RPF1s, so I'd say your squared away if you get those.
Old 03-01-2016, 03:05 PM
3.5 psi
gnuts's Avatar
get 18s though. 17s will look too small.
Oldsman71 (03-01-2016)
Old 03-02-2016, 06:41 AM
Oldsman71's Avatar
The only silver 18x8 rpf1 that fits our cars has a +35 offset. I feel that this might stick out to far (well over an inch from stock). The 18x7.5 has a +48 offset, but its probably too narrow to run a 235 tire. Not sure what I'm going to do.
Old 03-02-2016, 07:13 AM
I used to run 235-40-18 on 18x7.5 aspecs.
Oldsman71 (03-02-2016)
Old 03-02-2016, 09:15 AM
3.5 psi
gnuts's Avatar
I have those rims on currently with 235/40. I will rub on big dips in the rear only. I'm dropped about 1.6" around, rolled rear fenders and no camber kit. (ingalls is going on in the spring). With a 225 you might be ok.
Old 03-02-2016, 03:15 PM
Oldsman71's Avatar
If those are pictures of this set up, it doesn't look too bad. I thought it might "balloon" the sidewalls a little more. Tire racks specs recommend a minimum wheel width of 8" for a 235. Did you have any "funky" wear or ride issues? What did the 18X7.5 Aspecs come off of? TSX?
Old 03-02-2016, 03:54 PM
I never had any problem with wear or ride issues. They never really ballooned and they fit well in my opinion. The 18x7.5 aspecs were off a tsx and had a 55 offset.
Old 03-02-2016, 07:30 PM
Oldsman71's Avatar
Good to know this. Thank you. I'm a month or two away from having to make a firm decision. Perhaps a set of those sparkle silver Aspecs will pop up somewhere before then. If not I can still go with 18x7.5 rpf1s
bailey24
08-31-2015 05:38 PM
mc222
Motorsports News
08-18-2003 02:55 PM
nkx1
09-07-2002 09:48 AM
erik
03-29-2002 10:54 PM
Quick Reply: 235 or 225
