Jacobpockros’s CL-S 6-Speed Thread
Old 01-01-2011, 12:37 PM
  #321
Lone Wolf
brian6speed's Avatar
Dont be afraid to enjoy the car. You can take it up to redline. I go to redline probably 15 times every 30 minutes of driving.
You can fit bigger than 235 tires in the wheel wells. Ronjon has 255 without rubbing i believe. I have 235 now but want to go up to 245 or 255 for my next set.
brian6speed is offline
Old 01-01-2011, 12:42 PM
  #322
StreetKA's Avatar
i would not go more than 235/40 235/35 on 7.5" rim i have 235/40 on 7.5
StreetKA is offline
Old 01-01-2011, 01:40 PM
  #323
Jacobpockros's Avatar
I hear yo streetKA. Are your fenders rolled though?
Jacobpockros is offline
Old 01-01-2011, 02:13 PM
  #324
ParaSurfer1979's Avatar
You dont need to roll yours. the offset is fine. 235mm tires will fill the full 7.5in width... It'll look good. I have another question. You seem to have dome mostly Comptech. Why didn't you doe their springs?
ParaSurfer1979 is online now
Old 01-01-2011, 04:44 PM
  #325
Great question. I chose not to do their springs because they only drop the car 1.5 inches. Also, the majority of them are defective which causes them to rust a lot of the time. Also, Comptech never made Struts to go with their springs, and I didn't want to be riding on stock shocks with a lower drop, so the Eibach springs and struts turned out to be the much better choice, plus they match
Comptech also made a strut bar for the CL-S, and I have thought about getting it but I have heard from every member on here that they didn't feel any improvements with it. One more product that Comptech made for the CLS is a front swaybar. I already have the rear one, and if I was to buy the front one, all it would do is stiffen up the front, which would give my car more understeer.
Old 01-01-2011, 08:43 PM
  #326
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,130 Likes on 4,801 Posts
RJ is running the 255/35s on his 18x8 +48mm Legends. If they cleared the BBK Id have an identical setup.
civicdrivr is offline
Old 01-02-2011, 12:03 AM
  #327
Thats why you rub and I didnt. My HR's gave 1.3 drop. Im not a fan of race springs for the obvious issues you are having. That rubbing would make me turn my big curls str8....lol. Yeah I'd skip on fsb. That strut bar is nice. Just keep in mind CT had reasons for the perameters it on its parts for the CL. One issue u are learning now.. I can bet you that you aren't rubbing the fenders but the wheel well lining.
Old 01-02-2011, 01:25 AM
  #328
^Yup, it rubs, but only when I'm hauling ass on turns. It's such a light rub that it just sounds like your scratching a piece of wood. I will fix it once and for all though with the Eibach rear camber kit. I'm only planning on adding just enough so that it clears the wheel well lining.
Also, my Eibach drop didn't rub until I put the new wheels and tires on, because the stock wheels are 7's and the ones I have now are 7.5
Old 01-02-2011, 04:06 PM
  #329
Icebox Install pictures:
Removal of old airbox. I cleaned things up before the icebox went in:
Cleaned up and labeled the old Airbox and packed it away in case the car were to be returned to stock:
Install:
Final Product:
Old 01-02-2011, 04:14 PM
  #330
StreetKA's Avatar
next time get an better camera than cell phone
StreetKA is offline
Old 01-02-2011, 04:22 PM
  #331
nf3d0149ab's Avatar
Looking good man.
nf3d0149ab is offline
Old 01-02-2011, 04:24 PM
  #332
Originally Posted by nf3d0149ab
Looking good man.
Old 01-02-2011, 05:16 PM
  #333
Boy didnt i tell you to send me you cell pix and i can clean them/enhance them up so they are easier to make out?...lol Here they are after i fixed them...
Got ride of graininess. Make sure your phone set to best settings and keeping a very steady hand helps.
I hope you didnt mind but as you see member start complaining when pix are well... crappy..lol
Old 01-02-2011, 06:36 PM
  #334
Thanks for doing that. I know that my pictures were crappy but it was better than not posting them at all
Old 01-02-2011, 07:50 PM
  #335
anthracitecl's Avatar
Looking good~ so CT ice box doesn't make any noise? I was gonna get ct ice box to replace my AEM.
anthracitecl is offline
Old 01-02-2011, 07:57 PM
  #336
nf3d0149ab's Avatar
Pretty much OEM sound.
