Jacobpockros’s CL-S 6-Speed Thread
#241
Nope, my audio systems are stock. What wheels and tire sizes are you running? Also, the Eibach springs sit higher in the front because Eibach test-fitted them on the auto, but it doesn't mean that they were only meant for the auto.
#242
It Volk SE37A's 18x7.5 18lbs if memory serves me right. tires were so light added more tq-steer.
#243
Your Friendly Canadian
Received 1,484 Likes
I highly doubt a crank pulley is going to give you that much power/tq.
#253
Whats up with RDX owners?
You can see that the front on the blue one is a little higher. It all depends on the ground its sitting on.
#257
Your wrong about what I payed. I payed less than that. Also, I have a guy that can install it all for $100. I could do it myself if I wanted to, but I prefer a mechanic to do it because they have impact guns. Also, Superchargers cost more than 3 times of what I payed.
#258
Missing my
Civic, sorry to hear about your dog. It's like losing a family member.
#260
Huge difference with headers and Comptech Mufflers. Numbers speak for themselves...
#261
revs faster = more tq= twisting forces which means more power DUH!!! I'm kidding (the duh part).
#262
UPDATE:
So the weather cleared up and I finally drove my car today with the new Icebox. I mostly just drove below 3.5 RPMs, but I did do one 40-90 pull. To be honest, I didn't really notice any difference, but I did notice that my car seemed react faster after I let out the clutch after each high RPM shift.
My guess is that I will notice the icebox's true power after the headers get installed.
#263
Yea I didnt notice any difference either.
#264
Missing my
Pretty hard to feel a HP gain that small, but you will certainly feel it with the headers. Also, for those with the AEM CAI, there is a noticeably throatier and deeper sound when the car hits VTEC. Not sure how it goes with the Icebox.
#266
I absolutely loved how quiet the Icebox is.
But Ive grown to enjoy the throaty, om-nom-nom-more-air sound from an open element filter.
#267
Did you reset ecu? The pulleys should let engine rev fastern due to less rotational mass. Wont be much power but low-end tq should be different.
#268
UPDATE:
Send me your pix b4 you post if you like.
Notice the difference? not as grainy or "washed" out.
#271
It's probably close to being completely broken in. I wouldn't worry about it unless you were doing some serious engine mods.
As far as the crank pulley discussion, I remember there was a thread around here saying it freed up a negligible amount of horsepower. Backed up with calculations. I'll try to find it.
#272
Here it is:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/lightweight-crank-pulley-calcs-sorry-long-read-790020/
Yeah, I kinda ish fail
#274
Damn who owned that b4 you? Nope you are fine.. Next time you go into Acura for service just have them look at it. It wont hurt. Major work isn't dont till 105k. Your clutch be fine if on normal situations you are granny to semi-granny shifting through the gears...lol. Dropping the clutch or power shifting (pushing in clutch/shifting under WOT) will cause the clutch to wear fast...
#280
I'd have the timing belt checked out at least. Manual says it should be switched out every 105k/7 years, but your car's probably well past the 7 year mark.
As far as negative rear camber, depending on how much you dial in, I don't think it should be that noticeable, but you'll go through tires faster.