Old 01-02-2011, 08:47 PM
  #337
Anything for one of my AZ buddies.
Old 01-02-2011, 08:53 PM
  #338
It does have a hint more throatiness. But this is the 1st time i've ever heard anyone say the J-series motor with intake was too loud. I can get enough of hearing her x-over into vtec... Used to redline my CL-S6 any chance I could just to here those gloreous cams/valves do their work...lol. Cant wait to purchase the Takeda Intake for my TL.
Old 01-02-2011, 10:10 PM
  #339
CLtotheTL32's Avatar
Received 9,493 Likes on 6,165 Posts
Nicely done sir
CLtotheTL32 is offline
Old 01-03-2011, 12:08 PM
  #340
civicdrivr's Avatar
You actually took the bumper off?
Old 01-03-2011, 02:01 PM
  #341
Thanks. I didn't notice any difference in noise with it on.
:gheyhug:
Nicely done sir
Yes! It was so much easier to do it this way. Also, taking off and putting on the bumper is a piece of cake.
Old 01-03-2011, 02:14 PM
  #342
civicdrivr's Avatar
Yea, I agree the bumper is easy to take off, but its not required. If you turned the wheel all the way to the left and peeled back the splash shield you can access everything.
Old 01-03-2011, 02:19 PM
  #343
If I get 2 degrees of camber in the rear of my car, will it handle a lot worse?
Old 01-03-2011, 02:22 PM
  #344
civicdrivr's Avatar
Not really, but at -2* you will have premature tire wear. It may feel better in the corners but it also may feel as though its wandering when driving in a straight line.
Old 01-03-2011, 02:28 PM
  #345
Well if I do that, then re-align the front, it should be fine right?
Old 01-03-2011, 02:38 PM
  #346
civicdrivr's Avatar
Changing the camber on the rear wouldnt do anything to the front. But most alignment shops only do all 4 corners anyway.
Old 01-06-2011, 03:34 PM
  #347
UPDATE:
Something came in the mail today
What's inside the box?
Another box was what was inside the box!
But what is inside this box?
Old 01-06-2011, 03:43 PM
  #348
Awesome... I hope that the camber kits work for you. Let us know.
Old 01-06-2011, 03:45 PM
  #349
god damnit, why am I so obvious
Old 01-06-2011, 03:49 PM
  #350
StreetKA's Avatar
Is it fromt camber kit ? How much ? And why?
StreetKA is offline
Old 01-06-2011, 03:50 PM
  #351
Stop using GD bro. damn dude. Can't wait for you to meet your maker...lol. It's obvious btw because you spoke so much about how this will elliminate the rubbing. I'm not so sure but I hope it works because id hate to waste mony on something that doesnt fix the problem...
Old 01-06-2011, 03:52 PM
  #352
Rear camber kit. $100 from ebay. Because I want to stop rubbing in the back of the car and I want a small stance.
Old 01-06-2011, 03:54 PM
  #353
I'm not religious lol. I won't say it anymore though . I am 100% sure it will fix the problem. I only need a half inch of camber to clear the rear tabs.
Old 01-06-2011, 05:52 PM
  #354
civicdrivr's Avatar
Small stance + your ride height = doofy
Old 01-06-2011, 07:43 PM
  #355
Number 1: Your an asshole
Number 2: I'm realistically only going to add a tiny un-noticable amount of camber. I'm only going to add just enough so that it clears this:
I'm not really going to have a stance
Old 01-06-2011, 07:55 PM
  #356
03type_s6speed's Avatar
Post back your impressions of the eibach rear camber kit ... I'm about to purchase a kit and you feedback will help me decide.
03type_s6speed is offline
Old 01-06-2011, 08:37 PM
  #357
civicdrivr's Avatar
Just roll the goddamn fenders already. Its not going to degrade the value of an already cheap car.
Old 01-06-2011, 08:55 PM
  #358
Regional Coordinator (Texas)
nspec_ya4's Avatar
true. it doesnt affect the value of the car at all. unless u do a fucked up job.
nspec_ya4 is offline
Old 01-06-2011, 09:24 PM
  #359
Nah, I'm just gonna go around it. It will work
Old 01-06-2011, 11:00 PM
  #360
nf3d0149ab's Avatar
Yeah man nobody would know....
Quick Reply: Jacobpockros’s CL-S 6-Speed Thread
